DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Mar 22, 2021 at 1:00 PM
    #1341
    Eastkat808
    Eastkat808 Well-Known Member
    Esket
    2012 DCLB 4x4 sr5
    bilstein 5100 cranked up
    That’s the problem I don’t have the time for it, luckily I found a awesome Toyota Lexus dedicated shop where I’m at to do it for 200 bucks. Easy. saves me the mess. I was just saying if he wasn’t going to do it himself make sure he finds guys who know what they are doing because I made the mistake of trusting any transmission shop
  2. Mar 22, 2021 at 1:10 PM
    #1342
    Eastkat808
    Esket
    2012 DCLB 4x4 sr5
    I watched them do it, 13 quarts later she was good to go, changed the filter too
  3. Mar 22, 2021 at 1:16 PM
    #1343
    Eastkat808
    Esket
    2012 DCLB 4x4 sr5
    No this was just a shop a buddy of mine told me about, it’s a bunch of old guys who were all techs at the Toyota dealerships here before they decided to start their own shop
  4. Mar 22, 2021 at 1:54 PM
    #1344
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    I recently replaced mine while doing the 3-4 drain and fill. It was coated with fine metal and, as a new one is only about $25, there is no worry that I didn't get the old one fully clean or knock some crud loose that would now be floating around...
    edit - I'll add that I bought the truck with 188,xxx on the odo and, after the first drain, it was pretty evident that the fluid was OE as it was color of maple syrup!
  5. Mar 22, 2021 at 2:05 PM
    #1345
    Eastkat808
    Esket
    2012 DCLB 4x4 sr5
    Move to Hawaii then you can get the deal
    And what @Doc Samson said it was cheap and why not
  6. Mar 22, 2021 at 4:36 PM
    #1346
    Audi403
    Audi403 Well-Known Member
    2015 Tacoma TRD Sport
    Where did you get the filter for $25? I've called around where I live and it was more like $180 (CAD). Even the cheap ones on eBay are over $100. You have a part number?
    Or are you buying aftermarket?
    Kpatt9 likes this.
  7. Mar 23, 2021 at 1:51 AM
    #1347
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yes, it's cheaper; 3 qts vs 10. And probably not as messy.
    You only mess the tranny if the current ATF is black and has metallic particles in it, indicating the ATF is burnt with clutch material floating in the fluid. You replace this burnt ATF and the tranny will slip.
  8. Mar 23, 2021 at 3:06 AM
    #1348
    Doc Samson
    Almost NoVA
    None... yet.
    Sorry, should've clarified that it was an aftermarket kit (PTC F253 Transmission Filter Kit) through Amazon for 21.00. Both the gasket and filter fit perfectly and no problems since doing it a little over a month ago...
    Audi403[QUOTED] likes this.
  9. Mar 23, 2021 at 9:04 AM
    #1349
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    So just to be clear, you're saying to do a drain and fill and if the fluid isn't fucked, then consider the full flush?
  10. Mar 23, 2021 at 2:27 PM
    #1350
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I’d recommend draining the fluid then dropping the pan to check the condition of the fluid/magnets. By dropping the pan you also are able to get an additional quart or so. After you take a look and conditions look ok, I’d say go ahead with the flush. I believe the resident transmission guru, @gearcruncher, also recommendeds a pan drop before proceeding with a flush.
    steelcity2 and Kpatt9[QUOTED] like this.
  11. Mar 24, 2021 at 8:14 AM
    #1351
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    anyone have a link to the gasket/filter? (2nd gen)
    Going to tackle it myself this weekend. Want to be meticulous, so thank you for answering my deficient questions. :help:
  12. Mar 24, 2021 at 9:22 AM
    #1352
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Thats the easiest part of the job. :D
    Kpatt9[QUOTED] likes this.
  13. Mar 24, 2021 at 9:39 AM
    #1353
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    RockAuto has multiple kits with the filter and gasket for under $25. Or you can go to AutoZone, they might have a kit in stock.
  14. Mar 24, 2021 at 10:40 AM
    #1354
    Micbt25
    TM
    I used this kit, which came with a nice gasket, I don’t really like the cork based gaskets:
    https://www.amazon.com/gp/product/B07M6WH9JR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    However, it looks like it’s out of stock, so I’d go with this one from RockAuto, Wix always makes some good filters, also google search RockAuto coupon code to get a couple bucks off:
    https://www.rockauto.com/en/moreinfo.php?pk=4768797&cc=3310144&jsn=770
  15. Mar 24, 2021 at 11:13 AM
    #1355
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    Try choosing a fluid... Been reading threads for an hour now and even more indecisive than when I started. May just stick with the Toyo WS ATF...... has to be fairly soaked into the clutch etc by now.
    steelcity2 likes this.
  16. Mar 24, 2021 at 11:23 AM
    #1356
    Micbt25
    TM
    I flushed with Valvoline MaxLife over a year ago and I like the results, plus the price is right, $17-18 for 4 quarts at Walmart, it’s what many users on this forum use.
  17. Mar 24, 2021 at 11:36 AM
    #1357
    spitdog
    That’s what I did.... bought it on eBay.
  18. Mar 24, 2021 at 11:37 AM
    #1358
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
  19. Mar 24, 2021 at 12:22 PM
    #1359
    Doc Samson
    Almost NoVA
    None... yet.
    MaxLife +1. 3 drain & fills and zero problems...
  20. Mar 24, 2021 at 1:41 PM
    #1360
    Micbt25
    TM
    Definitely consider MaxLife, IMO I think it’s definitely as good as WS plus for the money you can flush more fluid thru the system and pay a lot less than WS. I did the same exact thing as your doing now, researched everything and this is definitely not the first vehicle’s transmission I’ve flushed. After obsessing about what fluid to use I was confident in going with MaxLife. If I could do it again I’d put a bottle of Lubeguard in it after the flush, which I intend to do next time:
    Lubegard 63010 Platinum Universal ATF Protectant, 10 oz.
    https://www.amazon.com/dp/B002MB57UI/ref=cm_sw_em_r_mt_dp_EP3DTJMDFB1799E6RR17?_encoding=UTF8
    After using MaxLife on my Tacoma, I ended up switching from Nissan NS-2 CVT Fluid for my wife’s 3.5 Altima to Castro synthetic CVT, because I think OEM fluid is a rip off, except I remembered to throw in a bottle of Lubeguard CVT.
    Food for thought, ultimately go with what you’re comfortable with, because the important thing is that you’re servicing the transmission.
