DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Apr 16, 2013 at 7:01 AM
    #121
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    So, with a drain and replaced...basically those first 14 put me back to where I started.
    The only 2 extra were what I put in in the end.
    Is it possible for a truck from factory to be more than 2qts low??
  2. Apr 16, 2013 at 7:13 AM
    #122
    gearcruncher
    Canadain bumper technician
    Yes , sorry , meant to say " check "
  3. Apr 16, 2013 at 7:23 AM
    #123
    gearcruncher
    Yes , the factory could have sent the vehicle out low on transmission fluid but there are other possibilities as well . Could have been something done to your truck at the dealer that required removing a transmission cooline line or rad , trans fluid can drain into the transfer case etc etc .
    Your truck is an 09 . When was the last time you properly checked the trans fluid ?
    Under normal operation , you should check trans level once a month .
    This is why these transmissions need filler tubes with a level indicator . The trans is overlooked because of the difficulty involved to properly check the trans fluid .
  4. Apr 16, 2013 at 7:29 AM
    #124
    93civEJ1
    09 DC TRD OR
    I have never checked it or fooled with it since I bought the truck. It just now hit 66,000 miles. Havent had a reason to check it yet, but now I guess is the time.
  5. Apr 16, 2013 at 7:42 AM
    #125
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I thought that the idea of a sealed system is that it is maintenance free. I don't see to check the Trans fluid on Toyota's scheduled maintenance page.
    30,000 miles is the first I see mention of transmission fluid. Then again at 60,000 miles.
    Source: http://smg.toyotapartsandservice.com/guides.php
  6. Apr 16, 2013 at 8:07 AM
    #126
    gearcruncher
    I wouldnt go more than 2 months without inspecting my transmission fluid level .
    Gotta remember that these transmission can still leak and do leak .
    These are not " sealed transmissions " They are the same as any automatic transmission without the filler tube .
    30 , 60 , and 90 are the recommended service checks to be performed by the dealer . I wouldnt want to drive with my transmission low on fluid for 30,000k . Checking the level every couple of months is your best bet .
  7. Apr 16, 2013 at 8:09 AM
    #127
    Sandman614
    Tim
    '06 SR5 Off Road
    Ever talk to a dealership?
    That's all well and good. Unless it's leaking, which you would notice 2+ quarts in this case, there is no reason to check every month. Really we should check and fill missing when the truck is new/"new to us" and have piece of mind until there is a leak.
    frankiejr likes this.
  8. Apr 16, 2013 at 8:19 AM
    #128
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Damn, I thought I was OCD:cool: I hate these "sealed transmissions" as much as the next DIYer, but a visual check every now and then should be enough to ensure that there are no leaks in the system. Drips in the driveway, and leaks from the transmission itself should be very obvious. No need to check the level every 2 months by getting it into ATF temp mode IMO.
    BTW, the girlfriends 1996 Isuzu Trooper has a "sealed transmission"....
  9. Apr 16, 2013 at 8:24 AM
    #129
    gearcruncher
    In a perfect world I agree 100% .
    As an example ,I have seen 2+ quarts of transmission fluid leak into the transfer case. The driver never knew the leak was there . Then there are those of us who tend to never pay attention to the oil spots on the ground .
    Maybe the lube system only leaks when its running .
  10. Apr 16, 2013 at 8:30 AM
    #130
    gearcruncher
    Ahh yes the dreaded Isuzu 4L30E . I have repaired a few . They are not a sealed transmission. they are like the A750E and have no filler tube .
    Toyota as well as other manufacturers call transmissions " sealed units " when there is no filler tube .
  11. Apr 16, 2013 at 4:00 PM
    #131
    93civEJ1
    09 DC TRD OR
    I put two more quarts in. Im waiting on my trans to cool down enough so I can do the correct temp reading. When I start it and try, the AT Temp just wants to flash saying its too warm to check.....so we wait.
  12. Apr 16, 2013 at 4:45 PM
    #132
    yrffej
    yrffej Active Member
    '05 prerunner trd sport
    if you use this link/source?
    read on to the definitions of "checking the transmission"
    Maintenance Definitions
    2005 Tacoma
    30,000 Miles - 36 Months
    Automatic Transmission Fluid or Manual Transmission OilInspect or replace at specified intervals. When performing inspections, check each component for signs of leakage. If you discover any leakage, have it repaired by a qualified technician immediately.
    seems as though the 30,000 fluid inspection is checking for leaks..... although I don't have the owners manual in front of me... but I also recall 100,00mi interval for checking as you-all are suggesting now... at correct operating temp, with the over-fill drain plug....
  13. Apr 16, 2013 at 5:15 PM
    #133
    Sandman614
    Tim
    '06 SR5 Off Road
    Mines an 06 it must be different for your 05. Kidding.
  14. Apr 16, 2013 at 5:31 PM
    #134
    93civEJ1
    09 DC TRD OR
    so, the 2 extra quarts did it...kinda confused though. This time i came pouring out the check plug...almost the two quarts I put in..haha...i let it drain til it was a drip out the check plug. Should be good to go on my change now. Runnin Valvoline Maxlife.
  15. Apr 29, 2013 at 6:34 PM
    #135
    pavemobile
    pavemobile Well-Known Member
    Wichita Falls, Texas
    2009 TRD Sport SR5 PreRunner
    K&N Intake
    My sincere thanks for taking the time to put this together. I did mine this past Saturday, went through 14 1/2 out of 15 qts. of Toyota WS. Changed filter out and put more magnets in the pan. There was a coating of dark grey clutch film on everything in the pan. Used the rest in the power steering. I am waiting for some pics to upload on photobucket and then I will post them here.
    My tranny was about 1/2 - 3/4 qt low from the factory. 40,491 miles on the factory fill and I wish I would have done this at 24K. I don't drive that hard but my fluid looked like iced tea, I did an old vs. new color comparison just like the OP. I will let pic's speak for themselves. If you found this how to, don't wait, do your tranny now, I like the way mine shifts now, feels like a much more confident shift. I plan to do an annual drain and refill now to keep things fresh.
    PzTank likes this.
  16. Apr 29, 2013 at 6:58 PM
    #136
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    Hmm...
    I didn't drain mine till almost 100K, the fluid color wasn't all that different, and I can't tell a difference in shifting (it's always kinda banged the 1-2 shift).
  17. Apr 30, 2013 at 5:07 AM
    #137
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Did you have to replace the pan gasket or place a thin film of RTV on the pan's lip to seal it up? Any leaks?
    Well done, BTW!
  18. Apr 30, 2013 at 5:25 AM
    #138
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Wait a minute, unless I am reading this wrong, you drained and refilled 3 times, right? And was this all at the same time, or how much time elapsed in between said drain/refills? If you just kept doing it over and over, then didn't you only change what's in the pan 3 times? And waste a lot of new ATF in the process?
  19. Apr 30, 2013 at 7:46 AM
    #139
    pavemobile
    K&N Intake
    Thanks, it looked better internally in some ways and worse in others once I got it opened up. I used a new OEM pan gasket (Fel-Pro gasket looks identical, have one for the below 4Runner project) with no sealer and followed the service manual torque spec's for everything. Pan bolts are 39 INCH POUNDS...there are 20 and I did them in 2 stages, 25 then 39 in/lbs. I started in the middle and went clockwise and made I think 3 rounds to stabilize the torque before the next step to 39 in/lbs and made 4 rounds at 39 just to make sure. Probably overkill but WTH. No leaks, and I check every morning and evening. That picture of shavings is from inside the factory filter, I uncrimped the edges to get a look inside...curiosity and all. Not nearly the metal we used to find in the older GM tranny's - T350, 400, and 200-4R O/D in particular. I wanted to keep this truck a while so this was the last 36K checkup action to perform. I ordered the high heat neodynium magnets from KJ Magnetics, maybe spent 40 bucks or so.
    I'm going to help my future son-in-law with his 4Runner pretty soon, he doesn't have the courage to do this on his own, or maybe it's the free labor, food & adult refreshments! Anyway, thanks for everyone's efforts in putting this together. I didn't have any issues with anything while in process.
  20. Apr 30, 2013 at 7:47 AM
    #140
    Sandman614
    Tim
    '06 SR5 Off Road
    you read it wrong. The drain process is not from the pan, draining is done at the return line. Effectively the new fluid is pushing out the old fluid, although yes some of the new fluid is wasted.
