DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Sep 11, 2013 at 11:43 AM
    #161
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Two years with Amsoil ATF DIY and no problems at all. I've been very pleased.
  2. Sep 11, 2013 at 12:48 PM
    #162
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    How about a report from the guys using Valvoline Maxlife WS?
  3. Sep 17, 2013 at 6:11 PM
    #163
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    My package just arrived so hopefully I'll do it next free weekend.
    I called my dealer out of curiosity- they charge $220 for a drain/fill and don't offer a full flush service. Are you sure yours was a full flush?
  4. Sep 17, 2013 at 6:18 PM
    #164
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Not positive, but pretty sure...:rolleyes:
  5. Sep 17, 2013 at 6:19 PM
    #165
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Have to check the invoice when I get a chance
  6. Sep 20, 2013 at 6:21 PM
    #166
    coreypso
    coreypso Member
    2007 PreRunner
    Thanks mountain lion, great write up. Once i got under the truck everything went great. Also fortech had a nice write up as well. Both of you guys saved me alot of time and some $$$.I really appreciate the time you guys took to help us out here. Thanks again guys!
  7. Sep 29, 2013 at 3:46 PM
    #167
    grivera
    Hanover, MD
    I flushed mine this afternoon using the above method for adding the new fluid. Everything went great. Thanks Mountain Lion, Fortech and acrossawire!
  8. Oct 7, 2013 at 8:13 AM
    #168
    Byrdmen
    Byrdmen Member
    Scott
    Houston
    2020 TRD OffRoad DC 4x4
    none
    Flushed mine last week, went fairly well. Thanks again for the pictures and tech data included in the first post, big help.
    I installed a OEM Trans cooler in series with my radiator cooler before I started, I let the flushed fluid flush out the cooler.
    Draining and refilling were easy enough, I ran into trouble getting into "temp mode" to check the level. I also had trouble filling the damn thing at all with a funnel and length of hose. Got it close and let the dealer set the fluid level.
    While I was under the car I noticed a drip from the rear of the transmission. Having a Gulf States Toyota extended warranty I called the dealer for an appointment to check it out (and set the ATF level). They called me back with a transmission leak, timing cover leak, and a power steering rack leak all for around $2,500!!
    Took Fred Haas two days and $400 out of my pocket for a new water pump (parts only), new fluids, and alignment. Finally got my money out of that extended warranty!
    mrlee likes this.
  9. Oct 7, 2013 at 8:28 AM
    #169
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Just a thought... instead of stopping/ starting you could have another container full of new fluid pumping into the other line as drains through the 1st. Just keep adding oil until fresh-ish stuff comes out. Anyone tried it like this?
  10. Oct 7, 2013 at 8:31 AM
    #170
    Sandman614
    Tim
    '06 SR5 Off Road
    I think this has been covered. If I recall there is a reason it can't be done, not a pressure line or location of the pump?
  11. Oct 16, 2013 at 10:15 AM
    #171
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I figure it may be push only via the pump... and may not pull into the trans. Kinda redundant
  12. Nov 25, 2013 at 7:55 AM
    #172
    TwentyAte
    TwentyAte Active Member
    Garrett
    San Jose, CA - Fremont, CA
    Great write up! This saved me a lot of time. I also went with Amsoil ATF. My truck is driving noticeably better/smoother.
    Thanks again!
    Garrett
  13. Nov 25, 2013 at 11:45 AM
    #173
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    Did mine over a year ago; transmission shifts perfectly under all temperatures and conditions.
    Used Toyota WS fluid.
  14. Dec 16, 2013 at 12:51 PM
    #174
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    I just grabbed a case of 12-1 quart bottles of Toyota WS on eBay for $80 shipped and want to do this soon. Should I be worried about trying to do this in the winter months? It's supposed to be a little warmer than 40 deg F this Saturday, which is when i want to do it...
    Also, I'm at 101k and the trans fluid has never been touched. I've seen some people say that it's not good to do a full flush and fill at this high a mileage. Recommendations? I could do a drain/fill now (~3 qts) then do it again once/month for the next few months?
  15. Dec 16, 2013 at 1:49 PM
    #175
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  16. Dec 16, 2013 at 6:36 PM
    #176
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Did a drain/fill on mine a year ago at 115k. Drained out ~2.5 qt. Put in ~3.5 qt.
    I plan to do another this month maybe which will be around 135k miles.
    I'm thinking a few qt worth of fresh fluid mixed in is good enough. And a simple gravity drain like that shouldn't dislodge any chunks big enough to cause problems the way a true forced "flush" might.
  17. Dec 16, 2013 at 8:25 PM
    #177
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    40 degree should not be a problem but if it was me I'd wait till warmer days just because I don't like working in the freezing cold.
    That's a great price for Toyota WS.
    I did a total flush at about 100k. Works perfect. Don't listen to the ignorant people. Fresh ATF is always better than old no matter how many miles you have on.
  18. Dec 16, 2013 at 8:34 PM
    #178
    jlleiber
    Justin
    Indiana
    How'd your guys' ATF look/smell at 100+k? Definitely make you glad you changed it?
    I'm leaning toward the drain/fill since its slightly less involved and I'm not terribly comfortable with tranny fluid yet so it'd be a good entry to it. I guess the drain/fill is basically the first part of a flush, so I could check the fluid and determine then whether to continue with the full flush?
  19. Dec 16, 2013 at 9:46 PM
    #179
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I didn't think mine seemed dark.
    I'd say start with basic drain/fill and if you think the fluid looks too dark, keep going. If it looks ok, leave it at that.
  20. Jan 1, 2014 at 12:02 PM
    #180
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    My dealer only does drain and fill, 4 qts @ almost $200.
