DIY Headgasket advice for '02 5VZ-FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grousin, Sep 21, 2022.
  1. Sep 21, 2022 at 8:20 AM
    Grousin
    Grousin [OP] Member
    2002 4x4 Doublecab
    Cylinder 4 is failing compression test, I'm loosing a bit of coolant and the oil cap is milky. A rough idle on startup spurred the check. Adding oil to the cylinder only gave me [edit] an extra [/edit] 10psi. It seems all signs lead to head gasket. Just over 250k on the truck
    I've made it in far enough to replace the valve cover gaskets two years ago but no further. This will be my first go at a head gasket. Any thoughts, tips, warnings, advice? Things to look for when it's apart?
    What else should I replace while I'm there? I'm buying the full gasket kit from Toyota. The timing belt only has 40k on it. Is it still worth replacing? Water pump? I've read the headbolts should be replaced, but I didn't see that indicate in the service manual.
  2. Sep 21, 2022 at 8:35 AM
    5efvz
    5efvz Well-Known Member
  3. Sep 21, 2022 at 8:50 AM
    Grousin
    Grousin [OP] Member
    2002 4x4 Doublecab
    Thanks. I've seen the Timmy videos and worsethanchiggers but I hadn't come across this one.
  4. Sep 21, 2022 at 8:54 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Yes do water pump and Knock sensor.(maybe injectors) It might help to get a service manual I found a free one online. This video series helped me a lot he is pretty detailed and has a few tricks to take the pulleys off a little easier. https://youtu.be/voLBRDZL9fE
    don’t forget to put the bolt in the cam before removing. And the timing belt skips around every revolution shit had me confused for hours.
    Grousin[OP] likes this.
  5. Sep 21, 2022 at 9:01 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I almost wonder if you don't have two issues; definitely sounds like your head gasket has gone south, but having virtually zero compression makes me wonder if there isn't another issue as well. Specifically, rings and/or valves which is causing the low compression.
    Smokestacks likes this.
  6. Sep 21, 2022 at 9:12 AM
    Grousin
    Grousin [OP] Member
    2002 4x4 Doublecab
    Sorry, I should have been more clear on the failed test. I've got 190+ on the other cylinders. Cylinder 4 is at 150, ~160 after adding a bit of oil.
    1997tacomav6 likes this.
  7. Sep 21, 2022 at 9:34 AM
    tirediron
    Ahhh... got'cha'. Okay, that makes sense.
  8. Sep 21, 2022 at 10:07 AM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    Remember, when removing the exhaust cam, make sure the service bolt is in-place before removal. Otherwise, you'll launch a cam across your garage...
  9. Sep 21, 2022 at 10:31 AM
    Itsgottabeyourbull
    Itsgottabeyourbull Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
  10. Sep 21, 2022 at 11:43 AM
    Grousin
    Grousin [OP] Member
    2002 4x4 Doublecab
    :eek: Sounds like there's a story there. Oof. I'll be sure to double check that box when I get there.
  11. Sep 21, 2022 at 11:43 AM
    Grousin
    Grousin [OP] Member
    2002 4x4 Doublecab
    Thanks!
  12. Sep 21, 2022 at 12:20 PM
    garetcurry
    garetcurry Well-Known Member
    Indeed, this seems like a head gasket issue.
    Over time the camshaft lobes wear down the shims over the valve buckets. This puts valve lash out of spec and can affect compression. Just something to be mindful of if you're going to go through the trouble of digging into your head. Shims can be bought from the dealership or online and come in sizes incrementing by 0.05mm or ~0.002".
    Don't forget the Allen head bolt after the eight "regular" head bolts come out. It's torque spec is also less than the regular head bolts.
    I have a 0.040" MLS cometic head gasket if you want it.
  13. Sep 21, 2022 at 12:54 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    The above is very important. Also get the head checked over by a good machine shop. Mine had a small crack when I took it in for inspection.
  14. Sep 21, 2022 at 3:57 PM
    Grousin
    Grousin [OP] Member
    2002 4x4 Doublecab
    A big thanks for the gasket offer. Unfortunately I already ordered the OEM kit.
    Good call on the valves. I hadn't given them much thought, but last time I checked a couple were barely within spec and I let them go.
  15. Sep 21, 2022 at 4:00 PM
    Grousin
    Grousin [OP] Member
    2002 4x4 Doublecab
    hmm. I was hoping to avoid the machine shop as long as things looked flat and copasetic. Admittedly a bit of a pipe dream, but it's a couple hours drive to the headshop. Was the crack visible at all before you took it in? It sounds like I may have to rethink that one. o_O
  16. Sep 21, 2022 at 4:06 PM
    Bishop84
    Bishop84 Well-Known Member
    You don't have to machine it, but its best practice to do so.
    My tips are, clean flush, but not mirror finish. Basically if its clean you wont be able to feel the old material with a finger nail. Resist the urge to clean it until it shines.
    Blow out the head bolt holes, they can trap fluid and hydrolock when reinstalling.
    Replace Valve seals while the head is off. Old toyotas are known for them leaking slowly, and its way easier with the head off. This also lets you inspect the valves and clean them off gently.
    Take pictures. Sort stuff out carefully.
    The exhaust is the hardest part depending on how rusty it is. I typically leave the manifolds on the heads and remove the pipes from the manifolds.
  17. Sep 22, 2022 at 7:18 AM
    tirediron
    As long as you have a good machinist's rule, you can check the head for true easily enough, but if you're going to all this trouble, I would go the extra mile and get the head pressure-tested and magnafluxed. It would suck balls to get it all back together and find out you had a crack between passages or something like that. Chances are, you're fine, but that's a LOT of time, effort and money on a chance.... YMMV.
  18. Sep 22, 2022 at 8:22 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    sub'd for outcome, GL OP
    Kwikvette likes this.
  19. Sep 22, 2022 at 5:12 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    It's worth a trip to the machine shop. My crack was not visible, they saved me from doing the job twice.
    It was around 3-500 I don't remember. I know they fixed the crack and cut the head a little with my permission. It runs fantastic on 91, and adequate on 87. I also have a long tube header, high flow cat and straight shot intake.
  20. Sep 22, 2022 at 8:34 PM
    Smokestacks
    BayArea
    I also had a crack they tend to happen between valves I didn’t need a shop to point it out. But my gasket also was fine
