DIY hood strut - possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TacoRidah, Jul 5, 2012.
  1. Jul 5, 2012 at 10:11 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    Went to my friends house yesterday and found some rear window struts that go to an S10 Blazer rear window. lucked out cause they are BRAND NEW (except for just missing the top locking clips - hoping I am able to find some replacements to make this work)!!!! Tested them on my hood (used only one) and it holds up fine. They aren't as long as the RedLine ones but imo should do :)confused:).
    Anyone know where to get some strut ball pins/brackets? I Googled it and found some nice ones that look similar to the RedLine brackets, but they were about $6 ea. plus shipping, can't find them anymore.
    Ref image (the ones on eBay looked like these)
    http://media.photobucket.com/image/recent/freedomxj/Hood%20Lift%20Install/DSC_0005.jpg
  2. Jul 5, 2012 at 12:48 PM
    07TacoRidah
    .. anyone?
  3. Jul 5, 2012 at 12:54 PM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    try red line and see if you cant buy those directly
  4. Jul 5, 2012 at 7:15 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
  5. Jul 5, 2012 at 7:17 PM
    07TacoRidah
    this is what the ends look like on the struts that I have.
  6. Jul 5, 2012 at 7:36 PM
    07TacoRidah
    just realized, I don't really know the "mm" of these things. :( going to try and see if the parts are laying around anywhere at my friends, last resort ... ask someone at a Autozone or something.
  7. Jul 6, 2012 at 11:01 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Do you have a Napa or similar around you? Here, you can call Napa and give them the closed length, the extended length & the weight it will support and they can struts rather inexpensively. I've been thinking the same thing but just haven't had an opportunity to start work on this. I was hoping to get someone with the Redline kit to take a few measurements and it shouldn't be terribly difficult to put your own kit together. Last time I bought struts for a hood they cost me ~$20 for a pair to give you an idea. That was many years ago though and I know they've probably doubled in price by now but that's still a far cry less than a kit if you can get measurements.
    Mmaira2018 likes this.
  8. Jul 7, 2012 at 8:14 PM
    07TacoRidah
    NICE, there's one around my place, I'm going to bring them the part to make sure too.
    on another good note
    Parts
    http://www.redlinetuning.com/QL-parts.html
    Bracket Kit
    http://www.redlinetuning.com/QL-HBRACKET-KIT.html
  9. Jan 27, 2022 at 7:04 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    DIY hood struts!
    Super happy how they turned out. I initially installed 100 lbs struts but they are way too overkill. I am replacing them with 40 lbs ones right away. Hopefully they are much better.
    Here are the parts:
    20" struts
    10mm ball stud mounting brackets
    You could use a little longer strut if you want the hood to open higher. I wasn't interested in this because my ditch lights are close to hitting the windshield with the hood prop rod.
    These are installed just like Spiker.
    The driver side strut does have minor contact the fuse for my subs but I'm not worried about that.
    The strut also slightly touches the brake fluid reservoir when lowering. Also not worried about that.
    hoffengineering and Area51Runner like this.
  10. Feb 17, 2022 at 8:02 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    For anyone interested in using parts-store stuff, '01-06 Acura MDX hood struts are pretty dead-on. I actually ended up finding them by backing my way into them by open/closed/weight specs from what Redline uses. I specifically used Stabilus 4B-092294.
    Napa 735-1898 & -1899 work for brackets, but other than local availability they're not really cheaper or better than other ones you can online.
    FYI, try flipping your struts @dpele, they're supposed to be the other way around, and they should clear a bit better closed with the rod instead of the body towards the front! And thanks for your post, I stumbled on it a couple weeks ago & it inspired me to try something I've been wanting to do but was too cheap to spend $100 on a kit for.
    dpele likes this.
  11. Feb 17, 2022 at 8:41 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Tween the struts and the tower I'm figuring you really know how to get it up.
    ETA: I'll scope y'alls only fans, but if mine has more subscribers I'm roasting you.
  12. Feb 17, 2022 at 9:15 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Try gasspringsshop.com they have nice stuff in SS and lots of connectors.
  13. Feb 18, 2022 at 8:28 AM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    I read 31lbs weight for the struts. I don' think that will be enough.
    I installed 40s because the 100s were way too much. 40s barely held my hood up and I had to lift it myself. I ended up going 80s at the end but I think 60s could work...
    Edit:
    I installed the struts in the same orientation Redline and Spiker have on their instructions. I don't thing flipping them will help with my clearance. Thanks though!
  14. Feb 18, 2022 at 8:31 AM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    How about the 10 ton crane?
  15. Feb 18, 2022 at 9:24 AM
    Taco 422
    USA
    You're into suspension but don't know shibari. There's shortcuts to everything.
    Or you'll leave us hanging like an episode of Miami Vice.
  16. Feb 18, 2022 at 9:26 AM
    Taco 422
    USA
    If you don't need all that LDF-4 I could "rehome it" to a mountaintop near me.
    dpele likes this.
