DIY HOW TO: LED Strip Bed Lights
Discussion in 'Lighting' started by Drunknsloth, Apr 29, 2011.
  1. Sep 12, 2011 at 8:48 AM
    #41
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  2. Sep 22, 2011 at 2:54 PM
    #42
    Drunknsloth
    Retribution
    South West
  3. Oct 14, 2011 at 10:22 AM
    #43
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    you still have all the stuff for these? I'm gonna wanna order in a little bit.
  4. Oct 22, 2011 at 11:33 PM
    #44
    blackphantom09
    blackphantom09 Newbie
    V.B., VA
    09 Double Cab TRD-Off Road SB
    TRD Exhaust, Black badges, Jason Rage tonneau bed cover, TRD S/C, OEM roof rack, Avid Light Bar
    subbed for future use.
    If I wanted to put the switch inside the cab instead of in the bed, could I just extend the 12v wires into the cab and run another wire from the switch to an aftermarket fuse box? Also what size bolts did you use for the aftermarket fuse box mount to the fender? Thanks.
  5. Oct 23, 2011 at 3:50 PM
    #45
    Drunknsloth
    Retribution
    South West
    Sorry I guess I missed your post when I was going over my subscriptions. Yep I still have everything :D
    Yes the switch can be put inside the cab in that way. I am not sure what bolts I used but I know that it is exactly the same as the ones that bolt the horns on in front of the radiator. So you can go to a local hardware store, unbolt the horn bolt there and just take it in to match it
  6. Oct 23, 2011 at 3:57 PM
    #46
    blackphantom09
    V.B., VA
    Thanks! I'll be in touch soon.
  7. Oct 23, 2011 at 3:58 PM
    #47
    Drunknsloth
    Retribution
    South West
    Anytime man!
  8. Nov 3, 2011 at 1:35 AM
    #48
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    definitely interested. don't have my truck anymore, but plan on getting another within the next 10 months or so. interested in the rigid version, cool white. probably 2-10" for under the hood and 2 sets of 2-10" for each side of the bed. i'll be in touch most likely after the new year.
  9. Nov 3, 2011 at 6:56 AM
    #49
    2012
    2012 Well-Known Member
    Garrett
    Colorado
    2012 TRD off road
    just for everyone's information, you can also use a piece of bailing wire to lead a through the rubber wiring boot that goes through the fire wall under the dash. just electrical tape the wire to the bailing wire and poke it through, the rubber boot seals around the wire so it's water-tight, and you don't have to take anything apart, literally takes less than 30 seconds.
    nice work by the way. i was just thinking about doing this yesterday. i put some in the engine bay instead. next week.
  10. Nov 3, 2011 at 8:25 AM
    #50
    doodooboi
    doodooboi Well-Known Member
    Phoenix AZ
    09' TRD DCSB Sport/Prerunner
  11. Nov 3, 2011 at 10:49 AM
    #51
    Drunknsloth
    Retribution
    South West
    Sounds good!
    Cool, hit me up if you need any more
  12. Nov 5, 2011 at 8:09 AM
    #52
    SARCOtheINFIDEL
    SARCOtheINFIDEL Member
    Chicago
    03 SR5 4x4
    Nice! Great looking mod!
  13. Nov 6, 2011 at 1:21 PM
    #53
    Drunknsloth
    Retribution
    South West
    Thanks man! Welcome to the forum!
  14. Jan 5, 2012 at 10:55 PM
    #54
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    So this may be a stupid question, but electrical work is hit and miss for me sometimes. As long as all the lights were connected using the bar to bar connectors, wouldn't you only need to use one 12v/ground connector, ideally next to the switch? It would essentially be wiring them in series would it not? Versus 4 and 2 in parallel, sort of? (or in my case using only 4 lights, 2 and 2) Here is how I see it in my head, so that might help clear things up
    4 light setup, 2 on each side of bed: 12v---light--1'--light--5'--light--1'--light.
    6 Light OP setup: 12v---light--1'--light--5'--light--1'--light--5'--light--1'--light.
    Either way wire the 12v to the power on the switch and the ground to the chasis.
    The center 5' bar to bar connector in the 4 light may need to be longer but you get the idea...
  15. Jan 6, 2012 at 7:58 PM
    #55
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Anyone...?
  16. Jan 7, 2012 at 7:51 PM
    #56
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Why not just remove the factory electrical tape and run the wire through the boot like all the other wires, I did this when running the wires for my backup sensors and plan to do the same here, no chaffing, no issues, just replace the electrical tape with new tape and put it back together, much easier. It can be a little bit of a pain getting the wire through the boot, but it is clean.
  17. Jan 7, 2012 at 8:18 PM
    #57
    goufcustom
    MD
    What fuse in the dash fuse box did you connect to? I want to wire mine up with the switch in the bed, so that I can turn the lights on when the truck is off or on.
    Plan was to use add a fuse and run a wire back to the tails where the switch will be. Ground everything back there with the LEDs.
  18. Jan 8, 2012 at 12:04 AM
    #58
    Drunknsloth
    Retribution
    South West
    I didn't want to bother with the seal of the tape. Re-taping it usually makes it not stick as well.
    I actually used an aftermarket fuse box, but I'm sure you can find one that is always hot, maybe the dome light fuse
  19. Jan 8, 2012 at 12:05 AM
    #59
    Drunknsloth
    Retribution
    South West
    Sorry, I've been super busy with three jobs and school. But yes that would work, I don't quite remember why I didn't do that but I was missing a piece or something ;)
  20. Jul 6, 2012 at 12:11 AM
    #60
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    What about the open end on the last light? Did you just fill it with silicon? Or are there plugs available...
