DIY Laser Cut Bed Stiffeners - Hand Bendable (...but requires welding)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ekliptiko, Aug 2, 2020.
  1. Aug 2, 2020 at 12:24 AM
    ekliptiko
    ekliptiko [OP] Well-Known Member
    Portland, OR
    I know there are plenty of bed stiffeners out there - but I hadnt seen any that were laser cut, hand bend-able, with files, free and open for everyone. So...I went ahead and made my own and I wanted to share the design with you guys.
    These are designed to be laser cut from 3/16". I am sure they could be cut on a plasma table, too, but I have not tried let alone verified. They are designed to maintain precision even though they are bend-able with an adjustable wrench. This is achieved by a relief cut along the bends; leaving only 2 thin tabs per bend. After bending, re-welding the back of the bends strengthens the stiffener back to similar strength of a press brake formed design. I ordered them from sendcutsend.com and selected their hot rolled P&O steel in 0.188" thickness. In late July 2020, they cost me $83.18 for a pair shipped.
    These fit my 2015 Tacoma Short Bed. That is the only vehicle I have tested them on and can verify it fits on my vehicle. I believe the bed is the same across all lengths even including 3rd gen, but I am unable to verify at this time.
    Cut files are attached here. Provide your laser cutter with the attached DXF and PDF file.
    They can be bent with just an adjustable wrench, square and some elbow grease. Position the adjustable wrench near where the little tabs are.
    Note: the above image was taken on an old revision with multiple tabs on the long bend. Current revision only has 2: one at each end.
    I recommend starting with the long, vertical section bend first. Bend a little on each tab with the adjustable wrench. Go back and forth bending each a little at a time until you get to 90 deg. The shorter, horizontal, bend can be bent in one go - it appears to be short enough to bend without going back and forth between the two bend tabs.
    Adjust your bends until you are satisfied that everything is square. Weld up the back of the bends in the crook left by the relief cuts.
    DON'T FORGET TO BEND A LEFT SIDE AND RIGHT SIDE - THEY ARE OPPOSITES. Don't ask me how I know.
    You decide how much of the bend length to weld. No recommendation provided.
    DXF, and sldprt file attached
    If anyone uses these models but makes improvements or changes, please post them here! Got a cool idea, but dont have the capability to modify the design? Post your idea - I might be able to incorporate your idea!
    Lastly, I have released these into the internet. The design is free for everyone. Feel free to take it, make a pair for yourself, modify it, improve it, make it yours. Maybe you have a plasma cutter and a welder and some time - feel free to make them to sell.
    My only condition for anyone to sell these for profit is that you give me credit and provide a link back to this post in your online store's product page for these.
    There's many more designs to come, guys! Im just getting started.
    Juisebocks, Torspd, jahulgan and 11 others like this.
  2. Aug 2, 2020 at 5:57 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Nice work making your own!
  3. Aug 2, 2020 at 6:25 AM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    For the time and money to get a similar product, you can buy a set already bent, welded, and powder coated, with hardware.
    I dont see the advantage to this.
    Wixo likes this.
  4. Aug 2, 2020 at 6:37 AM
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    Many people like making their own and perhaps can benefit from a well thought out design like this.
    paranoid56 likes this.
  5. Aug 2, 2020 at 7:04 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    With that said, you could also argue for the time and money spent on an oil change, you could just go down to Jiffy Lube. Everyone has their own level of justification and learning. Having something YOU built will always be cooler than something you bought.
    I guess the people who don't see an advantage to creating or working on things themselves just don't get it. Which is fine. Really. It's not everyone's "thing". But those people who do, will always have a better understanding of how things work, how to make something work, fix things when they break and improve upon things. And by the looks of his post, I can guarantee you that this guy will always have a job and have work.
    A good quote thats loosely applicable here and that I always remembered was....Those who try and fail are infinitely better than those that do nothing and succeed.
  6. Aug 2, 2020 at 9:23 AM
    ekliptiko
    Portland, OR
    Oh, I bought 4 iterations to get it right. So if we're talking cost here I could have bought probably 3 pairs of fully bent and welded brackets by now and mine still aren't painted and I don't have all the hardware, LOL.
    So... I failed 3x times before I got it right.
    Proto #1 - There were too many bend tabs on the long edge. My thought was to leave as much of the original material intact as possible by maximizing the bend tabs. Additionally, there was an outside chamfer at the top of the bracket. This caused the top bend tab to nearly break off in bending. Might have been fine after welding, but I didnt like it.
    Having multiple bend tabs and trying to make the bend by hand w/ adjustable wrench resulted in an out-of-plane bend making the bracket not square.
    Lastly, it was made out of 1/8". I had done some back envelope calculations and found that 1/8 would be sufficient for the force inputs I used to calculate. I didnt like that. They simply didnt LOOK strong enough.
    Proto #2 - Corrected some hole locations. Construction tape measure is only so accurate, lol. ±1/16" Made the long bend with only 2 bend tabs - one at either end. This relieved the strain along the length of the bend and helped to ensure that the bend stayed in plane to yield a square bracket. I also adjusted the outer profile of the upper most outer cut to help reduce weird bending stresses that occurred with the first proto.
    Proto #3 - the hole to receive the outer most bed bolt (the one with the D-ring) was still out of place. I also witnessed some variance in this hole position between L & R sides.
    Proto #4 - Current. I adjusted the position of the outer most bolt location and also slotted it to accommodate not only the L/R variance I saw on my truck, but hopefully to accommodate a wide(r) range of tolerances from the factory.
  7. Aug 2, 2020 at 9:24 AM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Nice work. Wish I knew how to weld :bananadead:
  8. Aug 2, 2020 at 9:35 AM
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Nice job like the design (tie down holes)
  9. Aug 2, 2020 at 9:53 AM
    ekliptiko
    Portland, OR
    Craigslist services section has many welders looking for work. And they'll come to you!
  10. Aug 2, 2020 at 11:47 AM
    ekliptiko
    Portland, OR
    Because the mods decided that the OP doesn't get a chance to respond to this, let's try it again.
    The advantage is that I have designed and released the complete design free and for anyone to use, modify or improve upon. I will even allow commercial use of the majority of my designs with the one condition that I receive credit for the design and this post is linked on any and all online store product pages for my designs. In my mind, I just opened up the market for competition.
    Yes, by the time I or anyone receive a single pair, bend them, Weld them, paint them and buy hardware, it is nearly the cost of a pair from one of many great vendors. In fact, I actually bought 4x sets each with iteration changes to get to the working design I have shown. I greatly enjoy the design process and feel far more proud about the parts I designed as opposed to purchased.
    Cali raised and victory 4x4 come to mind and offer basically equivalent products for ~$110.
    If you are not seeking to fabricate your own for whatever reason, please go purchase a pair from one of the great vendors here on the forum.
    Please feel free to contribute to the design. If you have any ideas for improvements that you feel would provide a better value than the existing commercial options, I would love to hear about it and I can try to incorporate it into a new revision.
  11. Oct 15, 2020 at 7:57 AM
    Porroquio
    Porroquio IG: @porroquio
    Miami, FL
    2016 Magnetic Gray Tacoma SR5
    this is so nice!!! thank you very much for the contribution!
    I have a noob question, is it really necessary to drill and bolt to the bed in order to fix the stiffeners?
    I was wondering if it would be possible to use only the stock bolts from the base frame, D-ring, and upper side to fix a stifferner design like the one from Total Chaos, without significantly compromising strength.
  12. Oct 15, 2020 at 9:04 AM
    ekliptiko
    Portland, OR
    I wouldnt do that. Your intuition on the problem is correct; the highest bolt is providing the most strength due to it providing the longest lever arm. However, The sheet metal channel at the rear of the bed is not thick and may fail if all of the load is concentrated in one point. Thin sheet metal structures can be strong when designed and implemented well and additional load, such as these bed stiffeners, are distributed.
    Another way to think about it: the stiffener bracket can be the stiffest thing in the world; but if it is bolted to something weak, the 'system' of the bracket bolted in place is only as strong as what it is bolted to.
    Torspd and Porroquio[QUOTED] like this.
  13. Oct 15, 2020 at 9:13 AM
    Porroquio
    Miami, FL
    Thank you very much!
  14. Oct 15, 2020 at 11:08 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Love this idea! I do wish the pricing through sendcutsend was a little lower - but I get they probably have quite a bit of overhead and startup costs to overcome.
    Besides the relatively high cost of these bed stiffeners and the fact that I don't need, need them (yet) I haven't bought a set of these yet mainly because I regularly haul dirt, sand or gravel and stiffeners are only going to get in the way of unloading these materials. It'd be nice to have design that tries to reduce that issue as much as possible. Possibly by keeping the corner open so you can sweep debris through the bracket rather than around it.
  15. Oct 15, 2020 at 11:12 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    I know right? I bought some for like $80 bucks that came PC'd and with all the hardware. I can see it making sense if someone has a cutter and some extra metal from a previous job laying around tho.
  16. Dec 8, 2020 at 7:29 AM
    jahulgan
    jahulgan There and Back...
    James
    Central Georgia
    '09 SBDC Green TRD Off-Road 4x4
    Old Man Emu 886 Springs, 255-85-16, ARB Front Bumper w/ Warn 8K Winch, SOS Sliders, Custom Skid Plates
    I got inspired last week by this thread and had some 3/16" x 2" angle and flat bar around the house. Here is what I came up with. Thank you for your design work!!!
    PXL_20201130_005511823.jpg PXL_20201130_012732776.jpg PXL_20201130_015608738.jpg PXL_20201130_021639109.jpg PXL_20201201_021156361.jpg PXL_20201201_021203801.jpg PXL_20201208_151057675.MP.jpg PXL_20201208_151100711.MP.jpg PXL_20201208_151108841.jpg PXL_20201208_151128047.MP.jpg
  17. Dec 8, 2020 at 2:16 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
  18. Dec 8, 2020 at 8:20 PM
    Waasheem
    Waasheem
    2007 xrunner
    "Some people make things happen. Some people watch things happen. Some people wonder what the fuc* just happened. I don't want to be the third guy". Phil Harris, RIP.
