DIY LCA Ball Joint Replacement 2005+ Tacoma
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Jan 10, 2013 at 1:06 PM
    #41
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Almost 60k
    It's sitting next to my camping gear for the next time I see you :D
    And I just got back to the shop so I went to look at the truck.. Found some movement in my uca uniball on the driver side so that must be what I've been hearing. How hard was it to replace your tc uniballs? You don't have a write up for that too do you lol
  2. May 30, 2013 at 7:09 PM
    #42
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Well this looks difficult. And to think..I thought it was a simple 'pop off old BJ, pop on new BJ, DONE!' job.
  3. Jun 8, 2013 at 1:02 PM
    #43
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    It's not that bad of a job once all the other components are off and you have the basic tools required.
    The press couplers are pretty much the most costly tool required that I had to purchase. They will also work on aftermarket UCA uniballs and the LCA bushings + a ton of other vehicles so that's a sound $60 investment IMO. They paid for themselves the first time I used them.
  4. Jun 8, 2013 at 1:19 PM
    #44
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    You ever get it done? My passenger side is nearing death.
  5. Jan 28, 2014 at 8:07 PM
    #45
    rmawhinney
    rmawhinney Member
    Maine
    05 TRD Off Road
    hey guys I know this is an older thread but i have been trying to get this done and I am having a real bear getting the steering stop off. Any suggestions? I tried what you put in your post first....then I tried prying a lot. I don't want to beat on the stop for obvious reasons but i am running out of ideas here. It seems to me that this shouldn't be a big problem. I can't figure out why they are not coming off. Any help would be great. thanks guys!
  6. Jan 28, 2014 at 8:14 PM
    #46
    XXXX
    sKiP
    05 Prius
    You can smack the crap out of it. I was wrong. It shouldn't hurt anything.
  7. Apr 17, 2014 at 2:46 PM
    #47
    JLink
    Josh
    Ocean, NJ
    Gonna replace the LBJ's soon
  8. Jul 7, 2014 at 12:38 PM
    #48
    JLink
    Josh
    Ocean, NJ
    done.
    should've reviewed the write up before attempting. I didn't have the right adapters so I ended up cutting one to allow it to open up more for removing the old one, and then I had to cut and squeeze one together tighter and weld it back together and then cut it in half for the top cup for installing the new one.
    the UCA uniballs ended up being a bigger pain in the ass though.
    ended up using the top misalignment spacer in the old uniball (after removing c clip) and bashing the shit out of it with a 3lb sledge hammer until it popped out. then installing the new uniball really sucked. tried the ball joint press, tried a vise, spent hours and couldn't get it to seat evenly. finally i froze them overnight and greased them up, set it on the UCA with the UCA upside down on a wood block, set a BJ press tube and cap over it, and bashed it with the hammer and got lucky.
    Crom likes this.
  9. Jul 7, 2014 at 1:30 PM
    #49
    XXXX
    sKiP
    05 Prius
    I would of sent you mine. They have been all over - Rich had them in TX last.
  10. Sep 26, 2014 at 1:26 PM
    #50
    hoodboogie
    hoodboogie Plazma Addict
    Scott
    Smiths Station, AL
    2014 DCSB TRDOR MGM
    Icon stage 3 + Delta joints Dakar leafs Method NV wheels 16" BFG KO2 285/75 Cab mount chop K&N drop in air filter K&N cabin filter Alpine X208U head unit JL Audio Slash 300/4 JL Audio Slash 600/1 Focal KRX2 components in front doors Focal RCX-165 in rear doors Alpine SWR-T12 sub Box/amp rack is fiberglassed on the back and molded to perfectly fit the cab. Leer 100R Decked drawer system Prinsu Cabrac and Toprac Husky Floor Liners ARB 50qt Fridge
    This write up helped me a lot. Thanks!
  11. Sep 26, 2014 at 4:09 PM
    #51
    XXXX
    sKiP
    05 Prius
    NP. Glad to be of help.
    Now I need to go back and fix the pictures.
  12. Sep 26, 2014 at 4:48 PM
    #52
    XXXX
    sKiP
    05 Prius
    and fixed again :laugh:
    I hate photobucket.. haven't even used it in years
  13. Nov 10, 2014 at 11:39 AM
    #53
    Large
    Large Red
    Just a quick tip for anyone wanting to do this, the ball joint press you rent from autozone does not work for removing the OE ball joint, and it does not work for putting the moog ball joint in. The pieces of pipe supplied with the kit are not the right size, they will keep slipping off the LCA and you have to start over. We ended up buying a 10' piece of pipe from a welder supply company and used a wedge to remove the OE ball joint, same for reinstalling the moog part number in the OP.
    ALSO, do NOT install the 45 degree zerk fittings that come with this kit, go to autozone / oreily and buy 90 degree ones, you will thank me afterwards.
    Crom likes this.
  14. Mar 28, 2015 at 1:35 PM
    #54
    dvd0020
    dvd0020 Well-Known Member
    Dave
    Colorado Springs
    08 Off Road Double Cab
    TRD supercharger, 4.88 Nitro gears, Doug Thorley long tube headers, aFe stage II intake, Pro Comp 6" DB lift (Icon Coilovers, Alcan 6" Springs, Bilstein RCD rears), NST lightweight pulleys, Morimoto mini projector retrofit for Spyder headlights, Cobra CB, 4' Fire stick, Pioneer AVIC-U310BT head unit, 2 10" alpine S, CBI Moab 2.0 front bumper, Smittybilt XRC8 winch, NFAB tire carrier, custom Colorado pinstripes
    Ok, I'm a little stuck at the moment. I can't for the life of me figure out how to get the steering stops off. Even using a pickle fork and hammer, they won't fall. Is there something I'm missing or should I keep beating the shit out of these things? Lol.
  15. Mar 28, 2015 at 1:49 PM
    #55
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    You need this tool. I'm not sure the of the actual name. Maybe Tie rod puller/ ball joint puller. You can rent them from a parts store.
  16. Mar 28, 2015 at 2:15 PM
    #56
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I've also removed the castlenut and flip it over reinstall and tighten untill flush if able and tap with hammer.
  17. May 22, 2015 at 2:03 PM
    #57
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    Is there one of the auto zone ball joint adapter sets that fit?
  18. May 22, 2015 at 3:58 PM
    #58
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  19. May 22, 2015 at 4:41 PM
    #59
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    I had to go to advanced auto parts to get the kit with the right adapter.
  20. May 28, 2015 at 10:21 PM
    #60
    White Bear
    White Bear Well-Known Member
    Louisiana
    Probably have the only 2nd Gen with an 8274 in the world.
    I did mine tonight. I bought the Chinese set of adapters in the op, and a us made ball joint press from napa. the Chinese adapters fit but I ruined a couple of them pressing the new ball joint in. Napa joints are a tight fit. I didn't put them in the freezer, etc. I'd recommend freezing the new joints. I'm a pretty big dude and I almost squeezed out a pebble wrenching on that press while pressing the new joints in, and that was with a 24" pull handle. Looked like a monkey humping a football or similar.
    Crom and phillstill like this.
