DIY LED DRL (2012-2015)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Izrasosa, Jan 11, 2016.
  1. Jan 11, 2016 at 8:02 PM
    Izrasosa
    Izrasosa [OP] Active Member
    2017 Tacoma TRD OR
    Started working on a small project recently and decided to share my progress. I've always liked the XSP-X style lights but they just looked to simple to justify spending that kind of money on them. I had spare trim pieces laying around so I decided to give it a shot and do it myself. Here's my progress so far.
    Ordered a set of 12 piece 10mm LED eagle eye bulbs off Amazon for $12.
    I then made a template from a cardboard box. I measured the center of the trim and then 1 inch between 6 points. Keep in mind the trim piece isn't square so make sure to take measurements from the bottom to ensure a straight line.
    I then taped the trim to keep from scratching the paint. Take the same measurements with the templates and mark them on the masking tape. Make sure to start the point by hand just enough to have a guide point for the drill to keep from possibly slipping or not lining up with the points marked. I used a 1/2' bit to give a little room to make adjustments to ensure a straight line.
    Next is to remove the back support lining to give the nut a flat surface to bite.
    Using a level lay the trim on a flat surface and adjust each bulb accordingly. Also measure each bulb from bottom to top to ensure straight alignment.
    Will finish wiring install when weather permits.
  2. Jan 11, 2016 at 10:47 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Subbed for outcome!
  3. Jan 11, 2016 at 11:00 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
  4. Jan 11, 2016 at 11:19 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  5. Jan 11, 2016 at 11:24 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I have those same lights and use them as my rock lights. Plenty bright. Looks good man.
  6. Jan 12, 2016 at 5:15 AM
    imageomega
    imageomega Well-Known Member
    Jarrod
  7. Jan 12, 2016 at 6:06 AM
    Wolverinesam
    Wolverinesam Well-Known Member
    New York State
    2013 Tacoma Prerunner 2.7L
    Where is that trim piece from on the truck? Pic if possible. Many thanks.
  8. Jan 12, 2016 at 6:20 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    subd for pics - custom > factory
  9. Jan 12, 2016 at 6:21 AM
    Wolverinesam
    New York State
  10. Jan 12, 2016 at 7:17 AM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Looks good so far.
  11. Jan 12, 2016 at 6:13 PM
    LiquidChimera
    LiquidChimera Well-Known Member
    Derek
    Spokane, WA
  12. Jan 12, 2016 at 10:28 PM
    DesertDunes
    DesertDunes Well-Known Member
    Cole
    Coachella Valley. CA
    2012 Super White Tacoma TRD OR DCSB
    Overland Stuff
    Can't wait to see this completed. I was thinking about doing this and taping into the DTRL. So during the day I would have these LEDs on and then at night my "raptor" lights in my grill would be on.
  13. Jan 15, 2016 at 8:15 PM
    DesertDunes
    Cole
    Overland Stuff
  14. Jan 15, 2016 at 10:05 PM
    VIPNiSS
    VIPNiSS Well-Known Member
    Tommy
    subbed.
  15. Jan 15, 2016 at 10:13 PM
    Captain Taco
    Captain Taco RipCity
    Rob
    Portland
    2013 Black Tacoma Sport
    3" Lift, Krank Fuel Wheels, TRD Pro Grill, Curved Roof LED Light Bar
    Awesome!! Want to see it on the truck :)
  16. Jan 15, 2016 at 10:18 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    Where are these gone go?
  17. Jan 15, 2016 at 10:43 PM
    DesertDunes
    Cole
    Overland Stuff
    Right below the headlights
    mahaloTaco[QUOTED] likes this.
  18. Jan 16, 2016 at 8:39 AM
    BWSecretQ
    BWSecretQ Well-Known Member
    Bradley
    Yadkin County, NC
    2013 Tacoma TX Baja
    Sliders, Prinsu Roof Rack, skids, Fox suspension
    Here is a picture of the trim piece he is working on...
  19. Jan 16, 2016 at 10:08 AM
    Wolverinesam
    New York State
    Thanks Bradley!
    mahaloTaco likes this.
  20. Jan 16, 2016 at 10:13 AM
    BWSecretQ
    Bradley
    Yadkin County, NC
    2013 Tacoma TX Baja
    No problemo! :thumbsup:
