DIY / Mechanic Quote Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AudioLove, Aug 14, 2024.
  1. Aug 14, 2024 at 9:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    Documentation of such?
    Benefit to the perps of this type vandalism?
  2. Aug 14, 2024 at 6:06 PM
    TacoTuesday1
    SD CA
    I'm not sure what the question is.
    Also, frame is done. That is like the foundation of the house. Biggest, most expensive, most important part. What's the point.
    Go to loosen a bolt and everything it's attached to disintegrates. Somehow manage to do an oil change to have truck break in half driving away.
    The cabin filters don't last over a year. That's why I switched to washable K&N with more air flow as per a rec on here.
    Engine filters, you are correct. They do not go bad that fast. No interval needed when it takes 2 minutes to inspect it.
  3. Aug 14, 2024 at 7:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    In My opinion that estimate screams Rip Off!
    Everything on it was WAY Overcharged...
  4. Aug 14, 2024 at 7:50 PM
    TacoTuesday1
    SD CA
    OP could very easily look at the labor time.
    Book time is generally book time.
    Again I'm not saying it's correct, like I said an engine air filter is not due every 10-15k.
    but as a mechanic, if a person wants to walk into the shop, log in, and look at book time themselves, there is nothing wrong with that. Very easy.
    Not to mention, at any dealership, the labor times themselves are typically literally written down every time.
    Also not going to change anything. If book time is 3 hours, 3 hours is 3 hours.
    You're either paying another human being (shop) 3 hours to perform a task for you, or you are doing it and not paying. But paying in other ways such as time and tools.
    Makes absolutely zero difference what the task is whether it's replacement of a part or performing Wash Laundry, as some folks do (butlers and housemaids)
    Extra Hard Taco likes this.
