DIY Mod "BLOOPERS"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NosiBaLasi, Sep 2, 2014.
  1. Sep 6, 2014 at 9:00 PM
    tankd0g
    tankd0g Well-Known Member
    Made a skid plate to protect the brake and fuel lines on my rallyx car, lowered it off the jacks and the plate severed a brake line.
  2. Sep 7, 2014 at 6:14 AM
    watchdog
    watchdog Well-Known Member
    jim
    nanuet n.y.
    09 tacoma
    Rims and tires , exhaust , stereo , Bhlm ,Changed carpet to black from grey. toytec ultimate lift kit. Allpro front bumper and light bar. In process of blacking out interior. Otrattw switches, black vinyl armrest mod, clazzio leather seat covers with heaters, flowmaster dual exhaust, hornblasters train horns,
    Did the same thing. Hope I never get a flat. Had to use air blaster to get beads to seat. I went from 265/55/20 that was on truck when I bought it. Was able to replace tires and rims for less than what 4 20" tires were going to cost.
  3. Sep 7, 2014 at 7:32 AM
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    8 in wheel was your problem lol. The 255s are designed only up to a 7 in wheel.. anything more than that is no bueno lol
  4. Sep 7, 2014 at 8:53 AM
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    I tried wiring the factory fogs to an aux switch and thought since it was "negativly switched" you put the negative from the old switch on the new one. All I saw was a cloud of smoke, flipped the switch back off. went to start the truck to find ABS, parking brake, and rear locker light on, no windows or ac. That one wire melted like 6 wires that kept making a fuse pop so I had to wire all of those wires...
  5. Sep 7, 2014 at 9:13 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Oh man...where do I begin.
    My 1990 Accord
    - When I was putting in my lowering springs/adjustable struts I disconnected the UCA as that's how my friends had done it in the past which allows you to pull the spring/strut/tophat assembly up and out. It disconnected the CV joint and then I couldn't get it to snap back together. The only way you can get the axlenut off is to have the tire on the ground to give you the friction. Ended up having to undo the LCA to make everything fit back together only to round off a nut in the process. My friend basically cleaned up the threads with a Dremel. My car was on jack stands for a week trying to figure out how to fix that one.
    2. Wired washer LEDs (remember those?) directly to the battery with a switch. No fuse, no firewall grommet, no insulation. I'm very lucky I didn't have a fire.
    3. When I reinstalled my rear interior after I had my quarter panels replaced I pinched the 3rd brake light wiring which caused it to short and blew a fuse. I kept replacing the fuse before I realized what the cause was. Turns out I melted have the brake light wiring before I fixed it.
    My STi
    1. Was washing it so I ended up having the wiper arms up. Went to open the hood and scratched it.
    2. I still need to get around redoing the stereo wiring as it's not as clean as I'd like it to be. Rather than use a heavy gauge wiring and a distribution block to power my two amps I have two amp kits (since I had one for each amp) and one wire was too short so I lengthened it using not such awesome wire (same gauge, poor connection).
    1993 Toyota Xtracab
    1. When I wired the KCs on my ARB I spent a lot of time with solder and heat shrink thinking I'd do a really professional looking job. I ended up heat shrinking both wires I had just soldered together so every time I turned on the lights the fuse blew. Took me a solid few hours to realize I was dumb.
    My Tacoma
    1. Just yesterday I was putting in my Homelink module and instead of grabbing the map light wiring I grabbed the Bluetooth microphone wiring. I swore I got +12v across the red/black wires from the microphone with my DMM but it wouldn't power the module. Moved it to the map wiring and it worked.
    I'm sure there will be many, many more to come as I have a tendency to break things when I'm working on projects.
  6. Sep 7, 2014 at 9:18 AM
    Dangerdave
    David
    Wilmington, NC
    20 F150
    WHAT? Every tire that I have looked up says 7-7.5 max wheel width..
    That is strange for sure.. My maxxis bighorn 255/85s are rated for only 7 in width
  7. Sep 7, 2014 at 11:53 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Haha I and thought I was clumsy...nothing really went wrong so far, but I have a tendency to draw blood everytime I work in the engine bay....
  8. Sep 7, 2014 at 12:01 PM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Last weekend I decided to finally install my dashcam.
    Since my truck doesn't have a compass/temp gauge, I was going to tap 12v up there.
    Removed overhead console, turned key on, started probing the connector with a DVOM trying to find power.
    Found nothing, searched interwebs to find pinout, scratched head, drank beer. Just as it was getting dark and I was ready to give up and button the truck up, I reached over and turned the key to ON instead of ACC. Oh, there's the 12V.
    D'oh. Nothing broken but that is a couple hours of my life I will never get back.
  9. Sep 16, 2014 at 9:18 PM
    NosiBaLasi
    NosiBaLasi [OP] RESULTS, not excuses
    Jones
    Home of 1st Marine Expeditionary Force
    IG: overlandhd & tacoma_2gen_hq
    All in "My Build" page
    LoL @ Mickey
  10. Sep 16, 2014 at 9:22 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
  11. Sep 16, 2014 at 9:31 PM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    Did you set it on fire or something?? Wtf
  12. Sep 16, 2014 at 9:33 PM
    NosiBaLasi
    Jones
    x2 WTF lol
  13. Sep 16, 2014 at 9:44 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Ugh where do I start?
    First mod when I got my truck, Got car mesh for a satoshi, cut that the exact size of the opening with no extra mesh to really connect to the grille :annoyed: . I now have painted chicken wire holding it to the grille (should get a picture of that up here)
    Next are the lights I put behind the grille.
    They are mostly for looks since the radiator support is so close to the radiator that I can't adjust the lights to not converge and be up so... it's a spotlight
    397D6066-6316-482D-AD3C-DAC6BBAD2DD5_zps_d2b3cf6ee45375944fec45a4cae4e4d8869cc6d2.jpg
    But they do make a very good spotlight haha
    Next is plasti dip rims
    AE51B583-0685-4F08-B1E8-CF24BC985122-102_8459cbe1150f1ff0fae5e92e74c66666778c4961.jpg
    Turned out ugly with how the front of my truck is!
    Then my latest addition is my camper shell. I ordered duplicolor lunar mist spray paint online and I guess they sent me generic silver! Well guess who found out after spraying the camper? Me
    CF473FC7-0C11-4E04-B544-D41439DDEF2D_zps_7dea144f015078285ca464ff563d59e7d8fc60e0.jpg
    and might I say that I didn't have enough to coat it evenly so its nice and splotchy!
    That is all for now until I paint the camper shell black. Which hopefully wont be a blooper... Please don't let it be a blooper
  14. Sep 16, 2014 at 10:15 PM
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    haha. man, you should probably stop modding your truck.
  15. Sep 16, 2014 at 11:35 PM
    #35
    Ice Horse
    Lauren
    Florida
    :laugh:
    You know how you can water dip stuff with paint?
    I tried to see it if worked with plasti-dip...it doesn't haha
  16. Sep 17, 2014 at 12:01 AM
    #36
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Pulled (crumpled really) my fender :frusty:
  17. Sep 17, 2014 at 7:32 AM
    #37
    WildLand
    Josh
    NM
    16T4RSR54WD
    I know huh :frusty:
  18. Sep 17, 2014 at 8:48 AM
    #38
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    Wife was driving and thought it was in first. Nope.... Got a nice modded rear bumper out of the deal. ;)
  19. Sep 22, 2014 at 9:20 PM
    #39
    NosiBaLasi
    Jones
    Beat me to it :D
  20. Sep 22, 2014 at 9:25 PM
    #40
    WildLand
    Josh
    NM
    16T4RSR54WD
    My first mod went well at least with my leveling kit, but all after has been shenanigans. Someday I'll have a mod that goes well again!
