DIY mods for the 95-04 tacomas!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman06, Jun 29, 2008.
  1. Aug 7, 2008 at 11:05 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Nothing worng with Bigger 12Volt batteries in your truck...
    just make sure your Ground are good. Your Batter should have 2 Ground leads.
    1 for the body and 1 for the Frame.
    make sure they are clean. Ask me how I know this.
  2. Aug 7, 2008 at 11:08 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    hey uber, how do you know that?
  3. Nov 9, 2008 at 6:45 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I have a manual 03 4x4 tacoma and i did the grey wire mod and it works. it should be exactly the same steps as doing it for an auto.
  4. Nov 23, 2009 at 10:06 PM
    Johnsono49
    Johnsono49 Well-Known Member
    Owen
    Asheville, NC
    Crewcab SR5 TRD 4x4
    Custom Front Bumper and skid plate from RLC Weld and Fab, Turn Signal Mod, PIAA Driving Lights, Leer Bed Cap, Bilstein 5100's Front (1.75") and Rear, ToyTec 2" add-a-leafs, 3" Deck Plate Mod
    Awesome post Will, has given me lots of ideas and thing to look forward to attempting.
  5. Nov 24, 2009 at 1:51 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah dude.....alotta good mods and such in there.
  6. Dec 2, 2009 at 7:10 AM
    opc167
    opc167 Active Member
    Macon Georgia
    96 4x4 3.4L XL
    I've only opened up the air box for more air intake. No mods.
    I need some advice. I have a 1996 4x4 3.4L. I need to pull about 5000 lbs. I’m changing out the [COLOR=blue! important][COLOR=blue! important]clutch [COLOR=blue! important]fan[/COLOR][/COLOR][/COLOR] [​IMG]
    with dual electrics first. What I want to do is the following:
    Add a re-locate [COLOR=blue! important][COLOR=blue! important]oil [COLOR=blue! important]filter[/COLOR][/COLOR][/COLOR] [​IMG]
    Add an oil cooler and trans cooler.
    I’d like to add this cooler in the tool box in the bed (vented or course). If I had filters for both oil and trans with a cooler for both that is dual fanned, should I add an inline oil and trans fluid pump since it will be adding several feet of travel? I’ll be splicing into the trans line that goes to the radiator and cool it prior to it traveling thru the radiator. I wanted to cool the oil because of the load I’ll be adding but I don’t want it to loose oil/trans pressure if I custom install this design in the tool box.
    I see fans on off-road buggies. Is it usually for oil or is it for the trans also in addition to radiator cooling?
    Thanks for your advice.
    Chris Brooks – Macon Ga.
  7. Dec 17, 2009 at 7:02 PM
    Huntr Pat
    Huntr Pat Green Taco
    Emmett*Idaho
    99 2.7 xtra cab
    K&N,Warn winch w/combo system,3"Revtek bilsteins,Marlin Crawler Nilights LEDs fog & flood Yakima roof racks. 31'"BFG K02's
    How about gearing stuff for a 98 taco 2.7 ltr
  8. Dec 17, 2009 at 7:37 PM
    98lowflyingtacoma
    98lowflyingtacoma Well-Known Member
    Phoenix
    1998 Tacoma Prerunner
  9. Apr 8, 2010 at 9:48 AM
    TGurau
    TGurau Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    Has anyone compared the intake mod to an actual CAI?
  10. Jul 17, 2010 at 8:26 AM
    FightFire48
    FightFire48 Taco Monster
    Will
    Spokane, WA
    04 Taco dbl cab
    3" Toytec lift AEM BruteForce CAI Gibson exhaust 2 - Rockford Fosgate 8's
    I dont know much about the decplate mod but im pretty sure its just a cheaper way to get more air. But i have an AEM brute force CAI and i noticed alot of gains. IMO when i dont have my foot in the gas tank i get better gas mileage as well.
  11. Jul 17, 2010 at 12:07 PM
    Johnsono49
    Owen
    Asheville, NC
    Crewcab SR5 TRD 4x4
    I haven't done a direct comparison, but I have noticed better highway millage and throttle response. Also helps to keep it under 2500 rpms.
  12. Dec 18, 2010 at 6:18 PM
    jimmer.777
    jimmer.777 New Member
    jimmer
    alaska
    99 xcab TRD off road super charged
    4 inch fabtech suspension lift, old man emu springs, 32X11.50 BFG mud terrain km2, ABR air locker in rear, ABR front and rear bumpers, warn 9500, TRD super charger, K&N air filter, xenon headlights
    for sure man i have a trd 3.4L and have always had a yellow top with 750cca
  13. Jan 20, 2011 at 3:13 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    great site you posted the small spacers will solve my rubbing problem on my 2004 prerunner L4. running 265/75-16's on it. also am stoked cause i just installed a pushbar and winch (wich took a case of beer, drill, welder and alot of muscle. did have on uestion though. im rather unhappy with the performance of my runner in mild to moderate off road conditions, in particular the coventional rear diff. any suggestions on a good replacement axle or lsd chunk?
  14. Jan 20, 2011 at 5:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what about an air locker like arb makes?
  15. Jan 21, 2011 at 8:05 AM
    #35
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    If you're not happy with the way a two wheel drive truck offroads, you should get a 4x4. No kind of rear locker will make up for the lack of spinning in the front. Not trying to talk crap, I respect all truck owners for the reasons they need a truck. A work truck doesn't need 4x4 unless they're in colorodo and the chance of snow is 99%. Two wheel drive trucks should stay on the road. Get a 4x4 and you'll be much happier with Offroading. If you really don't care, it's a good thing you installed a winch, you're going to need it. Good luck to you man, hope I didn't offend (anyone).
  16. Jan 21, 2011 at 1:20 PM
    #36
    v1ndictiv3
    v1ndictiv3 Well-Known Member
    Bay Area, California
    '98 PreRunner Xtra Cab 2.7L
    Mostly stock: AFE Pro Dry S Filter, Bedrug, Leer Shell, 265/75/15 Goodyear Wrangler RT, Husky Liners, Wet Okole seat covers... Powertrax No-Slip in the near future =)
    Didn't sound offensive to me... It's true that nothing will make up for the lack of the front end spinning, but a locker in the back will be a huge help and upgrade from stock open diff. Look into Aussie Lockers to see if they make one for your differential size and if not try Lock Rite or No Slip (basically like other lunchbox lockers but operation is quieter). Just know your trucks limits, drive carefully, put in a locker and you should be good for most apps. Just don't expect to rock crawl or anything. =D
  17. Feb 4, 2011 at 10:19 AM
    #37
    SalemCBR
    SalemCBR Oregon's #2 TW rep
    Oregon
    04 DC Elock PreR
    Deck plate, all time auxillary, black billet, xeon bulbs, sockmonkey decals, and lots of back to black.
    Obviously not rock crawling over here, but in mud and mild off roading that rear locker has made a world of difference when i put it on in 2wd. I'm not sure how much it would cost to throw one in. But if your keeping the truck and it doesn't have it now, I'd sure consider it. With-out the rear locker the thing would be near usless as soon as it leaves the road. Like a ford taurus with big tires on it. Look good, but lack in off road performance.... and it would still with the locker on many levels.
  18. Mar 4, 2011 at 9:37 PM
    #38
    Kelsey
    Kelsey Camping Lover
    Jasper, Alabama
    2004 Doublecab TRD 2WD
    K&N, Redline Differential Fluid
    I bought my '04 DC 3.4 to tow campers and race cars, and since my driveway looks like Colorado, I got a TRD with the locker. HAVE NEVER REGRETTED IT! Looking back, it's amazing how much I use the thing. Am I subconsciously getting myself into more tough spots than I used to because I know I have the locker under there? Might be. But I'm really REALLY glad I've got it!
    I've almost gotten stuck before, but not because of the locker. If my tires were a match for the locker, I'd never miss a beat. Time for new shoes.
  19. Dec 2, 2011 at 11:14 PM
    #39
    shockj2000
    shockj2000 Member
    Im adding aftermarket headlights to my 97 taco... the light already look ugly off the truck but i want hids.. Ill probably have it set up by end of nextweek just waiting on the hids to come in from asia...Anyone else done the lights mod with pics?
  20. Jan 16, 2012 at 11:58 PM
    #40
    98yoter
    98yoter Member
    Ash
    Houston, Tx
    98 Tacoma sr5
    Thanks for the great post! I am new to the world of toyotas I just purchased my first one last thurs. and I am really looking forward to fixing her up and hitting the trails.
