DIY N-fab style Step bars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BubbaHerrera, Jun 3, 2016.
  1. Jun 3, 2016 at 2:30 PM
    BubbaHerrera
    BubbaHerrera [OP] Member
    Bubba
    Azusa, California
    2011 SR5 Prerunner Double Cab
    HID change over Oversize tires (larger than stock at least) Fog light install Custom N-Fab style nerf bars Stock engine, drivetrain and suspension
    So I was looking into lifting my truck, researching and what not, and I remembered that I'm pretty short and if I do lift the truck I'll eventually need to get in and out of it right? So I figured I'd buy some step bars(my truck didn't come with them) while looking on Amazon and other websites that sell them, I realized they're like $300+ dollars plus shipping.
    It's just some metal tubing right?
    I have a welder, and love saving money. So I decided to make some myself.
    It's not as hard as you might think. But it is time consuming. I have finished the driver side already. And it is a bit rough.
    So as I'm making the pasenger side, I'm going to need more finesse and patience.
    Here are some pics and how I did mine.
    First, I purchased some 10' x 2" tubing, from the local home improvement store. image.jpgThen I measured where on the truck I want it to be, cut it down to size using my inexpensive harbor freight grinder. Which works as well as my makita for work, surprisingly
    And I bought a bunch of 3/4 black iron piping at:
    12" (2 per side)
    6" (4 per side)
    And a 45 degree elbow joint.
    I made the steps longer, and protrude out more from the base tube because i wanted a wide step area.
    Once the tubing was grinded down to size and ready for welding it was about 10" and 4"
    Here is the joint and the 4" piece before welding image.jpgIn the back is a completed step, along with tons of dust and slag haha
    I made the brackets for the actual step out of excess angle iron I got from work. I'm a carpenter and we use it as posts to keep us from falling to our death on some jobs.
    I cut 3 1/2 inch sections of the angle iron, welded them together with the ends facing opposite directions, like two L's (I'll post pics later) and drilled out a hole for it to bolt onto the holes on the bottom of the truck, the stock holes.
    Once the brackets were in place I welded up the base 2" tubing, and welded up the stepsimage.jpg I know my garage was messy at the time. I have cleaned it since I snapped these pics haha.image.jpg
    All in all, it costed me less than $80 to put these together myself, because I already owned most of the tools and some of the material I needed. Took me about 24 man hours to complete the first one, because it was a lot of trial and error, and a ton of grinding. The second one will not take half as long.
    This is my first post, I know I'm missing some descriptive explanations that some people might want. Feel free to ask questions, and I'll post more as I complete the passenger side.
  2. Jun 3, 2016 at 3:30 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Congratulations ! They look great. R U going to paint them ??
    BubbaHerrera[OP] likes this.
  3. Jun 3, 2016 at 3:43 PM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    As you pointed out its a bit rough, but looks good so far. I think the driver's side will need a bit of work to really make it clear, but overall you've done a great job. The N-fab's are expensive, I got a steal when I bought mine new for $250
  4. Jun 3, 2016 at 4:09 PM
    BubbaHerrera
    Bubba
    Azusa, California
    image.jpg Yeah $250 is a steal. I would have bought them too.
    half way through I got sick of making them and started wondering if it was worth buying.
    This is the driver side with paint
    SilverBullet19 likes this.
  5. Jun 3, 2016 at 4:12 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Damn... Impressive! Great job man! :thumbsup:
  6. Jun 3, 2016 at 4:28 PM
    BubbaHerrera
    Bubba
    Azusa, California
    Much thanks guys. Really appreciate the kind words
    Here are some more pics I snapped earlier. This is how I made the brackets/mounts
    So I fabbed up the passenger side today, and got some pictures while mocking it up.
    Drilled out the holes using a 1/2" titanium bit, and bolted it to the underside of the cab, in the factory threaded locations with the ends of the nerf bar supported by jack stands
    Slip in the bottom end of the bracket
    And weld it up.
  7. Jun 3, 2016 at 11:25 PM
    SilverBullet19
    Scott
    Sacramento County
    Looking really good. Personally, I would try to tuck the main tube up closer to the bottom of the cab. The workmanship is top notch!
  8. Jun 3, 2016 at 11:43 PM
    BubbaHerrera
    Bubba
    Azusa, California
    Thanks silver bullet. I did think of tucking it closer, but I wanted it to sit lower, so my passengers (and myself ) could get in easier when it's lifted. My wife is 5'0 and complains about hopping in at stock height.
  9. Jun 3, 2016 at 11:44 PM
    SilverBullet19
    Scott
    Sacramento County
    I know the feeling, my wife is 5'3" and struggled...its the only reason I got the steps! lol
  10. Jun 3, 2016 at 11:49 PM
    BubbaHerrera
    Bubba
    Azusa, California
    image.jpg Here's a picture of a step before mock up
    Notice the ends are cut to mount flush onto the base pipe
    Jack stands did a great job of holding the opposite end of things while I welded them in place.
  11. Jun 3, 2016 at 11:51 PM
    BubbaHerrera
    Bubba
    Azusa, California
    Haha yeah man, I plan on lifting like 3-4 inches so once that's done I know I won't hear the end of it haha. So I planned ahead
    Happy wife happy life...
  12. Feb 9, 2017 at 6:28 PM
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    hmm. some conduit is pretty thick from what i remember when i had to run 2+ i guess they can be different thicknesses. gotta check what i have left on my truck from install, i know i have couple 10ft pieces. thanks for idea, was gona cut ladder rack i got that doesnt fit truck. this might be alternative
  13. Feb 12, 2017 at 8:56 PM
    BubbaHerrera
    Bubba
    Azusa, California
    I don't recall the exact thickness of the conduit I used, but if I had to guess from memory I'd say it was about 1/8 of an inch thick.
  14. Feb 13, 2017 at 5:44 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Good job!!!
  15. Feb 13, 2017 at 6:11 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    They look pretty good but definitely need to slap some bedliner on them.
