DIY: OEM tailgate camera in pre '09 taco. LOTS OF PICS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MJonaGS32, Apr 25, 2011.
  1. Feb 23, 2013 at 9:34 AM
    mikesmith
    mikesmith Member
    Utah
    06 TRD Sport 6" lift w/33's
    I am going to be doing a OEM camera from a 09+ on my 06 Tacoma to one of the ottonavi head units that has a RCA plug for input for the backup cam. I am planning on taking a RCA plug and splicing it to the piece of wiring from the OEM camera. I am assuming that the video neg goes on wire and video pos to another wire on the RCA plug. My question is which is which? Also will this idea even work? Any thoughts guys?
  2. Feb 23, 2013 at 10:24 AM
    east
    east Well-Known Member
    S.E. N.C.
    Stock 4x4
    Excellent writeup, your post has given me a lot of good info that I can use on my install. I am planning to do an install with my aftermarket backup camera and run it to my Pioneer AVIC gps unit. I also liked the way you installed your small video monitor which I might do a small video monitor for my Icom IC 7000 hf amateur radio install.
    Thank you,
    Eric
  3. Feb 23, 2013 at 1:39 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i got these color codes from another thread on here....
    1- CY- (WHITE) CAMERA VIDEO NEGATIVE
    2- CY- (RED) CAMERA VIDEO POSITIVE
    3- CGND (BLUE) CAMERA GROUND "SHIELD"
    4- CB+ (BLACK) CAMERA POWER
    HOPE THIS HELPS
    thank this guy this is where i got my info from....
    rep to you sir
    http://www.tacomaworld.com/forum/4-c...ra-pinout.html
  4. Feb 23, 2013 at 4:17 PM
    mikesmith
    mikesmith Member
    Utah
    Thank you very much sir! The link didn't work for me but reminded me to put "pinout" in my search and found a couple other posts about it too. Hoping to get everything within a couple weeks and I hope to do another thread with a review of the ottonavi unit and the camera install install. But we will see where my patience is! Thanks again!
  5. Apr 23, 2014 at 6:04 PM
    Mikieaptos
    Mikieaptos Member
    Aptos,Calif
    Tacoma SR5 4x4
    Well got the waterproof license plate camera on, has two shield plugs, yellow(video) and red.. Now with Toyota harness has 4 pins as you pointed out, was having trouble getting a signal to the new camera...was splitting the yellow up to go to red + and white - and the split the red wire from camera to blue and black for power. Need some help, thanks
  6. Apr 23, 2014 at 7:54 PM
    Mikieaptos
    Mikieaptos Member
    Aptos,Calif
    Tacoma SR5 4x4
    Thank you Mike Smith for help on camera wiring, it works great..spit yellow video wire to white and red pins on harness, red wire split to black and blue pins on harness
  7. May 18, 2014 at 12:41 AM
    je3169
    je3169 Well-Known Member
    Cincinnati OH
    2014 Access Cab TRD Sport
    2" Front, 2" Back, Opti-Coat Pro, Toyo Running Boards, Kenwood DNX891HD
    Hello all does anyone know if 2014 camera is the same pin out I am installing an aftermarket head unit and want to hook up the rear camera to it.
    Thanks John
  8. May 18, 2014 at 7:36 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The pinout might not be the same as far as location on the plug, but you're still gonna have camera +/-, ground, and power
  9. Jun 14, 2014 at 9:12 PM
    Mikieaptos
    Mikieaptos Member
    Aptos,Calif
    Tacoma SR5 4x4
    License plate camera
  10. Dec 2, 2014 at 9:30 AM
    Purdue Pete
    Purdue Pete Well-Known Member
    Indiana
    07 TRD 4X4, V6, 6 spd.
    Removed Charcoal filter, K&N filter, and that's it until I can save a bit
    Sub'd for future use.
  11. Dec 5, 2014 at 6:48 PM
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    Sub'd
  12. Apr 6, 2019 at 12:01 AM
    fiij
    fiij Member
    Sarnia, ON
    09 2WD AC MGM
    Bump! Hoping one of you lads will be able to enlighten me here. I apologize in advance for my stupidity. I just bought a Sony XAV-AX1000 Receiver for my 4cyl 09 along with everything needed to install it—receiver wiring harness, Posi connectors, dash kit, screw pack. My tailgate handle has an empty slot for a backup camera, so I found the part number and bought one on eBay. I want to install this camera and connect it to my new receiver. Would it be safe to assume that my truck is all pre-wired for this? Is there anything else I'll need (additional wires, harness, electrical tape, etc.)? Got any tips that will make for a smoother/quicker installation?
    From what I've gathered, the pre-wired 09s are set up for the rear-view mirror/monitor. So, how exactly would I bring that wiring from the overhead console down to the head unit? Is there a specific route or method that makes the most sense (probably obvious to you; frickin' Chinese to me)? I have no clue what can or can't be pulled off or moved around. Crutchfield said the receiver comes with detailed installation instructions, and also offered to walk me through it over the phone, but it's the camera I'm worried about.
    If I'm not pre-wired, I may just have to bite the bullet and take it into the shop... :spending:
  13. Apr 6, 2019 at 12:08 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    You might consider asking in the Audio & Visual subforum. Lots of knowledge and help with these specific issues over there too.
  14. Apr 6, 2019 at 12:19 AM
    fiij
    fiij Member
    Sarnia, ON
    09 2WD AC MGM
    I made a post over there about 9 hours ago and unfortunately the only answer I got was that the pre-wiring would be found running into the tailgate or tucked behind one of the taillights. Although I appreciate the clue, it really didn't help my situation. Maybe I'll make another post with some more detail. Thanks biscuits.
    Biscuits[QUOTED] likes this.
