DIY Oil Change or Dealer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GibbsTacoma, Jul 29, 2020.
  1. Aug 2, 2020 at 7:06 PM
    #81
    DrMark
    DrMark Diet Mtn Dew & Guns
    Alabama
    2011 Tacoma PreRunner DoubleCab
    Those things don't drip?
  2. Aug 2, 2020 at 8:08 PM
    #82
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Here’s a little secret for those that live in apartments that don’t allow you to work on your trucks in the parking lot or they’ll evict you...... go to a different apartment complex parking lot and work on your truck. I did this my entire college career. Never have to worry about getting evicted. 4D chess, man.
  3. Aug 2, 2020 at 9:15 PM
    #83
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    This was my biggest skepticism before buying. It's been over a year now and it absolutely does not drip.
  4. Aug 3, 2020 at 3:17 AM
    #84
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    8 years with mine. I installed it at 5k miles when I did my first oil change and to this day, no drips. Only time you'll see a drip is post drain. The residual oil just accumulating on the bottom of the valve.
    -J
  5. Aug 3, 2020 at 3:35 AM
    #85
    navynuke
    navynuke Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    If you are in York county all of the waste collection facilities take oil. I store it in a 5 gal
    bucket until it’s 2/3 full and then take it to the one less than a mile down the road.
    GibbsTacoma[OP] likes this.
  6. Aug 3, 2020 at 4:35 AM
    #86
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Not unless they are damaged. They are quite reliable. They (that style, not futomo specifically) are PMA approved on many aircraft engines. They do hang down a bit further than the OEM plug. 1-2" depending on what style you get.
    DrMark[QUOTED] likes this.
  7. Aug 3, 2020 at 4:40 AM
    #87
    wbeard365
    wbeard365 New Member
    2015 Sport 4X4 DC Long Bed
    Stock
    There no real cost difference for me to have oil changed and tire rotation
  8. Aug 3, 2020 at 9:30 AM
    #88
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    The older I get, the more work I do on my own vehicles. Got sick of crappy expensive repairs from the mechanic shops. My OCD takes over and I become a perfectionist when working on things so like one poster said at least I have the peace of mind that I know it is done right and I was probably much more meticulous than the mechanic was in being sure that is done right.
  9. Aug 3, 2020 at 9:37 AM
    #89
    mikkydee
    Doyle
    Florida
    The reason I didn't go with the fumoto plug is because by adding the additional drain insert you can't drain all the oil out because the threads stick up higher in the oil pan. My OCD tells me that the bottom of the pan is where all the sludge and sediment settle and I want that out every time I change the oil. Even if it is only 1/4" of oil left in the pan it is the bottom where all the sludge, particulates, and residue settle.
  10. Aug 3, 2020 at 9:42 AM
    #90
    mikkydee
    Doyle
    Florida
    I totally need one of those! Maybe the wife will let me pawn her ring and get me one...
  11. Aug 3, 2020 at 9:45 AM
    #91
    mikkydee
    Doyle
    Florida
    I freakin live on youtube how to videos.
  12. Aug 3, 2020 at 9:48 AM
    #92
    mikkydee
    Doyle
    Florida
    hahahahaha! This is freakin genius, I love this idea. Of course, now I don't have to worry about it because I have a 9-acre spread with a barn and a 3 car garage. But where were you back in the day man?
  13. Aug 3, 2020 at 10:02 AM
    #93
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    No OCD here but I have the same concerns about draining as much contaminated oil as possible.
    I've been doing basic maintenance on my vehicles for 50+ years, and the Tacoma is one of the easiest to do.
    mikkydee[QUOTED] likes this.
  14. Aug 3, 2020 at 10:08 AM
    #94
    GrundleJuice
    Michigan
    2016 TRD Bro
    If that's the case, I wouldn't use one either. I have one at home, night it with intention to install at next OCI but after seeing how much it protrudes I am on the fence about it. The threads don't seem to be long enough to protrude above flush inside the sump but I'll measure next time the plug is out.
  15. Aug 3, 2020 at 3:14 PM
    #95
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    I have a Fumoto Valve and was worried about the sludge build up too. Then I measure the amount of threads in the pan to the amount that was sticking out from the valve. I was prepared to grind them down but the amount of protrusion was minimal and didn't even bother starting up the grinder. I also start draining the oil as soon as I get home from driving. It helps speed the process up and I figure everything should still be suspended.
    If you dont want to grind the valve just keep adding washers. Any threads past the pain do nothing hold it in.
    mallege likes this.
  16. Aug 3, 2020 at 4:55 PM
    #96
    DrMark
    Alabama
    I got ya beat... I take my drain plug out for my short commute home from work. Then I can change the filter and add oil as soon as I get home, and don't have to find a place to take the old oil.
    Alright... I'm kidding of course... but I'm sure someone has done it.
  17. Aug 3, 2020 at 4:58 PM
    #97
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    same had it on my Truck and on my previous car. Those things make engine changes a damn breeze. make sure you get one one with the nipple on it so you can add a hose on it. If you run skid it protects it. I just take off the lever lock, push the tube on, open and rank, flip it back and its done (minus oil filter).
  18. Aug 3, 2020 at 4:59 PM
    #98
    nudavinci64
    Robert
    im sure someone somewhere had. horrible but if you can think of it then someone had done it.
  19. Aug 3, 2020 at 5:56 PM
    #99
    TexasWhiteIce
    Texas
    Longhorn, baby!!!
  20. Aug 3, 2020 at 8:51 PM
    #100
    Regnar
    Kodiak,AK
    Damn. You waste all that good oil? I spray down my entire underside with what I collect. Never have to worry about rust. Kidding of course.
