DIY Oil Change Poll - Stock Nylon Cartridge Filter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Oct 2, 2020.
Was the Oil Filter Cartridge Cover Problematic?
  1. Too tight?
    23.5%
  2. Broken when loosening?
    7.4%
  3. More than one failure?
    1.3%
  4. No issues at all.
    73.2%
Multiple votes are allowed.
  1. Oct 2, 2020 at 10:04 AM
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Hey, Folks.
    Because it comes up very often, I am just curious about folks who have continued to use the stock nylon oil filter cartridge cap. After more than one oil change, did you have difficulties or failures?
    My basis is that I did an oil change at 5k because I was bored and had no problem with the cartridge cap. I'm coming up on the 40k service and am curious to see the situation after the ToyotaCare work. I have no plans or worries about the nylon cap?
    We had one car with a cartridge filter in the past. The cap had no flutes like the Taco one does. Still, no issues in the 140k life of that car with 10 oil changes that I did. According to the state registration website, it is still on the road at any rate. :D
    If there needs to be more choices, please let me know.
    Thanks!
    Have a good one.
    Adding: Three oil changes done at home now. 5k, 40k, 50k, 60k, and 70k. The 40k was just a bit tight, but I have found other fasteners to be torqued to a consistent feel from my dealer after the ToyotaCare visits. Lugs and skids.
    I think the problem that has been seen here are shops torquing it incorrectly.
    davidstacoma and Junkhead like this.
  2. Oct 2, 2020 at 10:07 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I've had the stock nylon on 2 FJs, a 4Runner, a Prius, and my 3rd gen, never an issue with any of them
    Plain Jane Taco and tonered[OP] like this.
  3. Oct 2, 2020 at 10:07 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Mine was too tight when I first yanked it @ 10k miles. I just torqued it’s correctly and never had an issue since
    over60 and tonered[OP] like this.
  4. Oct 2, 2020 at 10:08 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I should add that the Prius we bought certified used and that sucker was the tightest of the bunch, it had been dealer serviced up to 40k. The rest were bought new and only myself did the maintenance
    tonered[OP] likes this.
  5. Oct 2, 2020 at 10:10 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    This style is way superior in every way to metal cartridge or spin on filter. (I can’t think of any single downside as long as used appropriately). Had them on many vehicles over the years, and never a single problem. But I also do my own maintenance, and many don’t seem to know how to use them and they will break if misused.
    69 Jim and tonered[OP] like this.
  6. Oct 2, 2020 at 10:15 AM
    tonered
    tony
    Lynnwood, WA
    I do agree, esp for taking a look at the filter media after the removal.
    But mainly, I am curious about usage issues of the cartridge cap itself since there is some much talk about tightness and failures.
  7. Oct 2, 2020 at 10:18 AM
    Bishop84
    Bishop84 Well-Known Member
    It really varies, you have to understand lube techs are terrified of leaks and will double check the filters, which usually ends up in over tighten
    I have a couple of filter tools, but I don't use the flute one very often anymore. Usually when its over tight I use the non-flute tool and chisel the flutes with a pry bar while keeping pre-load.
    Factory is never over tightened for me. It's just the tool and the angle.
  8. Oct 2, 2020 at 10:21 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    No problems here. My Camry Jut hit 105K. I've changed the oil every 5K and it uses the exact same cap. Toyota took it to 20K and I've done every change since.
  9. Oct 2, 2020 at 10:23 AM
    tonered
    tony
    Lynnwood, WA
    Thanks!
    That is why I am asking about folks who have repeatedly done their own work. Other than the factory torque, like you noted, it is probably the only reliable method that we have to get something established here.
    I'm not trying to make a personal decision, just gather up some data because it comes up so often.
  10. Oct 2, 2020 at 10:24 AM
    Shellshock
    Iowa
    Mine was vastly over torqued thanks to toyota care
    TailHook, b3itz, Junkhead and 3 others like this.
  11. Oct 2, 2020 at 10:26 AM
    tonered
    tony
    Lynnwood, WA
    I am looking forward to that moment myself. They have been great, even with the lugs.
    How about since then?
  12. Oct 2, 2020 at 10:27 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    This setup has been around since 2004. It's a tried and true setup. Just remember that the housing is sealed with an o-ring not a gasket. There is no reason to torque down on it. A light snug is all that's required.
    Boghog1, NAAC3TACO and tonered[OP] like this.
  13. Oct 2, 2020 at 10:30 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had a Cavalier in the past with a similar setup, no issues on that one or my Tacoma.
    Junkhead and tonered[OP] like this.
  14. Oct 2, 2020 at 10:31 AM
    tonered
    tony
    Lynnwood, WA
    Agreed!
    Good advice. And, that the torque spec is molded right into the cartridge cap.
  15. Oct 2, 2020 at 10:34 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Torque specs are stamped on the cap. You're right, it's not a lot.
  16. Oct 2, 2020 at 10:35 AM
    Shellshock
    Iowa
    Since then I replaced mine and have done it myself. No issues
  17. Oct 2, 2020 at 10:35 AM
    tonered
    tony
    Lynnwood, WA
    Yes, but did you have any issues repeatedly removing it at home?
    Just trying to prove / disprove a myth here. :D
    shakerhood likes this.
  18. Oct 2, 2020 at 10:38 AM
    robssol
    Rob
    S. Wisconsin
    Nope. Except the first time after the dealer did it.
    tonered[QUOTED][OP] likes this.
  19. Oct 2, 2020 at 10:39 AM
    tonered
    tony
    Lynnwood, WA
    Thanks!
    I am seeing a trend here!
    :cheers:
  20. Oct 2, 2020 at 10:49 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    No issues with mine, but I never used toyota care.
    Our highlander came with the aluminum cartridge and we did use toyota care for the two oil changes on that car. It was super tight the first oil change that I did, but has been fine ever since. I just did the 60k service last weekend with no issues.
    Rick111 and tonered[OP] like this.
