DIY Oil Change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TGAR, Apr 28, 2010.
  1. Apr 28, 2010 at 9:04 AM
    TGAR
    TGAR [OP] Member
    Rochester,NY
    SR5 4x4
    2002 SR5...oil filter looks to be difficult to get to. Had the dealer do the first one free but I have always done my own. Any photos out there for the best approach?
    Thanks
    TG
  2. Apr 28, 2010 at 9:05 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Through the driver side fender. Just remove the guard held on by the plastic clips... I'll get you a link in a second...
  3. Apr 28, 2010 at 9:05 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Turn the wheels all the way to the left and remove the fender liner in the drivers side wheel well. You should be able to get the the filter through there fairly easily.
    edit: too late lol.
  4. Apr 28, 2010 at 9:05 AM
    TacoNut
    Adam
    Denver, Co
  5. Apr 28, 2010 at 10:16 AM
    TGAR
    TGAR [OP] Member
    Rochester,NY
    SR5 4x4
    Excellent resource! Thank you. Sure looks a lot messier than the other trucks I have had. I like the position of the filter in my brothers FJ! That was a great design.
  6. Apr 28, 2010 at 10:29 AM
    TacoNut
    Adam
    Denver, Co
    haha yea, it takes a couple times to figure out how to do it without a mess :eek:
  7. Apr 28, 2010 at 1:10 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    And hopefully they didn't install it with a breaker bar...
    First one I did myself, I had to use a screwdriver for extra leverage to get it unscrewed. I think I ended up having to make 3 holes in it before it was loose enough to finish by hand. Really a pain since there's not a lot of room to work with and it's quite a bit more messy.
  8. Apr 28, 2010 at 1:24 PM
    Boosted17
    Boosted17 Well-Known Member
    Cliff
    Florence, Ky
    Looking for a new Toyota Truck.
    2006 Corvette Z51 M6. Best mod ever!
    I just reach down from the top and go under the alternator. I am able to get a good hold on the filter and take it off. I slide a plastic bag under it to catch some of the oil. This has worked well for me.
  9. Apr 28, 2010 at 3:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I too use the 'reach under the Alt' method for removing and replacing the filter but I must be going overboard by actually removing the skid plates so I can catch all the drippings in the drain pan below.:notsure:
