DIY oil changers ... question ...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dentedporsche, Apr 11, 2024.
  1. Apr 11, 2024 at 3:38 PM
    dentedporsche
    dentedporsche [OP] Well-Known Member
    Ron
    Do you always remove the oil filter drain plug before the filter housing?
    I tried it figuring one less o-ring to mess with and using the useless drain piece that is included in the oem kit ... I was surprised that it was not that messy.
    Is this bad to skip when doing the oil change?
    TacoTime55 likes this.
  2. Apr 11, 2024 at 3:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I've never used the filter bowl drain plug in 14 oil changes.
    jmneill and HondaGM like this.
  3. Apr 11, 2024 at 3:51 PM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    After doing my first change last month, it seemed like an unnecessary step to me. I'll probably stick a new o-ring in there every couple years. lol
    HondaGM likes this.
  4. Apr 11, 2024 at 4:01 PM
    Tacoma Mike
    Southern Maine
    I never pulled that plug ever. One less thing to go wrong. It’s not leaking before the oil filter change, it won’t leak after.
    HondaGM likes this.
  5. Apr 11, 2024 at 4:07 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Don't know how skipping that step can make it bad. Depending on you and how you work it may be less messy if you remove and re-install drain plug. Like anything else don't cross thread, use a new O-ring and don't over torque. Not rocket surgery. 1 extra step and O-ring isn't a big deal unless you're in a NASCAR pit stop rush. That's just me.
    JoshC and HondaGM like this.
  6. Apr 11, 2024 at 4:08 PM
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    Yes because it only takes an extra 4 seconds.
    HondaGM likes this.
  7. Apr 11, 2024 at 4:10 PM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i did it that way once. it is better, but my OCD and fear of not following steps gets the best of me. i still carry the o-ring in my pocket from the one time i did not remove it.
    what would you do with the o-ring that comes with the filter? no way i could throw it in the trash.
    the thought of having to look at 1,2,3......10......15......20 of those in a plastic bin on the work bench scares you know what out of me. it's probably best i just remove the filter drain plug and replace the o-ring.
    HondaGM likes this.
  8. Apr 11, 2024 at 4:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Most of us at the dealer only use the filter drain on the stupid trd skid plate.
    I agree with your thinking, one oring only point of failure.
    So we crack the filter housing loose and let it drain. Remove it, drain residual, put new filter in.
    HondaGM, 3JOH22A and RustyGreen like this.
  9. Apr 11, 2024 at 7:15 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    No way… we all know dealers don’t change filters, or at least don’t put new ones in.
    xguntherc, joba27n, 02Duck and 2 others like this.
  10. Apr 11, 2024 at 7:17 PM
    Bishop84
    I just run out and put a new sticker on the windshield.
    I wait till the customer complains about the maintenance light, I dont have time for these games.
  11. Apr 11, 2024 at 7:23 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    :fistbump:
  12. Apr 11, 2024 at 7:41 PM
    JoshC
    JoshC Well-Known Member
    2023 TRD Off-Road M/T Celestial Silver
    1999 SC 2.4L 2WD 5m/t (RIP)
    Oh man. I hate the new oil filter on the 3rd gen. The filter on my 1st gen made sense. This filter seems like it was made by an engineer with too much time on their hands. Wait what? Why is technology making my life more difficult? I thought the promise of technology was to give me less work, not more.
    e_engstro and 02Duck like this.
  13. Apr 11, 2024 at 7:48 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    I did the first two oil changes, but my last one, I didn't bother, just spun the hosuing off. Didn't seem to make any more/less of a mess than the previous two times. I upgraded to the cast aluminum lexus filter housing from the plastic one the teuck came with when I did the first change. I do replsce the o-ring. None of them have appeared to be damaged/stretched/crushed when I pull the filter hosuing, but the new filter psck comes with them, so I swap them and keep the old one as a "spar," in a ziploc bag in the glovebox.
    Considering a spin-on oild filter adapter, because that would ultimately be less of a pain in the ass.
  14. Apr 11, 2024 at 7:51 PM
    MGMDesertTaco
    Why cut corners? Just replace it.
  15. Apr 11, 2024 at 7:55 PM
    Bishop84
    At the time cartridge was viewed as less environmental impact, also spin on filters weigh more, so freight and shipping costs etc.
    They've gotten rid of all cartridge filters again across the board, thankfully Toyota has learned their lesson.
    2nd gen was easily the best v6 oil change ever. Stupid easy.
    1st was a bit messy but fairly simple.
    3rd gen is easily the worst.
    RushT, FastEddy59, 02Duck and 3 others like this.
  16. Apr 11, 2024 at 8:03 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Haven't tried not draining it first. I guess no different in mess department than metal spin on filters that mount in a similar way. In the back of my mind though, I'd know Mr Toyoda would not approve.
  17. Apr 11, 2024 at 8:17 PM
    Omegastu
    Omegastu Well-Known Member
    Mid Tenn
    2021 Cement TRD Sport DCSB
  18. Apr 11, 2024 at 8:26 PM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Loved the filter on my 05. I ran a taller Wix filter too. That was nice. Larger filtering surface and a tad more oil.
  19. Apr 12, 2024 at 5:11 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I do, by doing so, I get almost zero mess to clean.
    TacoSR523 likes this.
  20. Apr 12, 2024 at 5:26 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    I do but I have the trd skidplate a fumoto valve and the motivex kit. My brother just pulls the whole housing on his trd sport with 250k km. Do it however you like, I like less mess.
