DIY: Painted Wheels
Discussion in 'Wheels & Tires' started by Phi Kai, Mar 4, 2008.
  1. Mar 4, 2008 at 1:09 PM
    Phi Kai
    Phi Kai [OP] Active Member
    O-Town, FL
    2005 BSP DC LB TRD Sport 4x4
    Painted Wheels, Debadged Tailgate, Soon 5100s
    I haven’t seen a DIY for this so I thought I would be the originator!! Anyway, I really like the look of stock wheels. Keeps the vehicle looking factory, but you still have the ability to have all the fancy things. I had a friend who had painted his wheels for an old car of his and I had just been waiting for the right vehicle of mine to do it for. Anyway, I’ll get right in to this because I think it will be a bit on the long side.
    Author: Phi Kai
    Date Published: May 10, 2007
    Contact: via PM
    Title: DIY Painted Wheels
    First of all this will cover all the steps for painting your wheels. However, with my particular set of wheels I went with black with a silver lip look, so it includes a few extra steps.
    Supplies Needed:
    Aircraft Stripper
    Spray Paint (Any Color)
    Automotive Spray on Primer
    Clear Coat
    1” Plastic Putty Knife
    Small Wire Brushes
    Sand Paper (Fine Grit)
    1” Painter’s Tape
    Notecards (optional if you have tires)
    RUBBER GLOVES (absolutely have to)
    Step 1: Take the center caps out…I know obvious
    Step 2: Tape up parts you don’t want painted…(in my case that means the lip) and for everyone that means the valve stem (assuming tires are on). Make sure to do a good job with the taping.
  2. Mar 4, 2008 at 1:10 PM
    Phi Kai
    O-Town, FL
    Step 3: Put your rubber gloves on…at times I doubled up on them… This part is a little laborious and the fumes plus the chemical are killer so be careful. You will be using the aircraft stripper to take the factory paint and coatings off the wheel so that you have a non painted service to work with. It takes quite a while and several sessions of this spray on application to take all the factory paint off. During these steps you will be using the putty knife and the wire brush to scrape everything off. You want to make sure you get everything otherwise you’ll have an uneven surface when you go to apply paint. After you do several coats and have scraped and brushed all the factory paint off, grab a water hose and spray everything clean.
    Step 4: After you get everything stripped and cleaned you will need to use a fine grit sand paper to scuff up the wheel and give the paint an even better surface to stick to. I removed the tape after the stripping because between the water and chemical it has a tendency to un-stick the tape.
  3. Mar 4, 2008 at 1:11 PM
    Phi Kai
    O-Town, FL
    Step 5: See above about taping everything up.
    Step 6: Apply the primer in light even coats. Its probably not crucial to do the primer, but I had some bad luck the first go on these wheels with the top surface being to slippery. I’d give you all tips on spray painting things, but well I’m not so good at it. So do your best.
    Step 7: Paint the Wheels color of choice. Once again I chose black because that’s what I want to do. I probably gave them between 3 and 4 coats of the black…it was on a black primer so it was kind of tough to tell…
    Step 8: Time to work on the Center caps…you were probably wondering since I had left them out up until now…Anyway, I tried to just use the primer and was going to paint over that, but it didn’t stick. I then went to Krylon Fusion, but it didn’t really stick that well either…I ended up giving the center caps a quick light sand to get the paint to stick. You’ll also notice that I left the center circle silver…I had originally tried to tape that part up, but it wasn’t working out so well. Fortunately enough the cap to the aircraft stripper is a perfect fit inside that circle and worked well to keep it silver.
  4. Mar 4, 2008 at 1:11 PM
    Phi Kai
    O-Town, FL
    Step 7: Headed back to the wheels to remove the blue tape covering the lip. Turned out pretty good…
    Step 8: It was time to clear the entire thing…but the tires still needed to be protected. For this I used note cards and stuck them around the outside of the tire to protect the wheel while I sprayed the clear coat. I did about 3 coats of clear.
    Step 9: Get them mounted…I haven’t had a chance to do this as I work and well…the paint is still curing.
    Hope you guys enjoy this tutorial…
  5. Mar 4, 2008 at 2:06 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Good job with the paint and the guide.
    If I attempt something like this I would practice on the spare to be sure I like the finished look before doing all four wheels.... I'm careful like that.
  6. Mar 4, 2008 at 2:08 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Someone is making a splash. Thanks for the tutorial. I've been thinking about doing this for a while.
  7. Mar 4, 2008 at 2:10 PM
    Phi Kai
    O-Town, FL
    Go Big or Go Home...cause I care...It has more to do with the fact that I feel happy looking at this forum...therefore I like to contribute more...and more willingly
  8. Mar 4, 2008 at 2:12 PM
    Phi Kai
    O-Town, FL
    I wish I had a spare around to try it on...I'd kinda helped my friend do it once on a set of wheels...but still...
    I would have done the aircraft stripper several more times...taken WAY more time with tape...and gotten the tires removed...other than that I'm happy...
    Need to get the can of paint out next week when I have some time and touch up a couple of spots on the wheels...no biggy though
  9. Mar 4, 2008 at 2:15 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    when i did mine i didnt strip anything and the only thing i taped off were the valve stems
  10. Mar 4, 2008 at 2:47 PM
    Phi Kai
    O-Town, FL
    I had read and seen before that stripping the original factory coating off was a good plan...not sure its necessary, but a good idea...
    I taped off the outer rim, only cause I wanted that silver...
  11. May 17, 2010 at 6:02 PM
    xxcjtxx
    xxcjtxx Member
    CJ
    Cali
    2008 TRD Sport Black on Black
    anyway you can get the pics up again?
    and how did you end up getting the paint to stick on the centercaps? i used adhesion promoter too and it didnt work
