DIY prinsu style shell rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paranoid56, Nov 23, 2017.
  1. May 26, 2018 at 1:53 PM
    #201
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    I bought a set of 6 for mine, because I had no time to design something for the topper. I will however use something similar as the OP in the future.
    Subway4X4 likes this.
  2. May 26, 2018 at 4:39 PM
    #202
    BeachBoy
    VT & QC
    Working on the cab with my pretty green 3D model :yes:
  3. May 26, 2018 at 4:54 PM
    #203
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I tried to search, but for the life of me, I can't find a reference to these SmittyBilt mounts elsewere on TW. Can you link please?
  4. May 26, 2018 at 5:07 PM
    #204
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  5. May 26, 2018 at 6:31 PM
    #205
    Subway4X4
    Lloyd
    NY/NJ
  6. May 26, 2018 at 6:32 PM
    #206
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What're you going to be carrying up top? If nothing too crazy, 4 would be adequate. I only have 4 feet on my prinsu on my long bed, but I'm never seriously loading it with weight. Just a couple kayaks. If I was planning on a RTT or something, then I'd do 6.
  7. May 26, 2018 at 7:02 PM
    #207
    Subway4X4
    Lloyd
    NY/NJ
    @BeachBoy - I read this whole thread. I’d like to get in line for your turnkey solution (1/4” side, mounting feet, SS hardware) minus crossbars. I currently have a pair of 48” Proline Tracks on a short bed.
    Please let me know when available. Hoping to get these installed soon. Thanks!
  8. May 27, 2018 at 1:29 PM
    #208
    BeachBoy
    VT & QC
    I got 6 on my longbed
    just opened the box a few minutes ago, there's a bunch of reaaaaaly long bolts, hopefully everything is included to install iit, I hate having to go to the store midway when doing something. The hardware is all black that's neat though, but I hope it's stainless.
  9. May 28, 2018 at 3:25 PM
    #209
    BeachBoy
    VT & QC
    Now time to paint and install.
  10. May 28, 2018 at 5:49 PM
    #210
    BeachBoy
    VT & QC
    So it seems the distance 1" between holes for the crossbars is a little too tight on my plates. I have to check if it's my design, the laser cutting or the bars. Then I have to decide if I need to correct or have a slightly larger hole diameter.
    For my set I will simply file the holes a little.
  11. May 28, 2018 at 5:56 PM
    #211
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    This might be the case if one were to assume I only had a one vehicle. Such peasantry. :duel:
    But still doesn't solve the issue of getting sheets of 4'x'8' anything back home.
    If you look at Rocky Mountain's solution.
    https://www.rockymtnracks.com/s/Matterhorn-Assembly-Instructions.pdf
    They use two on either side bolted to the extrusions. The 4runner doesn't have a rail that runs down the sides of the cabs like the 2nd gen tacomas and 4th gen 4runners on.
    so uhm.. does a model exist for an access cab tacoma?? and perhaps a 3rd gen 4runner?
    ready6delta likes this.
  12. May 28, 2018 at 7:19 PM
    #212
    BeachBoy
    VT & QC
    So the culprit are the t-slots profiles.
    They are much less than 1" even though the technical drawing calls for 1" +/- 0.026" (less than 1/32) I think the actual is shorter than that. I would have to double check with my caliper this weekend.
    My next set of side plates I'll make the holes a tiny bit oblong to compensate. That's how a prototype works.
    I also find the profiles are not straight, they curve "down" and I have to check with the supplier if that can be corrected. This picture shows them back to back, the gap means the center of the rack would be about 1/4in lower than the ends. Of course the next set will be straighter.
    ready6delta and kalieaire like this.
  13. May 28, 2018 at 7:21 PM
    #213
    BeachBoy
    VT & QC
    Yes they have short bed, access cab, 2014 and 2011 versions.
    I still have not received the actual cad, the image was an object imported but I can't use it much (not to scale and only a bunch of surfaces).
  14. May 28, 2018 at 7:33 PM
    #214
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Two things:
    The extruded bars i ordered from tnutz were dead on 1" (measured with a caliper) I wonder if its an off run or something. 2: i think the arch in the pieces are due to the heat from plasma cutting. I dealt with that making my roof rack and it was a pain. Aluminum acts weird with any heat at all even from media blasting.
  15. May 28, 2018 at 7:46 PM
    #215
    BeachBoy
    VT & QC
    I didn't think the laser cut would heat that much. I'll chat with the company and see if I can arch my design a little to compensate and make it straight after cut. It's not too bad as you can see in the picture (the actual "droop" is half the gap shown).
    For the position, I will measure with a caliper to make sure, and check different ones as I have over a dozen. But the one I checked was definitely shorter as you can see even with a tape measure.
  16. May 29, 2018 at 3:00 AM
    #216
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Id be interested to see what they say. I tried to correct that same arching on mine and made it worse by over compesating. I also cut by hand which adds another variable. The bar holes suck mine weren't like that.
  17. May 29, 2018 at 8:26 AM
    #217
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    My profound applogies for the mistaken assumption m'lord/eminence/majesty/et al. You didn't mention another vehicle or your title. I have an AC myself and carry 4x8 sheets all the time, sometimes in the bed and other time on the cap rail mounted Thule bars, it's not a problem that they hang over the tail gate by 2'. If it's an issue you want to plan for I suggest increasing the width from the Prinsu standard 47" to something greater than 48". If carrying them in the bed is your only option I suggest a 2 x in the forward elevated notch along with a 4' x 8' sheet of 1/2" ply so the alu sheets stay reasonably flat.
    kalieaire[QUOTED] likes this.
  18. May 29, 2018 at 8:27 AM
    #218
    kalieaire
    Santa Clara County
    Can't use the bed for that at all. Pelfreybilt Swing out and Habitat.
  19. May 29, 2018 at 8:40 AM
    #219
    bagleboy
    Scott
    Norcal, Santa Rosa
    Then rent a uhaul trailer or a truck from home depo. As for heat warping from a plasma cutter, might get better results from water jet cutting?
    Darkgoatracer likes this.
  20. May 29, 2018 at 8:42 AM
    #220
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
