DIY prinsu style shell rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paranoid56, Nov 23, 2017.
  1. May 30, 2018 at 8:12 AM
    #241
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Lol, if people or campanies always acted responsibly there would be no need for regulation. This is just one of those situations where failure at any point should not be considered an option. If the mounts fail then the rack becomes part of the missile the load just became. Individual bar failure might just result in roof damage and I agree that the rack is probably stronger than the roof but it's still on us to prevent such failures by adhering to the weakest link limit.
  2. May 30, 2018 at 8:36 AM
    #242
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    Your long slots seems very wide (high), wouldn't the bars attached there sit lower than the other ones?
    I also see that your start/end bars are much farther from the end than mine.
    The design is very similar though!
  3. May 30, 2018 at 8:37 AM
    #243
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Thanks! I'm gonna go with 47" cross-bars for aesthetics. 50" crossbars seem to overhang over the contoured Cap too much.
    What size bolt hardware did you use to mount the SmittyBilt feet to the Crossbars? 1/4' - 20? I'll need to pick the size so I can pick the right T-nuts.
    Also, price of the SmittyBilt mounts on Amazon went down by $20 bucks from $121 to $101
    Edit: Went back to $121 today. Yesterday, I ordered it at $101.
  4. May 30, 2018 at 10:13 AM
    #244
    BeachBoy
    VT & QC
    I paid $121, lucky bas....
    The hardware:
    For feet to rail I bought 1/4-20 3/4 length with wide washers. Some rail plates are M6 others 1/4-20 (both from Thule)
    For feet to crossbar I bought 3/4 length 1/4-20 carriage bolts with large washer, lock washer and but in stainless. The other option was to use the drop in t-nut but I figured carriage would be stronger.
  5. May 30, 2018 at 10:31 AM
    #245
    Clwrz
    Clwrz Well-Known Member
    San Diego, CA
    2007 Silver Double Cab Tacoma TRD Sport
    How did you go about mounting it since the tracks are not level? Did you add anything else or just tighten everything up and leave the gaps alone.
  6. May 30, 2018 at 11:28 AM
    #246
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Not level how? My tracks are level relative to each other.
  7. May 30, 2018 at 11:36 AM
    #247
    Clwrz
    San Diego, CA
    angeldavid216 likes this.
  8. May 30, 2018 at 11:37 AM
    #248
    Clwrz
    San Diego, CA
    Also what bolts did you use for the tracks? Do you have any photos of them?
  9. May 30, 2018 at 11:44 AM
    #249
    Bannerman
    Johnson
    Charlotte, NC
    Mine dont look like that, those actually look like they may be installed on the wrong side.
  10. May 30, 2018 at 11:45 AM
    #250
    Bannerman
    Johnson
    Charlotte, NC
    Made this with 3/4" aluminum bar and 1/4" SS carriage bolts.
    Varak, GoyoGreybeard and ready6delta like this.
  11. May 30, 2018 at 11:54 AM
    #251
    Clwrz
    San Diego, CA
    You mean the tracks are on the opposite side as they should be? Also, did you use those bolts to attach the feet to the crossbars as well or different ones?
  12. May 30, 2018 at 11:58 AM
    #252
    Bannerman
    Johnson
    Charlotte, NC
    Correct. That is my guess anyway, mine are "fatter" on the outside edge to offset the roof curve. Same bolts just shorter maybe since they need to fit inside the square tube.
  13. May 30, 2018 at 12:12 PM
    #253
    Subway4X4
    Lloyd
    NY/NJ
    I might steal the 3/4" bar stock for inside the track idea.
    Looks like that can distribute any uplift load on the track a lot better than T-nuts or washers. I wish I had the ability to punch in square holes into the bar stock to hold the carriage bolts while tightening.
    Bannerman[QUOTED] likes this.
  14. May 30, 2018 at 12:17 PM
    #254
    Bannerman
    Johnson
    Charlotte, NC
    Thats why I did it that way, I lift the camper shell on and off using the rack, that's the main reason I wanted it.
  15. May 30, 2018 at 3:51 PM
    #255
    bruciep07
    bruciep07 Well-Known Member
    Bruce
    Central NJ
    2015 Sport
    The long slots are only meant to be tie down points, not for mounting cross bars.
    Also, if I drew it over, I’d move the bars out closer to the ends and space the “tie down slots” a little more evenly...
    Subway4X4 likes this.
  16. May 30, 2018 at 6:01 PM
    #256
    BeachBoy
    VT & QC
    Ah now that makes sense! My tie downs are the lower holes.
  17. May 30, 2018 at 6:03 PM
    #257
    BeachBoy
    VT & QC
    Finally had a chance to talk to the guy.
    There is not much you can do in the design as it's not always 100% the same deformation, but you can specify the grain orientaltor and have the hump be higher instead of lower (which is minimal but I still prefer a bump than a dip)
  18. May 30, 2018 at 6:50 PM
    #258
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I'm interested.
  19. May 30, 2018 at 6:55 PM
    #259
    bruciep07
    Bruce
    Central NJ
    2015 Sport
    Think the OP had this in mind, I’m not stepping on his toes in this thread.
    jmaack[QUOTED] likes this.
  20. May 30, 2018 at 7:00 PM
    #260
    jmaack
    Justin
    Helena Alabama
    I understand.
    Whoever decides to do it I am interested. @BeachBoy @paranoid56
