DIY prinsu style shell rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paranoid56, Nov 23, 2017.
  1. Jan 15, 2019 at 9:29 AM
    #781
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Sure i will sell it. Bought it at the end of october. $50?
  2. Jan 15, 2019 at 9:42 AM
    #782
    Clwrz
    Clwrz Well-Known Member
    San Diego, CA
    2007 Silver Double Cab Tacoma TRD Sport
    Ill PM you!
  3. Jan 17, 2019 at 11:43 AM
    #783
    TomTomBikes
    TomTomBikes Does Things "On Purpose"
    ColoRADo
    2015 MGM AC V6 4x4
    none
    Mine is pretty much all there now! Still need to make a fairing, hi-lift mounts, rotopax fuel, and add some camp lighting, but very happy with it. Stainless is an old kickplate from a door and is for attaching anything needed that doesn't fit between bars, roto will probably go up there.
    ready6delta likes this.
  4. Jan 17, 2019 at 11:46 AM
    #784
    Clwrz
    San Diego, CA
    Got any more photos of those traction board mounts? Are they locked? I currently have mine bungeed up there with a lock but hoping to do something a little more secure.
  5. Jan 17, 2019 at 12:17 PM
    #785
    TomTomBikes
    ColoRADo
    2015 MGM AC V6 4x4
    none
    They are just bolted on, I could lock them with a cable I suppose.
    Front are two long bolts through the stainless plate, back are two long carriage bolts with the heads ground so they slide into the track - Both front and back are nutted down so if the boards are off I just have 4 long studs sticking off the rack. Found two pieces of aluminum in my scrap pile that had a slot down the middle that was the perfect width and length for the studs of the traction boards - Would have fabricated something similar, but I got lucky. IMG_0040.jpg
  6. Jan 17, 2019 at 1:01 PM
    #786
    Barnburner
    Barnburner Well-Known Member
    2015 Tacoma SR
    @TomTomBikes rack looks great! I like that length on the MX cap. Any pics showing the whole truck?
  7. Jan 17, 2019 at 1:06 PM
    #787
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    You could probably use wheel locks if you matched the bolt size. Or maybe a hitch lock.
  8. Jan 17, 2019 at 1:17 PM
    #788
    TomTomBikes
    ColoRADo
    2015 MGM AC V6 4x4
    none
    No current ones. I'll have to go find a snowbank to flex on so I look cool.....
  9. Jan 24, 2019 at 7:41 AM
    #789
    ovrlandfam
    ovrlandfam Well-Known Member
    10' dbl cab TRD sport
    Trail gear tube rear bumper, Westin brush guard,
    Questions:
    Did you still go with 47” cross bars for the cab rack? Second, without a wind deflector do you get any whistling/noise at speeds?
  10. Jan 24, 2019 at 2:29 PM
    #790
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I forgot to post pics!
    62198E72-2E01-4490-A0F5-54A2D335AF70.jpg 3D54D9A5-9CB9-4C16-8959-B0C37EC4CDA9.jpg 9EF4245B-ED26-4C94-B0B2-170585EA0979.jpg 6A1C8A0D-4409-45EA-A830-E8BDB8E05115.jpg
    Yes, 47” wide.
    I’ve noticed a ton more wind noise. So much noise that I may remove it until I fab some sort of wind deflector for it. Does anybody else notice a lot of wind noise? My wife rode in the back seat and said she couldn’t even hear us talking in the front seat it was so loud.
  11. Jan 24, 2019 at 2:58 PM
    #791
    WetTaco
    WetTaco Well-Known Member
    Louis
    Northern California
    2012 DCLB 4x4
    Do you have a build thread for that golf cart?? Looks sweet
    MolonLabeTaco[QUOTED] likes this.
  12. Jan 24, 2019 at 3:05 PM
    #792
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    2015 Yamaha Drive 48V
    Jakes 6” long travel lift kit
    23” mud tires
    A few other things
    It’s for sale right now for $4,500, which is a slammin’ deal!!!!
  13. Jan 24, 2019 at 5:43 PM
    #793
    WetTaco
    Louis
    Northern California
    2012 DCLB 4x4
    I'll take it if that's a delivered to my door price.
  14. Jan 24, 2019 at 6:11 PM
    #794
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Ha! Cali is too far for me to deliver.
    WetTaco[QUOTED] likes this.
  15. Jan 27, 2019 at 7:18 AM
    #795
    Toyojo
    Toyojo Well-Known Member
    Joe
    Erie,pa
    2010 mgm dcsb TRD offroad
  16. Jan 28, 2019 at 5:43 PM
    #796
    ovrlandfam
    So I’ve been brainstorming the cab rack based on this thread for my 2010 double cab. My plan is to make the side rails out of steel instead of aluminum mainly Because I can weld it easier. But as I’ve taken measurements of the roof I came up with a few puzzling questions.
    I purchased the 47 inch crossbars that everyone’s recommended and I find those to be a bit too long. For the rack to sit at the outside edge of the roof rain channel the bar should be about 44- 45 inches long. I think I might cut the bars shorter and re-thread the holes on the ends. Anybody have any suggestions or run into similar issues?
    The second thing I noticed is the front threaded mounting points in the roof are further apart (left to right) compared to the rear mounting points in the roof. So if you wanted to the outside of your rack to lineup evenly with the outer edge of the rain channel then the rack would not be square but have a V-shape. The front of the rack would be wider than the rear. Maybe I’m overthinking it. But all these questions came up as I’m trying to come up with an easy way to fabricate mounting brackets to attach the rack to the roof.
    My hope was that I can make a simple L-shaped bracket that would mounts to the roof. Then the inside of the side rails would sit against the outside of the L bracket and then I would just weld them on. But because the roof angles outward towards the front I don’t think that this would be an easy feat. Thoughts?
    I believe the easiest solution will be to make a simple bracket that mounts to the roof and then the crossbars sit on top of that bracket. I would then screw the bracket into the underside of the crossbar utilizing the square nuts.
    I apologize now for my brain overthinking. I try to remind myself that I’m not building a bridge
  17. Jan 28, 2019 at 6:55 PM
    #797
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    The rack will be square because the mounts slide inboard &/or outboard. The front mounts won't be slid in or out as far as the rear mounts.
  18. Jan 28, 2019 at 7:32 PM
    #798
    Dajova
    Dajova Well-Known Member
    2017 MGM TRDOR
    Wow OP this thing is seriously professional looking.
    paranoid56[OP] likes this.
  19. Jan 29, 2019 at 9:40 AM
    #799
    Rebirtha
    Rebirtha Well-Known Member
    Lance
    PDX
    2015 TRD OR DCSB
    Well here is my version for a SnugTop XTR . A lot of backyard engineering went into this . Just couldn’t find a rack or basket that would fit the bars on the shell right so I just made my own :) Still need to tweak it a bit but it’s functional
  20. Jan 29, 2019 at 11:14 AM
    #800
    Rebirtha
    Lance
    PDX
    2015 TRD OR DCSB
    I also wanted to thank you all for the awesome ideas ! Was fun looking through here to see what I could try to adapt to my shell .
