DIY prinsu style shell rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paranoid56, Nov 23, 2017.
  1. Jan 31, 2020 at 9:46 AM
    #981
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    does anyone have a printable template for the sides?
  2. Jan 31, 2020 at 10:10 AM
    #982
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Most if not all seem to go with aluminum at either 3/16 or 1/4 and 2 or 3 mounts per side depending on load. If the mounts go on the cross bars then all the load goes to the screws at either end of those particular bars. The side plates being on edge should be plenty strong, it's the cross rails that are more vulnerable to point loading and the screws that are the weak points.
  3. Feb 10, 2020 at 5:40 AM
    #983
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Great thread! I just spent the last three days reading all 50 pages.
    I'm really happy with my Softtopper and it's versatility and ease of removal so want to build a bed rack around it using side plates similar to what is being created here (most likely out of steel so I can weld vertical supports to them that attach to a plate on the bedrail system) and then use the extruded aluminum crossbars. There was some mention of people wanting to do the same incorporating some of the knowledge shared here.
    Any Prinsu-style Softtopper bedrack updates?
    Can anyone with a water jet or plasma table cut me some functional (aka cool looking. lol) Long Bed plates out of 1/8" steel? Or if anyone has a cool template I could borrow, I could likely make something (less professional looking) work with the cheap plasma cutter I've got.
    Thanks!
  4. Feb 10, 2020 at 7:11 AM
    #984
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    I think he's out of stock right now, but @Barnburner is your man to contact.
    https://www.tacomaworld.com/threads/fs-beachburner-cap-rack-plates-for-short-and-long-beds.592766/
  5. Feb 10, 2020 at 7:12 AM
    #985
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I noticed he was out of stock, too. Also, I'm looking for steel (for easy weld-ability) and not sure if he can accommodate that but I'll try reaching out to him. Thanks for posting!
    MY50cal likes this.
  6. Feb 17, 2020 at 1:45 PM
    #986
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Where did you get these:
    These would work perfect for my DIY RTT mount!
  7. Feb 17, 2020 at 1:50 PM
    #987
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Aluminum square tubing cut down and they come in various sizes. I went with 1in. I’m about to remove it in favor of adjustable mounts.
  8. Feb 17, 2020 at 2:17 PM
    #988
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    X2 on the square aluminum tubing. I went with 1 1/4 to match my Thule rails. A couple of 45* cuts on a miter saw and a couple of holes to attach to the rack and the rails.
  9. Feb 17, 2020 at 2:28 PM
    #989
    ForestRunnerFrank99
    Josh
    Cool! I like the idea. Seems super cheap too.
  10. Feb 19, 2020 at 9:32 AM
    #990
    d.shaw
    d.shaw Well-Known Member
    2012 Silver TRD-OR
    Vagabond Drifter, King 2.5 coilovers, King 2.5 rear, Pelfreybilt front / rear bumpers and skids, rock sliders, Safari snorkel, Smitybilt winch, Baja designs 20in, wide cornering spots, S2 rear. Deaver expedition series stage 3 rear leaf.
  11. Feb 19, 2020 at 4:55 PM
    #991
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
  12. Feb 20, 2020 at 4:58 AM
    #992
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    bagleboy likes this.
  13. Feb 20, 2020 at 5:58 AM
    #993
    Reddy
    Reddy Well-Known Member
    Scott
    Ohio
    '11 TRD OR AC
    OME 885's/Dakars/265's/belly skid
    That looks slick. What hardware did you use to attach the DIY rack to the topper's rack? I'm debating doing something similar with a bedrack.
  14. Feb 20, 2020 at 8:29 AM
    #994
    bagleboy
    Scott
    Norcal, Santa Rosa
    Hinges work pretty well to account for roof slope and you can replace the pin with a carriage bolt and nyloc nut. A plate under each hinge that supports the barrel below and outside would make it easier to locate when reinstalling.
  15. Feb 20, 2020 at 8:30 AM
    #995
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    But it's not going to be a on roof, it's going to be on a bedrack, ie attached to a tube.
  16. Feb 20, 2020 at 8:48 AM
    #996
    bagleboy
    Scott
    Norcal, Santa Rosa
    And you can bolt or weld a steel hinge to that too.
  17. Feb 20, 2020 at 8:52 AM
    #997
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Duly noted. @Rebirtha let me know what you used.
  18. Feb 20, 2020 at 11:17 AM
    #998
    TheTacomaInn
    Rob
    Littleton, CO
    Ain't nobody got time for that! Ha just messing, I do wish I would have just made a second or third set while I was making mine and had everything set up. For now I'm still trying to get rid of all these metal shavings all over my house :frusty:
  19. Feb 20, 2020 at 11:26 AM
    #999
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Understand. If you ever decide to let me know. I’ll buy a set for now mine will work but I really like how clean yours turned out.
  20. Feb 23, 2020 at 8:53 PM
    #1000
    bagleboy
    Scott
    Norcal, Santa Rosa
    They cling to everything but the dustpan, well, that too but they don’t want to go into it. If you’re worried about the router you could duct the top of it to clean, positive pressure air. If your vacuum has a blower use that.
