DIY PVC Water Tank
Discussion in 'Technical Chat' started by themcnertney, Aug 17, 2022.
  1. Mar 11, 2023 at 2:07 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Nice write up. When I built mine I did not see this design. I went with 4” ABS. I built two and mounted under my Rhino Rack cross bars. I run them at 30 psi with no pressure relief valve. They work nicely.
    N64_Wallmaster, jwctaco and steveo27 like this.
  2. Mar 12, 2023 at 8:01 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Looks exactly like my first version, mounted almost identical.
    themcnertney[OP] and Pointeman like this.
  3. Mar 13, 2023 at 3:30 PM
    themcnertney
    themcnertney [OP] Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    Thanks.
    update: decided to go with plastidip as my final outer coating. I used this on my pelican case refurbishment and it has held up very well through most the summer and the mild Ohio winter we’ve had. I recall in the summer months, the case got super hot under the August sun. Figured plastidip would fair well with this water tank. Couple coats over the next few days and I’ll have the tank just about complete. Third and final test to come soon.
  4. Mar 13, 2023 at 7:20 PM
    Pointeman
    Mark
    Keep us posted on the plastidip. I’d be interested in seeing if it helps heat up/retain heat better. I have some in the garage waiting for a purpose.
  5. Mar 22, 2023 at 1:01 PM
    themcnertney
    Dan
    Akron, OH
    Put the last coat of PlasitDip on it today...
    I put a bead of JB Weld Waterweld at each of the seams to insure its sealed. Ill plan to do a water and pressure test within the next couple weeks or so.
    IMG_E1393.jpg IMG_E1390.jpg IMG_E1391.jpg IMG_E1394.jpg IMG_E1392.jpg IMG_E1395.jpg IMG_E1396.jpg IMG_E1389.jpg IMG_E1398.jpg IMG_E1397.jpg
    banditcamp, Pointeman and Wadar like this.
  6. Mar 24, 2023 at 9:47 AM
    themcnertney
    Dan
    Akron, OH
    Very Happy with how it turned out. Gonna have to wait for a warmer day to do a pressurized water test again though. Future Solar Panel between the case and the water tank.
    Pointeman, Wadar and jwctaco like this.
  7. Mar 24, 2023 at 9:59 AM
    steveo27
    Pittsburgh
    Looks good. Hopefully the plastidip holds up.
    themcnertney[OP] likes this.
  8. Mar 24, 2023 at 10:20 AM
    themcnertney
    Dan
    Akron, OH
    And hopefully it works, Haha.
    As you can see on the pelican case I refurbished, it still is holding strong after almost a year and a pretty mild Ohio winter.
    Wadar likes this.
  9. Mar 24, 2023 at 11:12 AM
    Spanky3412
    Spanky3412 Well-Known Member
    Dave
    Northern N.J.
    2020 Cement Offroad
    Just as a public service announcment you shouldn't be putting DWV (Drain,Waste,Vent) fittings under pressure. Schedule 40 fittings have much larger cups on them which translates into alot more glued surface and the fittings are heavier. Personally if I were to put one of these togother I would just use a peice of schedule 40 pipe with 2 schedule 40 end caps and just drill and tap fittings wherever needed. Just my 2 cents.
  10. Mar 24, 2023 at 12:32 PM
    themcnertney
    Dan
    Akron, OH
    Can you be a bit more specific? Just want to make sure that my design is the best I can make it.
    I understand the dangers of pressurizing pvc drain piping. This is where the pressure relief valve will play a role. And the pressure gauge for good measure to insure the pipe doesnt go over 30psi. I was planning to use a small usb air compressor with psi settings,
    https://www.amazon.com/dp/B08JPBHZJZ
  11. Mar 24, 2023 at 3:31 PM
    Spanky3412
    Dave
    Northern N.J.
    2020 Cement Offroad
    Your design looks good it’s just the fittings appear to be DWV in type and are not rated to hold pressure. Schedule 40 PVC pipe and fittings are rated to hold pressure. If you go on Home Depots website and just search PVC you will find DWV and Schedule 40 parts, even better if you go there you will certainly see the difference. Charlotte pipe is the manufacturer of what Home Depot typically sells I'm sure their website would be a good resource for information. The gauge and relief valve are for sure a must have.
  12. Mar 24, 2023 at 4:10 PM
    themcnertney
    Dan
    Akron, OH
    This is very interesting. I didn’t know. Here are the stamps for the 3 fitting. Can you give me some more info on this. Sorry for the orention just how the tube and fitting arrangement is.
    7B2D4AD3-6E83-4A51-9788-E684E6AEC615.jpg 4FCC85DB-5614-40E5-BCC8-B7328EBE39CC.jpg 255A5F28-E39B-4CCA-A08C-D187C2758305.jpg
  13. Mar 24, 2023 at 5:32 PM
    Spanky3412
    Dave
    Northern N.J.
    2020 Cement Offroad
    E38AE04A-78C8-4ED7-93AF-BBD7C978D6AC.jpg C10F8064-738D-4189-872E-5980321496F6.jpg
    I can tell by the shape of the fittings that they are meant for drain or vent lines. See attached for the difference in the two types of fittings.
  14. Mar 24, 2023 at 5:51 PM
    themcnertney
    Dan
    Akron, OH
    I’m starting to understand.
  15. Mar 24, 2023 at 7:44 PM
    #35
    steveo27
    Pittsburgh
    Mehh..
    I put 30psi into DWV ABS and it been fine. The pop off valve will open way before the pipe cracks/explodes/whatevers.
    5 years of real world experience running the set up says you don’t have anything to worry about.
    Pointeman likes this.
  16. Mar 25, 2023 at 6:35 AM
    #36
    themcnertney
    Dan
    Akron, OH
    This is a good thread. I think my design, although not the best as I learn more about this, with the valve and gauge, setting a limit for pressure in, etc. these safety measures are the best they can be.
    Back in august, I did my first test with water and pressure. It seemed pretty successful imo. This was without any safety measures. With all that said, now that I’ve learned a lot more, I think this will suffice my needs
  17. Mar 25, 2023 at 6:45 AM
    #37
    themcnertney
    Dan
    Akron, OH
    Beads water pretty well.
  18. Mar 25, 2023 at 9:29 AM
    #38
    Pointeman
    Mark
    Agreed…Mines going on 3 years and have not had any failures or other issues. With my straight pipe design the 2” filler pipe was drilled and welded in and the JB Weld putty was added to the inside of the holding tank. I figured that would be the point of failure, but so far it has proven itself.
  19. Mar 25, 2023 at 1:52 PM
    #39
    themcnertney
    Dan
    Akron, OH
    I’ll need to purchase the air compressor I want to use, coiled garden hose and shower head then I’ll do a water pressure test.
  20. Mar 25, 2023 at 3:02 PM
    #40
    Spanky3412
    Dave
    Northern N.J.
    2020 Cement Offroad
    Well my 35 years of being a pipe fitter in the HVAC field tells me different. I've seen plenty of pipe failures due to using the wrong materials with injuries involved, sometimes even using the correct materials and installing them improperly. To say the relief valve will open before a failure is false, there is no guarantee there won't be a failure before reaching the relief set point. Even that being said plenty of relief valves fail to operate and cause accidents. Not trying to be dramatic just giving advice based on my real world experience use the information as you will.
    powder1134 likes this.
