DIY: Qi Charging Magnetic Phone FrankenMount (iPhone)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gpb, Dec 23, 2016.
  1. Dec 23, 2016 at 2:39 PM
    gpb
    gpb [OP] Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Content removed.
    Mods think that an image of a dog peeing on a photo of a war criminal is inappropriate.
    I think I won't support this site with my intellectual property.
  2. Dec 23, 2016 at 2:48 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    subd.... this is a future project for sure. Thanks in advance for the write up.
    gpb[OP] likes this.
  3. Dec 23, 2016 at 3:34 PM
    AddicTioN
    AddicTioN Forklift technician
    wyatt
    north carolina mountains
    2020 dclb off road
    Great write up for sure Going to
    Order everything up and do this for sure.
    gpb[OP] likes this.
  4. Feb 3, 2017 at 6:26 AM
    PHLinPHX
    PHLinPHX Well-Known Member
    Brian
    Bucks County, PA
    2023 Tundra CrewMax TRD Offroad 4x4 Limited
    @gpb What are your thoughts on the actual phone case after a month or so of use? Looking for a good QI iphone case, but seems like most have so many mixed reviews.
  5. Feb 4, 2017 at 7:52 AM
    DOSS
    DOSS Well-Known Member
    Scott
    Utah
    2016 Black Tacoma TRD Sport DBCB
    subd
  6. Feb 5, 2017 at 9:23 PM
    Travis17
    Travis17 Well-Known Member
    Travis
    2017 Tacoma Limited
    I tried the magnetic mount on a iPhone 6 Plus S and a Dreem case. But I started to have problems with certain apps and data probably as a result of the magnets on the memory chips in the phone.
  7. Feb 6, 2017 at 5:41 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Great work! I'm lazy though, why not make one for me?
    :D
  8. Feb 11, 2017 at 6:19 AM
    EagleUSMCRet
    EagleUSMCRet Well-Known Member
    Gettysburg, PA
    2017 MGM 4x4 Tacoma DC Limited
    ESR Magnetic Mount MAGSafe charger for iPhone; AVS Vent Visors; Replaced Entune system with Kenwood Excelon Head unit, The Taco Garage DMM for Qi charger, Owl Dash Cam and Motorola GMRS; LED interior light upgrades, ARE Z Cap w/ Yakima Rack, Front Bed Rail, Bed Rug, Tuffy Bed Lock Box, Add a leaf, Pop and Lock, Blendmount and mirror tap for radar detector, AVS Hoodflector, Redline Hood Gas Spring mod. A/C drain mod, X2 Power Premium 27M battery, Debadged the tailgate, Compustar remote start, USB charger for the rear seats, Husky Mats, Lexus Credit Card Transponder Fob, MAG Light mount, twin Hella Sharptone horns, Bedslide, Gasshole, Meso Fuze cover, TRD Gas cap cover, Passenger side locking door handle, Mr. Produxn license place mount, Total Chaos Bed Stiffeners, Valley Runner Tune....help me I can't stop!!!
    I followed your instructions and it worked as you described to a "T". Very happy wit the results.
    Only issue I had was two non cooperating reuse Scoche magnets. Two went on just like you described... the other 2 would not stay in place no matter which way they were oriented. Thanks for the excellent instructions.
  9. Mar 22, 2017 at 6:01 PM
    paradox4286
    paradox4286 Well-Known Member
    San Antonio, TX
    17 TRDOR DCSB P/T JBL
    Your guide was excellent to follow. I did the same tonight in about an hour. I could've done it faster but I've never used JB Weld before and nearly stripped the center screw. Had to drill it out slightly to get it to fit.
    I've ordered the hard wire kit and right angle cable. Plan to tuck the wires this weekend. [​IMG]
    gpb[OP] likes this.
  10. Mar 23, 2017 at 4:15 AM
    paradox4286
    San Antonio, TX
    They had black and white color options if I remember correctly.
  11. Mar 23, 2017 at 5:14 AM
    paradox4286
    San Antonio, TX
    Just checked Amazon again. I lied. No white. I do like the black. It doesn't grab attention. The only thing it grabs is my phone :D
  12. May 29, 2017 at 1:28 AM
    harlequin_forest
    harlequin_forest Well-Known Member
    Oregon
    TRD OR 6MT , 2.0 SFOB
    Oh nice write up! Will definitely keep in mind!
    gpb[OP] likes this.
  13. May 29, 2017 at 3:01 AM
    ffpdfirefighter2002
    ffpdfirefighter2002 Well-Known Member
    Guam
    2017 Tacoma TRD Sport 4x4 MGM DCLB
    Westin HDX drop steps, painted stock Sport rims, Clazzio seat covers
    love the carbon fiber job on the dash trim, you do it yourself?
  14. May 29, 2017 at 4:10 AM
    EagleUSMCRet
    Gettysburg, PA
    I followed the same excellent instructions... changed a bit... used a Ram ball mount with epoxy... and a Hondo Garage un-holey dash mount. IMG_2173.jpg
    opentang and gpb[OP] like this.
  15. Jun 3, 2017 at 7:27 AM
    paradox4286
    San Antonio, TX
    Sorry for the delay in responding. Yeah, I got some 3m vinyl off Amazon, and took my time using a heat gun and patience.
  16. May 9, 2018 at 6:02 AM
    FlyingMonkey
    FlyingMonkey Well-Known Member
    2017 Tacoma OR/LB Quicksand
    Leer topper w/ Prinsu racks. Bilstein 5100's & Falken 285's
    I'm using the Hondo vent mount too. Looks like you're routing the power through the air vent? Are you making a hole in the duct tube and then routing it to something behind the dash? Where are you drawing power from?
  17. May 9, 2018 at 6:23 AM
    EagleUSMCRet
    Gettysburg, PA
    No. I pulled off the silver trim part of the dashboard... using a dremel... I made a round notch large enough for the power wire to fit through with out pinching.... if you need a picture... my truck is in for the 15K mile service and I won’t pick it up till this afternoon.
  18. May 9, 2018 at 6:24 AM
    FlyingMonkey
    gotcha. no picture needed. where did you route it to?
  19. May 9, 2018 at 6:26 AM
    EagleUSMCRet
    Gettysburg, PA
    I plugged the usb into the dc converter and tapped that into the fuse panel and ground on the drivers side above the kick panel.
  20. May 9, 2018 at 6:27 AM
    FlyingMonkey
    did you use a fuse splitter or add-a-circuit thingy?
