DIY: Quickie Front Rotor Change
Discussion in 'Wheels & Tires' started by badguybuster, Dec 18, 2009.
  1. Dec 18, 2009 at 5:07 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Ok. So here we go. I decided to replace the front rotors on my 2006 DC Tacoma TRD. I chose the Power Slot drilled and slotted ones to change too. Since I am not typically mechanically inclined (til I found this website) I am also using my Haynes Manual for direction. I apologize in advance for the pics. I used my cell phone to take them.
    Step 1: Park your truck on a flat surface and set the emergency brake. Chock the rear wheel to ensure it doesn't go anywhere on you.
    Step 2: Remove one front wheel. I did mine one wheel at a time but you can remove both if you want.
    Step 3: Remove the brake caliper. This is pretty easy to do. There are two bolts in the back, one right above the other. Mine were pretty tight so I sprayed them with some liquid wrench to loosen them up. The top bolt is shown in the picture. Instead of removing the metal line coming from the caliper (I advise you to remove it) I just rested the caliper onto a wood block.
    Step 4: Once the caliper is off, try wiggling the rotor off the hub. If it won't budge you can use a bolt to thread it off. You will see a hole in the rotor to the inside. Just thread a bolt into and it will push the rotor off the hub. You may also use a rubber mallet to tap it off instead, if you choose. Once the rotor is removed the hub will look like this.
    Step 5: Use a wire brush to clean off any rust or corrosion off the wheel hub rim. I then added thin line of anti-seize compound to prevent further rusting and to prevent them getting stuck on again. Then slide the rotor onto the hub, ensure to put the rotor on correctly and seated properly. (I used the lugs just to show how it sets).
    Step 6: Re-attach the caliper in the reverse order it was removed. It is not necessary to squeeze the pads back to fit them back on the caliper. Just sit it on the rotor and tap lightly with a rubber mallet. It should slide on easily. Replace the two bolts in the back, it is easier to start the top one first and then place the bottom one in.
    Step 7: Replace your tire and lower the vehicle. Depress the brake pedals a few times to bring the pads into contact with the rotors. Bleeding the brakes should NOT be necessary. Drive a short distance in safe area stopping frequently to check for proper function.
    If anyone has additional tips, feel free to add on.
    Torque Specs: Caliper Mounting Bolts- 91 ft. lbs.
    Wheel Lugs- 85 ft. lbs.
  2. Dec 18, 2009 at 5:09 PM
    badguybuster
    Michael
    P.S.
    This took me about 1 hour to complete from start to finish.
  3. Dec 18, 2009 at 5:20 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    What do you mean i advise your to remove it? Are you referring to the brake line? I cant think of any other line.
    if that's the case I would not remove it. Just make sure that you dont put any stress on the line by letting it hang. If you do remove the line you will have to bleed that caliper.
  4. Dec 18, 2009 at 5:45 PM
    badguybuster
    Michael
    Yep. That is what I was referring to. I put that in there so I don't get blamed if someone drops their caliper and damages the line. CYA!!
  5. Dec 18, 2009 at 6:04 PM
    JAG
    JAG Well-Known Member
    Thanks for the write up! I've got 3 mm of brake bad left it was the dealer said... So I am going to just upgrade the rotors and get new pads... Where did you get the rotors and pads. And have you had any squealing brakes or annoying sounds?
  6. Dec 18, 2009 at 8:59 PM
    badguybuster
    Michael
    The pads are Duratrac that I got from Autozone and the rotors are Power Slot brand that I got on ebay.
  7. Dec 19, 2009 at 10:05 AM
    copernicus
    copernicus Well-Known Member
    91 lbs/ft on the caliper bolt?
    My explorer only needed 50 or so, is that right?
  8. Dec 19, 2009 at 10:16 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    FWIW, I use a piece of bailing wire or a coat hanger to hang the calipers when working on disk brakes. Just tie it off to the spring, and it works like a charm.
    vietstyle559 likes this.
  9. Dec 19, 2009 at 10:40 AM
    badguybuster
    Michael
    According to the Haynes manual it is.
  10. Dec 19, 2009 at 6:14 PM
    badguybuster
    Michael
    Well, when I asked about good rotors these were recommended to me. This was also my FIRST rotor change that i did myself.
  11. Dec 20, 2009 at 6:35 PM
    badguybuster
    Michael
    UPDATE: I took the girl out in the DEEP snow today, to try out the new rotors. I wanted to see how they'd perform with some snow and ice on them. They work fantastic. I was in snow deep enough to pack into the wheel wells! The rotors never missed a beat. I was VERY pleased.
  12. Jan 4, 2010 at 8:59 PM
    JAG
    Thanks for write up... having rotors turned and using your install method for brake pads too.
  13. Jan 7, 2010 at 5:13 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    nice write up. do you by any chance know what the stock size brake rotor was? is it 1.25"?
  14. Jan 8, 2010 at 12:05 AM
    vicstacoma
    vicstacoma Guest
    there's really no need for loctite. just make sure you torque them to spec and you will be fine.
  15. Jan 8, 2010 at 10:59 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Yes, 91 ft/lbs is correct.
  16. Aug 17, 2010 at 2:21 PM
    cyclewvu
    cyclewvu Well-Known Member
    WV
    08 base 4x4 2.7l
    K&N intake & filter, Trifecta Trifold toneau cover, 16" American Racing Fuel wheels, Bridgestone Duelers
    what size bolt will thread into the rotor to pull it off of the hub?
  17. Aug 17, 2010 at 2:25 PM
    JAG
    There are two bolts that hold the air intake assembly base and one of these worked for me. Just remove it... use it... replace...
    That is if you have the 4.0L engine... cuz thats what i got.
    edit i see you have the 2.7. I'm not sure if its the same bolts that hold your intake to the wall of the engine bay.
  18. Aug 18, 2010 at 12:21 AM
    cyclewvu
    WV
    08 base 4x4 2.7l
    It's an 8mm bolt on mine... there are 2 holes on the rotor and I needed to use both of them to get the rotor off!
  19. Aug 19, 2010 at 1:09 PM
    badguybuster
    Michael
    Glad you like it.
  20. Nov 13, 2012 at 8:31 AM
    TacomaNL
    TacomaNL Member
    Ontario
    06 Tacoma Double Cab V6 6Speed Manual
    Greaqt posting,
    thanks so much.
    I have to do front brakes on my 06 tacoma, i also need to replace my calipers.
    Could you give me the quick low down on how to replace the calipers? Ie: removing, replacing, bleeding?
    any helpful hints. I've done brakes before but not calipers.
    Thanks again
