DIY: "Raptor" Style Lights
Discussion in 'Lighting' started by m32, Sep 4, 2013.
  1. Sep 8, 2014 at 12:31 AM
    #181
    gtdad66
    gtdad66 Well-Known Member
    Jesse
    West Ga
    2017 Tacoma Limited
    Front window tint, tool box, bed mat
    Subd too
  2. Sep 8, 2014 at 2:30 AM
    #182
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I like this mod so much and I totally forgot about it until I saw it pop up on the main page again. I just bought 3 LED's from the superbright website, or whatever it was called, Lol. I'll have these things up and running before the trip to the sand dunes. :D
    I love lighting mods.
  3. Sep 8, 2014 at 12:33 PM
    #183
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    Let us know how you wire that up :D!!
  4. Sep 8, 2014 at 8:33 PM
    #184
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :thumbsup:
    I currently have the DRL anytime mod on my dually fog lights setup to work with the fog light switch. I am debating either wiring them in hard to my turn signal DRL's and have them on all the time, or only have them on when I have my DRL anytime mod on.
    I'm not sure which route I want to take it!
  5. Sep 8, 2014 at 8:36 PM
    #185
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  6. Sep 9, 2014 at 9:17 AM
    #186
    alxmlr789
    alxmlr789 Well-Known Member
    Alex
    Orlando, FL
    06 PreRunner DCSB SR5
    5k HID's, Optilux fogs, 265/70/17 Terra Grapplers, NEX4000 Pioneer, Bilstein 5100 2.5 lift, TT AAL + .5" Block, Projector headlights
    subbed for future
  7. Sep 9, 2014 at 9:30 AM
    #187
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
  8. Sep 9, 2014 at 10:49 AM
    #188
    Z E R 0
    California
    02 Tacoma 4x4
    Yes I also debating that, I just want them to turn on at night, so I don't know what to do.. Maybe a separate switch just for those light, or tapping into the parking lights
  9. Sep 9, 2014 at 12:00 PM
    #189
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm thinking since those light remain on constant with the Raptor, that it might be better just to tap into the parking lights circuitry. Not to mention it might look cleaner that way and add a new dynamic to the DRL's and eliminate running the DRL anytime fog light mod itself. I'm willing to try a different look!
  10. Sep 9, 2014 at 1:38 PM
    #190
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Most, including myself, tap into the parking lights wire, so they only come on with parking lights
  11. Sep 9, 2014 at 1:44 PM
    #191
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    This is on my list to do
  12. Sep 9, 2014 at 1:45 PM
    #192
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If the DRL's run on the same circuit though that would indicate that the lights would stay on all the time with the "parking lights." (DRL's).
  13. Sep 9, 2014 at 2:09 PM
    #193
    MTopp
    05 SR5 4x4
    Idk about your trucks 2012-2014, but I just quick spliced into the parking light (aka the light in the upper corner of headlight) not the center/blinker/flasher wiring. Works fine for me as I can switch my parking lights on/off and do not have DRLs in the flasher/blinker area
    I did do a the DRL mod so my blinker bulbs' secondary filament (meant for the DRL, but not factory wired) comes on with my parking lights
  14. Sep 14, 2014 at 1:54 PM
    #194
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Need some opinions before I hardwire this mod. Which looks better?
    Without DRL anytime fogs
    Or with the DRL anytime fogs on
  15. Sep 14, 2014 at 4:47 PM
    #195
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here's how I wired them. I started by tying all the wires in parallel and wired tied them to some small holes I drilled into the back of the grille. This part wasn't difficult, just tedious and time consuming.
    After that I ran my ground to the body.
    Now here came the hard part, just trying to figure out how to wire the power. Initially, I wanted to run it to the DRL only, but the issue with that more then anything was that the DRL uses some kind of funky setup to run, its not just simple power on power off. So I got to thinking, maybe I could just run it with my current DRL fog anytime mod!! Back to wire routing and working I went.
    I pulled the secondary fuse box off of the main box, then pulled off the lower cover as well to expose the bottom where the wiring runs to and ran my wire through an open pin which was coincidentally right next to the pin where the power to the DRL anytime runs to.
    I then snipped the wire to length and added a quick disconnect plug to it.
    Here is where the magic comes from. I took my current DRL anytime relay setup and decided to run a quick disconnect plug from it also. I soldered a loose wire from the one I snipped and this is what I turned out with.
    Plugged it all up and it turned out very clean and simple. You cannot even tell there's much of any wiring there outside of stock at all.
    Final product.
    Thinking about it in retrospect, I will need to add a quick disconnector set to the power wire by the grille and maybe to the negative side as well to enable quick disconnections when re-installing and removing the grille.
    cnote4l likes this.
  16. Sep 14, 2014 at 5:12 PM
    #196
    MTopp
    05 SR5 4x4
    Way more complicated than it has to be. Literally use a red/pink color quick splice to the PARKING light. The smaller, 194 type bulb in the upper outside corners of headlights. Just splice to the power there and then they'll only come on when you turn on your parking lights.
    Just didn't want people thinking they had to do all that above to do this relatively fast easy mod
  17. Sep 14, 2014 at 5:14 PM
    #197
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I did it like this to achieve the stock look and not make it look all weird with splice disconnects.
  18. Sep 14, 2014 at 5:17 PM
    #198
    MTopp
    05 SR5 4x4
    Yeah and that looks great, just didn't want people to be afraid to do the mod that are weary of wiring. I just taped mine up and put some wire loom around it, hard to tell its not an extra wire.
    But either way is perfectly fine, whatever you prefer
  19. Sep 14, 2014 at 5:24 PM
    #199
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :thumbsup:
    5+4=9 and 6+3=9 different methods of achieving the end result but the result has still been achieved. :)
  20. Sep 14, 2014 at 5:26 PM
    #200
    MTopp
    05 SR5 4x4
    Yeah, sorry, I sounded kinda dickish above. It's just when I first started wiring I woulda bee like "wut", but yes, each looks noice
