DIY: "Raptor" Style Lights
Discussion in 'Lighting' started by m32, Sep 4, 2013.
  1. Oct 6, 2015 at 7:21 PM
    #321
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Either comment in the thread like you have
    Or on the right side near the top is a button that says "watch thread" you can do it there too
    Once one or the other is done it will notify you when there is new discussion in the thread
  2. Oct 6, 2015 at 7:22 PM
    #322
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    Thank you man enjoy the page and doing this to my taco next week.
  3. Oct 6, 2015 at 7:23 PM
    #323
    StOrMyThEtAcO
    Cody
    CO
    All of them
    No problem man
    :cheers: Happy moding
  4. Oct 16, 2015 at 9:50 AM
    #324
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
  5. Oct 18, 2015 at 4:37 PM
    #325
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    My lights are still goin strong. Might update them soon with some brighter ones
  6. Oct 20, 2015 at 9:33 PM
    #326
    Ajak
    Ajak Well-Known Member
    ATX
    '07 DCSB Indigo Ink
    I bought 44 LED bolts from superbrightleds.com and 3 of the lenses fell off. If you buy those, maybe super glue the lenses on before mounting them. Now I have 1 with a lens, and 3 without.
  7. Oct 20, 2015 at 9:39 PM
    #327
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Dang when I first read this I saw 44 and thought damn that's a lot of bolt LEDs. I thought I was going to have some serious competition.:rofl:
    dcsbtaco likes this.
  8. Oct 20, 2015 at 9:42 PM
    #328
    Ajak
    ATX
    '07 DCSB Indigo Ink
    Haha, no only 4. Don't know why the forums sometimes change words/numbers. It's done that before for no reason.
    How many do you have?
    MTopp likes this.
  9. Oct 20, 2015 at 9:49 PM
    #329
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Bolt LEDs? None actually, but I do have several strips.
    MTopp likes this.
  10. Oct 20, 2015 at 9:51 PM
    #330
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    2 each its own This I like^^^^^^^
  11. Oct 21, 2015 at 8:13 AM
    #331
    DukesTaco
    AZ
    The only to compet against you is to light their truck on fire. :bananadead:. :thumbsup:
  12. Oct 21, 2015 at 1:06 PM
    #332
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Hm. I thought those would be better quality. I've bought quite a lot on eBay from China and have the same problem with the lenses. And the anodized coating fading in the az sun. I tried super glue and it doesn't really help. I've thought about coating them in a uv protective clear coat. I will try it when I redo all my bolt leds with new ones. I have 14 of them for turn signals. 7 each side in the headlight filler panels. And four more for running lights. Have all new ones ready to install but want to try my clear coat before to see if they last longer. They still work even though ALL of the lenses have fallen off of the turn signal ones.
  13. Dec 2, 2015 at 7:07 PM
    #333
    chenryiv
    chenryiv Member
    2014 Tacoma TDR off road
    How did you mount your light in the OEM grille?
    Tacomalifer likes this.
  14. Dec 3, 2015 at 9:25 AM
    #334
    Biwwip
    Biwwip Member
    Ontario
    2006 SWB TRD Sport
    Hi Chenryiv!
    I did mine the very simple way. I opened the hood, and, using a measuring tape, I marked the desired position of the lights on the top 'bar' of the grill. I did not remove the grill from the truck. I did it all with the grill in position.
    Once I had the proper spacing all marked out, I drilled the holes with my Milwaukee cordless drill, and the appropriately sized drill bit (I drilled a small pilot hole first, using a 1/8" bit, followed by the 'proper-size' bit... I'm sorry, I don't remember the size.) I didn't care much that the drill was on a bit of an angle for drilling the holes, because the plastic is so thin: a bit of a slant in the thin material would make no difference whatsoever in how the light was mounted...
    So, then I threaded the wires up and through the holes, and tightened down the nuts on the threads, and wired it all up. Took next to no time at all. Stopping for coffee and playing with the kid, probably 90 minutes start to finish...
  15. Dec 7, 2015 at 1:23 AM
    #335
    huli467
    huli467 Turning Octopus
    Honolulu
    2015 TRD Sport 4x4
    The world is big...and I want to have a good look at it...before it gets dark - John Muir
  16. Dec 11, 2015 at 6:44 PM
    #336
    DukesTaco
    AZ
    It's between page 1 and 17. I know cause I read it and did it. :rofl:
  17. Dec 11, 2015 at 6:52 PM
    #337
    DukesTaco
    AZ
    Are you using the parking lights or daylight running lights
  18. Dec 29, 2015 at 7:04 AM
    #338
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
  19. Dec 29, 2015 at 7:16 AM
    #339
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    the green is a hot that will not come on with DRL the black is ground and the "blue" which should be on opposite side of the green would be your DRL wire
    EDIT- i used these lights btw https://www.superbrightleds.com/mor...lights/miniature-led-license-plate-bolt/1685/
    Mike likes Tacos likes this.
  20. Jan 5, 2016 at 7:58 AM
    #340
    nugget
    nugget Well-Known Member
    Saskatchewan
    2007 Toyota Tacoma TRD Sport
    sub'd
