DIY: "Raptor" Style Lights
Discussion in 'Lighting' started by m32, Sep 4, 2013.
  1. Jan 6, 2016 at 8:19 AM
    #341
    g60gti
    g60gti Well-Known Member
    K
    WNY The Ruff Buff
    Recently put some in my truck. Used the bolt lights from oznium. I think they came out good. All these lights are looking good in this thread.
    TOY4JMEBOOZE likes this.
  2. Jan 6, 2016 at 8:39 AM
    #342
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    those headlights are the tits.
    JMoCLTNC likes this.
  3. Jan 26, 2016 at 10:10 PM
    #343
    mexitacoma94
    mexitacoma94 El Rojo
    Alex
    california
    06 prerunner DCSB Radiant Red
    LEDS- brakes,reverse,corners,interior/3k foglight hids,raptor style grill lights. - big country brush bars. -BFG rugged terrain (for now). -GTA audio kit.
    how did you remove the painted part of the grill??? :confused:
  4. Jan 27, 2016 at 5:08 AM
    #344
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    There are 12 screws that need to be removed and then pop the clips out to separate
  5. Jan 27, 2016 at 8:09 AM
    #345
    cvisinho
    Rhode Island
    I managed mine with no separation. If you have patience and the right tools it can be done. Just careful pre drilling and boring of the hole with a dremel. Then use a solid flat washer on the top side so when the nut is tightened the light pulls itself tight and self levels to the washer.
    pic attached with zero details of what I just described.
    MTopp likes this.
  6. Feb 1, 2016 at 7:42 PM
    #346
    jarett92
    jarett92 Well-Known Member
    Jarett
    Raleigh, NC
    for those of you with a mesh grille, did you put the led's in front or behind the grille? it's hard to tell from the pics
  7. Feb 3, 2016 at 9:23 AM
    #347
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    All mine are behind the grille (and the mesh insert). :rolleyes:
  8. Feb 7, 2016 at 6:51 PM
    #348
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
  9. Mar 2, 2016 at 5:43 AM
    #349
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    subbed for later
  10. Mar 4, 2016 at 4:11 PM
    #350
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    On 2012+ model, The wire I want to tap into is the green one right?image.jpg
  11. Mar 4, 2016 at 4:44 PM
    #351
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    I connected to green. They come on with parking lights not the drl.
  12. Mar 4, 2016 at 5:03 PM
    #352
    Sterling_vH111
    Sterling
    socal
    Thanks! I did the always on parking lights mod, so my inner ambers are on when the engine in running. I also tested with an ohm/Volt meter and green is correct.
  13. Mar 12, 2016 at 3:52 PM
    #353
    Another_Silver_tacoma
    Another_Silver_tacoma The Silver Stalion
    Jake
    Santa Cruz, CA / Reno, NV
    05 TRD OR AC 4x4
    Yes.
    Any one just connected to the battery? I don't get why that is not an option to have them on at all times.... I'm a wiring dumb-ass though so some one enlighten me. :help:
  14. Mar 12, 2016 at 4:56 PM
    #354
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    You could tap into a circuit that is on whenever the ignition is on, that way they will still turn off when the truck is off but will be on anytime the truck is running regardless of whether the parking, headlights or DTRL are on.
  15. Mar 12, 2016 at 5:50 PM
    #355
    Jake
    05 TRD OR AC 4x4
    Yes.
    That makes sense. Thanks.
    This is what I'm looking for. I want them on at all times, but have DTRLs so the parking lights are only on at night. I think adding the wire to my ignition circuit is my best option! Thanks!
    Blackout14 likes this.
  16. Mar 14, 2016 at 12:43 PM
    #356
    poland6767
    poland6767 New Member
    jeff
    2011 silver Tacoma trd
    Did you get the "10mm bolt beam" from that site?
  17. Mar 14, 2016 at 1:32 PM
    #357
    poland6767
    jeff
    What brand/model raptor lights are installed here?
  18. Mar 14, 2016 at 4:50 PM
    #358
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Um, it's a Raptor grill by HomerTaco, and then I did a little DIY and use a dremel to cut out holes and install my own flush Amber LED lights that are bolt LEDS. Essentially a bolt with a nut on the backside that tightens down, but the end of the bolt is the LED. So they're completely flush and invisible. I ordered them from.... let me look. Oznium I think. Then I wired them into the middle daylight orange lamps.
    https://www.oznium.com/led-bolt
    more info is a few page back when I did it last year.
  19. Mar 14, 2016 at 5:23 PM
    #359
    poland6767
    jeff
    Perfect, thanks.... You remember the diameter of the LED's you used? They range from 6mm to 16mm..
  20. Mar 14, 2016 at 5:27 PM
    #360
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    Yeah.. 11mm.
    4 x Flush Mount LED Bolt - Amber, Aluminum (1W), 11 mm, No Lens, Black = $23.96
    That's what I bought. Got an extra just in case. ;-)
    poland6767 likes this.
