DIY: "Raptor" Style Lights
Discussion in 'Lighting' started by m32, Sep 4, 2013.
  1. Jun 26, 2016 at 7:12 PM
    #401
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Lol I was messing...
    It's more thank just the clear lens tho
    I'll explain later
    At a family outing ;)
    Casper66[QUOTED] likes this.
  2. Jun 26, 2016 at 7:25 PM
    #402
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    Awesome look forward to it.
  3. Jun 27, 2016 at 8:52 AM
    #403
    Jerez
    Rod
    Ontario Ranch
    Estock
    So I don't have pictures at the moment on how i did it.
    But it is a clear lens with the same Oznium bolt led lights drilled into it,
    i wired it into the stock plug so they only turn on when you brake opposed to the actual raptor ones stay dim at night then when you brake it lights up fully.
    i did this only because i wanted to hide my rigid 6 in. sr amber bar away from the back of the truck (dust light)
    was a pain cutting the cab to make fit :anonymous:
    Casper66 likes this.
  4. Jun 27, 2016 at 9:07 AM
    #404
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Oh okay I see thank you.
  5. Jun 28, 2016 at 8:49 AM
    #405
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    I was curious what diodes you used for you lights and where you got them? tacomarcflyer.
  6. Jul 2, 2016 at 12:43 PM
    #406
    tacomarcflyer
    tacomarcflyer Member
    2016 SR5 Double cab V6
    Sorry guys, didn't see this post as we have been having a conversation offline. I used 3 amp rectifier diodes. 1 amp probably would have been fine since the lights don't draw much power but went with the 3 amp to be safe.
  7. Jul 11, 2016 at 3:29 PM
    #407
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Up date I finally got a chance to redo the led lights with the diodes, they work great they blink with the turn indicators they flash when being locked and unlocked. Exactly the end result I was looking for thank you for the info @tacomarcflyer and @m32 for the awesome write up.
    o0oSHADOWo0o likes this.
  8. Aug 31, 2016 at 1:37 PM
    #408
    Flipsyde
    Flipsyde Well-Known Member
    Chad
    Fresno, CA
    06 TRD Sport DCSB 4wd
    I just ordered 4 of these led bolts. I'm sort of a newb with wiring.
    Do I tie in all 4 red positive wires together and tap that into my headlights? Then tie in all 4 negative wires and ground it to the frame or tap it into the negative wire on the headlights?
  9. Aug 31, 2016 at 1:39 PM
    #409
    Flipsyde
    Chad
    Fresno, CA
    Nvm. This might have just answered my own question.
  10. Sep 4, 2016 at 12:07 PM
    #410
    Flannel_Lover
    Flannel_Lover Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    on the parking light, do you tap into the green wire? I am gonna get the rest of the stuff i need to do this mod today
  11. Sep 5, 2016 at 2:14 PM
    #411
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I'm guessing these pull so few Amps, it would be ok to tap into an Accessory slot in the fuse box (inside cab) with an add a fuse to power them? I'm thinking of adding 4 amber (to match my DTR) to my lower grill valence. My 2011 has that honeycomb pattern, so there's no clean spot there to mount them.
    OhioTaco68 likes this.
  12. Sep 6, 2016 at 5:51 AM
    #412
    Sig45
    Mark
    Maine
  13. Sep 6, 2016 at 5:54 AM
    #413
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    This is one of my favorite mod that I have done.
  14. Sep 7, 2016 at 1:52 AM
    #414
    Gabezz
    Gabezz Well-Known Member
    Gabe
    Los Angeles, CA (Montebello)
    '12 Tacoma TRD Off-Road DCSB
    Volant CAI w/Ram Air Scoop, Volant Throttle Body Spacer, Flowmaster SS Dual Exhaust, JBA Cat4ward Headers, Body Armor Side Steps, ProComp 3in Suspension w/Pro Runner UCA's and shocks, Various KC Hilites LEDs.
    Yes, green wire is Positive (+).
    Using an Add-a-circuit should work just fine for Positive (+), although are you going to wire a switch to them?
    Here is my final installed pic, been forgetting to post a pic. Looks real nice at dusk and nite imo.
    although during the day, they a pretty dim, so I just wired them to my parking lights, I can turn them on at dusk, and they light up, since I don't use parking lights in the day. Made sense to me at least haha.
    Sig45[QUOTED] likes this.
  15. Sep 7, 2016 at 3:44 AM
    #415
    Sig45
    Mark
    Maine
    I wasn't planning on a switch. Just want them to come on when the DTRL's come on (but without tapping/splicing into any factory wiring). I figured an ignition related accessory slot would work fine. Or I could tap into the DTRL fuse.
  16. Sep 7, 2016 at 5:38 AM
    #416
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Why not just wire directly to DRL's since the wiring is right there next to where the LEDs will be in the grille?
  17. Sep 7, 2016 at 5:59 AM
    #417
    Sig45
    Mark
    Maine
    I just don't want to tap into/splice any factory wiring in the event I ever want to remove them.
  18. Sep 7, 2016 at 11:52 PM
    #418
    Gabezz
    Gabe
    Although I understand what you mean, in my opinion, it truly would be easiest, and certainly safe to just use a T-Tap connector to splice into the DTRL if that's how you want them to light up. I used those 3M t-taps and they are quality connectors. If you wish to remove them it should cause no issues, just some electrical tape over the splice. Either way, it was a fun little mod!
  19. Sep 8, 2016 at 3:59 AM
    #419
    Sig45
    Mark
    Maine
    Appreciate the info on that product. It would certainly cut down on the length of wire I'd need to run. I'll certainly look into it.
  20. Sep 8, 2016 at 4:51 AM
    #420
    Sig45
    Mark
    Maine
    Another quick question...
    Any difference in wiring if I run:
    1. All 4 LED wires into 1 (both power & ground and heavier gauge of course) and then connect to power source & ground - this may be too thick for a butt connector?
    2. 2 LED wires into one (twice) and then those 2 into one and then connect to power source & ground
    I'm thinking with the spacing of the LED's and depending on the length of the wires - option 2 seems more practical.
