DIY: "Raptor" Style Lights
Discussion in 'Lighting' started by m32, Sep 4, 2013.
  1. Sep 8, 2016 at 6:05 AM
    #421
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  2. Sep 8, 2016 at 6:34 AM
    #422
    Flannel_Lover
    Flannel_Lover Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    I did this mod the other day, still trying to solve my wiring gremlins, not very good at wiring. Sometimes they all work, sometimes the ones on the right don't work, and more recently the one to the left of the Toyota badge won't work, I did 4 lights all together, going to get creative with wiring tonight to try to connect them all once and for all and be sturdy and work all the time.
  3. Sep 8, 2016 at 11:17 AM
    #423
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    When I wired mine originally I wired all 4 positive wires together and ran spliced them into the parking light wire, tied all 4 ground wires together and ran to the ground wire behind the battery. Make sure to get a good solder on all the connected wires. If you run them to the DTRL they will turn off when you turn the head lights on. I have sense rewired mine to the DTRL's with a 3amp rectifier diode in between the wires so they blink with the turn signals and flash when I lock/unlock the truck. I then tied them into the parking lights with another 3am diode to work when the head lights are on. I did the same thing on both sides so the two flash with the right side turn signal and two flash with the left side. It is more wiring but the end result was worth it to me.
    :cheers:
  4. Sep 8, 2016 at 11:24 AM
    #424
    Sig45
    Mark
    Maine
    Thanks!
  5. Sep 8, 2016 at 11:50 AM
    #425
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    of course..Good luck.
  6. Sep 8, 2016 at 11:52 AM
    #426
    Sig45
    Mark
    Maine
    Just need to find an easy way to access that lower valence to drill the 4 holes. Hoping to do it w/out removing grill.
  7. Sep 8, 2016 at 11:59 AM
    #427
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    The best and easiest way I found was to remove the grill, even with the grill out and everything taken apart it is still kind of a pain. Also when you tighten the bolt keep in mind there is a allen head on the light it self makes it easier to get all snugged up.
  8. Sep 8, 2016 at 12:05 PM
    #428
    Sig45
    Mark
    Maine
    I was hoping to tackle it from under my truck by removing the skid plate. The lights arrived today and I saw that allen head. They are much heavier duty than I thought.
  9. Sep 9, 2016 at 6:43 AM
    #429
    Flannel_Lover
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    I didn't notice the Allen head until AFTER I got pissed and just used silicone to secure them in. :rofl: I don't know how long they will hold but I hope they will, there is a lot of silicone in there.
  10. Sep 12, 2016 at 12:02 PM
    #430
    rdietz65
    rdietz65 Well-Known Member
    robert
    Fayetteville. GA
    2013 Tacoma Pre-Runner Sport
    OMG, so many options on these amber Raptor lights. Which is best? Help!
    Oznium vs. SuperBrightLEDs?
    Side View Bolt vs. Flush Mount Bolt?
    Beam Angle: 180dgrees vs. 60 vs. 110 vs. 120 vs. 18?
    Lens or No Lens or Epoxy?
    1W vs. 3W?
    LED Type: COB vs. 5050 SMD vs. 3528 LED?
    .5 lumens vs. 3 vs. 14.7 vs. 8 vs. 50?
  11. Sep 12, 2016 at 12:19 PM
    #431
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    When I got mine I spent a few days doing research on them all. I went with the ones from Oznium I am very happy with them they blend in with grill even in the day time when they are off. They are very bright for their size. I love mine its one of my favorite mods I have done. I hope this helps out a little
    Gabezz likes this.
  12. Sep 12, 2016 at 8:59 PM
    #432
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I would go with the brightest(most lumens), 60 degree beam angle(because you wont be able to see these from the side anyway), side view bolt LED.
    Waaaay too many options for me though. I'm glad I just lit up the whole grille. :D
  13. Sep 28, 2016 at 12:59 PM
    #433
    rdietz65
    robert
    Fayetteville. GA
    ok everyone, I think I've decided on the Oznium 11mm flush mount 1W amber LED in black housing. But I have a question for all you experts. I cant decide whether I am going to mount them on my 2013 OEM grill facing down or out. And I cant decide whether to get these with lens (60 degree light disperse) or no lens (180 degree). What are the advantages/disadvantages of both? Will the lens or no lens dictate whether I am going to mount them facing down or out? Thanks in advance.
  14. Sep 28, 2016 at 1:39 PM
    #434
    white_knight
    white_knight Well-Known Member
    UT----> MN
    2016 White Tacoma Off-Road
    Icon Stage 4
  15. Sep 28, 2016 at 1:47 PM
    #435
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    I mounted mine facing out and I couldn't be more happy with the out come
  16. Sep 29, 2016 at 5:23 AM
    #436
    rdietz65
    robert
    Fayetteville. GA
    Thanks Caprizzy. And did you buy the Oznium 11mm flush mount 1W?
  17. Sep 29, 2016 at 6:55 AM
    #437
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    I used the Oznium lights that the OP posted the link too
  18. Oct 8, 2016 at 10:56 AM
    #438
    Ads5689
    Ads5689 Well-Known Member
    Finally got around to doing my raptor grill and LEDs. Came out pretty sick.
    Jonny22r, TortyB and o0oSHADOWo0o like this.
  19. Oct 8, 2016 at 11:01 AM
    #439
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Dam! bloodied knuckles on a raptor light mod. Don't ever drop a tranny. You might lose a hand. Lol
  20. Oct 8, 2016 at 6:21 PM
    #440
    breader3
    breader3 2016 TRD Off-Road 4x4
    Brad
    Las Vegas
    Finally got mine wired. Add a fuse to the headlight low beam circuit.
