DIY: Replace Rear Center Slider
Discussion in 'Technical Chat' started by tacabode, Mar 28, 2016.
  1. Mar 8, 2019 at 5:54 PM
    tacabode
    tacabode [OP] Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    :worthless:
  2. Jun 18, 2019 at 9:51 AM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
  3. Jan 24, 2023 at 10:48 AM
    4sfire
    4sfire Active Member
    southern South Dakota
    Current: 2015 TRD Sport 4x. Past: 1998, 1991, 1985 Toyota 4x4 trucks.
    Leer camper shell Westin Brush Guard Springer Spaniels
    I just finished replacing my rear slider about a minute ago. When the window arrived I thought it might not fit (it is 13-5/16" x 13-5/16" x 1/8") but it did. I used a Leatherman knife blade for making the cut, a plastic prying tool for prying things out and pushing them back in, and some dry lubricant. I have not sealed it yet. Thanks for the tutorial, as I would not have figured this out on my one!
  4. Jul 12, 2023 at 4:00 PM
    tacabode
    Ohio
    '14 MGM DCSB TRD OR
    Glad I could help. I haven’t touched the RTV on mine since I put it there in 2016. No leaks.
  5. Jul 13, 2023 at 6:47 AM
    Emmohl
    Emmohl Well-Known Member
    2019 SR5
    This thread always makes me smile when it pops up. I had gone for a surf at an out of the way spot and locked myself out of my truck. I had to make it back down to my kids daycare before they closed. Had no way to call anyone. Smashed my slider out and got my keys. Hauled butt! I had enough time to stop at a gas station and vacuum the glass out. Made it in time. Almost seven years ago. Good memories!!
    tacabode[OP] likes this.
  6. Sep 12, 2023 at 9:42 AM
    Eskimobob
    Eskimobob New Member
    Bobby
    Alaska
    2013 base, 4.0l Double Cab
  7. Sep 24, 2023 at 6:17 PM
    TacoSeth
    TacoSeth Member
    2014 Tacoma V6 TRD; 2015 Highlander
    It does appear this could work. Except I ended up not even needing to peel back the window seal because I replaced it with clear poly-carbonate. I didn't want this breaking ever again, and since I have a topper that also has tinted glass I preferred to have it not tinted so I could see better. The bracket is held in place with trim adhesive foam, so that would need to be replaced.
    I do like using the poly except I now see exactly how curved the proper glass is supposed to be. With the poly being straight you can see where the seal doesn't touch the straight poly in the middle. I bought some additional window seal to see if that would fix it. The poly is perfectly clear and looks great.
    You're the real hero for posting these exact specifications. The only other place I found that has dimensions said 13.5"x 13". That probably would have worked too since I can see how you're is a bit wider but not so much that it comes outside the trim. But I was really concerned.
