DIY Satoshi Grill for under $30 (2004 style grill)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tonka, Apr 26, 2015.
  1. Apr 26, 2015 at 10:51 PM
    Tonka
    Tonka [OP] Pro-Darwinism
    Taylor
    America's Basement
    14 DCSB prerunner 04 AC 4x4 TRD OR. '16 DCSB 4x4 TRD OR
    '04 265/70R16 Dueler A/T, Softopper, Bilstein 5100's, Toytec AAL, DIY Satoshi, Midland CB, ARB front. Self fabb'd rear bumper. Smittybilt X20 winch '16 custom car grill, Cooper ST Maxx
    today I decided I was going to build myself a Satoshi grill for my 2004 tacoma... I went to Lowes and I purchased all items I needed for $23.93 (I had a dremel, saw, magic markers, and black enamel spray paint etc)
    Note: this will probably work for all 1st gens
    List of Items:
    1. 2 part epoxy - I used Gorilla Glue brand $5.48
    2. Dark Gray Spray paint $6.88
    3. wire mesh (found in building materials at my lowes) $10.21
    4. Dremel
    5. coping saw
    6. sand paper
    7. black enamel spray paint
    8. pair of dikes... the tool
    9. masking tape
    Step 1. Remove the entire grill from the truck, I did not get a picture of this... but it was super easy
    Step 2. cut out all vertical pieces approx 1/4" from the bottom of the grill the 12 0'clock strut needs to be cut off (it wont hurt anything)
    Step 3. You will need to take the dremel and grind down all remaining plastic until it is flush all around
    Step 4. Sand with 80 grit to smooth it all out... then again with 120
    Step 5. trace your grill onto a piece of cardboard... then cut it out
    Step 6. place cardboard on wire mesh and cut-- leave about 2-3 inches around cardboard
    Step 7. trim to around until it fits into the grill use the remaining lengths to wrap around the edges to hold it into place
    Step 8. use epoxy to glue the edges all the way around (don't use all of it yet)
    Step 9. tape it off and paint
    Step 10. remove the large 'TOYOTA' emblems from the tailgate on the drivers side
    Step 11. scuff with sandpaper
    Step 12. paint with whatever color you choose
    Step 13. use remaining epoxy to glue 'TOYOTA' emblems to the grill
    Step 14. marvel at your awesome ass grill
    Step 15. clear coat
    Step 16. clear coat
    Step 17. clear coat
    Step 18. install the same way it came off...
    I will be sure to get more photo's. It took me about 3 hours to complete (excluding dry times) and by the time I was done it was dark and couldn't get a good photo but here are some in the mean time. Also, after trimming the vertical struts I noticed the bottom was solid and the top had gaps... I decided nobody would ever see the top so I didn't fill it with fiberglass...
  2. May 21, 2015 at 11:02 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    any final product pictures?
  3. May 22, 2015 at 7:47 AM
    teehext
    teehext Well-Known Member
    Tyler
    CA
    2001 PreRunner SR5
    Interested in finished pics in the sun too. I was eyeing that Lowe's mesh but wasn't sure if it would be too seethrough...
    Awesome work OP!
  4. May 22, 2015 at 12:09 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Awesome, cool and cheap. Might try this with a donor grill for my 95.5. Did you happen to see any finer mesh? No Toyota emblems on my tailgate (painted on). Was thinking about just spray painting TACOMA with stencils in white. Maybe paint the mesh gunmetal beforehand.
  5. May 22, 2015 at 12:59 PM
    eltacoutah
    eltacoutah Well-Known Member
    Ben
    Utah
    2010 TRD Sport
    I will be doing this soon!
  6. May 22, 2015 at 1:02 PM
    Red_Taco33
    Red_Taco33 Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    Definitely going to give this a try :wink:
  7. May 26, 2015 at 1:52 PM
    Tonka
    Taylor
    America's Basement
    I was also put off by the size of the mesh but it was the best expanded aluminum I could find without ordering online.. I finally have pictures also
    Edit: I swapped out the Toyota emblem to the one I pulled off my 2014, not sure how I like it but it'll do for now
  8. Apr 7, 2018 at 10:06 AM
    TacoHoss
    TacoHoss Member
    Nick
    2004 silver Tacoma
    2” lift. FJ Cruiser spare 17” wheels wrapped in BFG Mud Terrains.
    Hi there. I just picked up a Tacoma a couple days ago, 2004. I was looking for cheap but cool upgrades that I can do when I came across this. If you still have it, can you let me know how it’s holding up after almost 3yrs? Thanks so much. Sorry for the resurrection, but hey, sometimes it’s fun.
