DIY: Secondary Air Filter Removal
Discussion in 'Performance and Tuning' started by 007Tacoma, Jul 7, 2007.
  1. Feb 13, 2009 at 7:55 AM
    #201
    Deer Slayer
    Deer Slayer Active Member
    NW Mississippi
    08 4X4 I4 MT Acc Cab
    I took out my seconary air filter last night, but I haven't noticed much difference. this is on a 08 Access Cab 4X4 I4. Maybe a little bit of quicker response at lower speeds in first and second gear, but not much else. After reading all the extremely positive feed back over here, I was disappointed that I didn't notice much of a differnce :(.
  2. Feb 13, 2009 at 7:57 AM
    #202
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont be too disapointed. I noticed no improvement on my truck, and Gadget has noticed nothing as well. Removal of the filter has no affect on the engine as far as performance goes.
  3. Feb 13, 2009 at 8:02 AM
    #203
    007Tacoma
    007Tacoma [OP] I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    On the V6, I agree. I didn't notice a difference. However, on my 4 cylinder, I did notice the difference.
    I don't think that this modification (or any intake modification) does too much of a benefit without exhaust modification and remapping of the fuel injection. I noticed more benefit out of my cold air intake after I ripped a big hole in my muffler. :p
  4. Feb 13, 2009 at 8:08 AM
    #204
    Deer Slayer
    NW Mississippi
    I guess what bugs me is that alot of people were talking about the huge difference they noticed and made out to be a real big deal, so it was a let down for me when really nothing happened.:(
    Stewzz likes this.
  5. Feb 13, 2009 at 8:09 AM
    #205
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!!
    Thing is, in the tests I have done, the filter STILL flows more air than the throttle body will allow. Seems the air intake on the Tacoma doesnt really hinder the air flow like many people would like to belive. the biggest restriction seems to be the airbox it self. Gadget found this to be true also. The only way to have a gain seems to be with the URD intake. I have seen gains of 2 or so h.p. with the TRD intake, and others along the same design, but nothing when doing anything to the existing intake design. I agree that exhaust needs to be considered as well as an intake (the engine is, after all, an air pump) for best results, but it seems the more engines progress in efficiency, the harder it is to get any gain with bolt on mods.
  6. Feb 13, 2009 at 9:32 AM
    #206
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I guess you missed the thread where I showed the whole I punctured in the front of my muffler by hitting a wood palette in the middle of the highway, huh? :p
    I love my URD intake, but it is mostly for the sound at wide open throttle when I am passing some numb-skull doing 45 MPH in the left lane. I noticed a bit of increase in mileage (probably ~2 MPG) when I actually drive it nicely. However, I don't think that the intake alone is enough to get some real efficiency out of the truck. If I dumped the 265 All Terrain tires, I am sure I could get some better MPG. The intake does little to help the power output for normal driving conditions.
    ...but damn it sounds good. :devil:
  7. Feb 13, 2009 at 1:57 PM
    #207
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well, my exhaust on there there as well, doesnt hurt either.
  8. Feb 14, 2009 at 8:08 AM
    #208
    Rockstar2448
    Rockstar2448 Well-Known Member
    Maryland
    05 Indigo Ink TRD Sport D-Cab LB 4x4 // 2020 Super White TRD Sport D-Cab LB 4x4
    2005: Toytec 3" Lift, Helo Maxx6 Chrome 17x8, Nitto Terra Grappler 265/70/17, Polished Billet Grill-Full Front Kit, Westin Polished SS Tube Steps, Leer 700 Tonneau, Fog Lights On Anytime, Debadged, USA Spec iPod Adapter, Britax car seat with special UNC color scheme, Window Tint, SilverStar bulbs 2020: TRD Skid Plate with front spoiler delete, emblems partial removal/blackout, Toyota folding hard tonneau
    From my experience, if you have a 4.0 don't bother with this mod at all. It seems to work better on the 4cyl, although I can't verify that. I did this mod and ran it for a little while. I think my MPG actually was slightly worse? I put the filter back in. It's really no need in wasting you time with this mod.
  9. Feb 25, 2009 at 3:34 PM
    #209
    wnealw
    wnealw Active Member
    Fredericksburg,Va.
    08 tacoma 2wd
    scanguage,thrush turbo muffler wellded in.
    Well pulled it out today. Just for something to do. Typically I get about 30mpg on my drive to and from work about 130 miles aday. I'm more into seeing what I can get for mpg. 08 2.7 reg cab 2wd.
  10. Mar 1, 2009 at 8:39 AM
    #210
    06yoter
    06yoter Active Member
    Tampa/ Plant City, Florida
    06 Prerunner TRD Sport
    Doug Thorley long tubes, flowmasters, URD TCAI, custom dent in the bed from a fence
    can someone please make a fancy guide for the secondary air filter like they did with the 2.7 in line 4 motor? or did someone make one alredy. i cant find it.
  11. Mar 1, 2009 at 11:16 AM
    #211
    beastlytaco
    Ian
    08 Access Cab SR5
    look at the first page. its with a 4 cyl
  12. Mar 14, 2009 at 8:38 PM
    #212
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    This statement is accurate. As for all combustion engines, by allowing more air to enter requires a improved flowing exhaust to evacuate it. Likewise, allowing more air leans out the current fuel mixture. For there to be any realized benefit, more air will require more fuel. This tweaking can be improved only within the limits of the power plants design. Every engine has its limitations. Lean power is often sought after, but can be harmful if too thin. Not that you could cause an excessive lean condition with this mod... even if you opened the exhaust at the header collectors and removed the air box completely. An extreme example and certainly harmful, but not from too thin a fuel delivery level.
  13. Mar 22, 2009 at 10:12 AM
    #213
    BrianB
    BrianB Active Member
    ABQ
    13 DCSB TRD
    Removed mine just now. Took all of 3 minutes. Un-hook the two clips holding the top of the air box on, cut a slit in the secondary filter and just rip it out. That has to be the most stupid thing I've seen for a long time. Why? You can't tell me there is a benefit for that. Emissions? It's AIR! There is no emissions GOING IN!
    I'm sure the government made them do it. Just like the TPMS deal.
    Burky likes this.
  14. Mar 22, 2009 at 4:04 PM
    #214
    beastlytaco
    Ian
    08 Access Cab SR5
    its suposed to help filter emissions after the engine is already turned off. i really didnt see the point anyways.
  15. Apr 21, 2009 at 9:15 PM
    #215
    08toyoamn
    08toyoamn Its For Sale. :(
    Central, OR/ Tacoma WA.
    08 AccessCab, 4.0L, 6spd
    duel polished aluminum tips, 44 flowmaster, 15% tint all round, 3" TOYTEC-spacer/AAL, TRD true cold air, tinted tails, bumper mounted B/U's, 6k HID, Painted Grill -- on the way -- black billet grill
    i have had a 3" lift and 33" BFGs for about 5 tanks now and it droped from ( the best...) 24 mpg to around 17mpg and thats all highway... after removing the secondary and adding a new K&N im getting at best 19 driving all highway around 60mph... around 70mph and a heavy foot its around 17... not the best but it does help... and all the driving is over the mt. hood pass US26 in OR... 4.0 6 CYL 6 spd... seems to work enough for me ! :)
  16. Apr 21, 2009 at 9:22 PM
    #216
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Any gain you have seen was due to the K&N, or slightly different driveing style. The charcoal filter has no affect on the engine.
  17. Apr 25, 2009 at 8:03 PM
    #217
    tt07
    tt07 Well-Known Member
    north carolina
    01 4wd
    none yet
    Thats it mine is coming out!
  18. Apr 28, 2009 at 8:24 PM
    #218
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    I beg to differ, removing obstruction will always help at higher engine speeds. Cruising you won't see much difference. But passing or rapid acceleration you'll have a little more top end. That's my experience.
    Burky likes this.
  19. Apr 28, 2009 at 8:27 PM
    #219
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On the 4 cylinder it may help.
    FWIW, I have tested this stuff on a dyno, flow bench, etc. Thats my experience.
  20. Apr 28, 2009 at 8:41 PM
    #220
    lawnrevenge
    Southern California
    I have no experience on the 6 cylinder. A dyno is better proof than anecdote. I missed that he was in a 6cyl. The only benefit I've heard of for a 6 is the supercharger.
