DIY: Secondary Air Filter Removal
Discussion in 'Performance and Tuning' started by 007Tacoma, Jul 7, 2007.
  1. Apr 29, 2009 at 6:13 AM
    #221
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    True. A good exhaust and headers helps too, but the price per hp is high.
  2. May 2, 2009 at 9:37 AM
    #222
    Hops
    Hops Well-Known Member
    Gabe
    south mississippi
    08 Silver Streak Mica Access Cab 4X4
    Shock and leaf spring TSB, Neoprene seat covers, weathertech digital fit floor mats, vent visors, bug shield, secondary filter removed, K&N drop-in filter, century camper shell, 265/75R16 ATM's...
    Just removed the secondary filter and installed a k&n air filter on my 4.0 v6. Noticed a 200 to 250 rpm decrease at 70 mph. Should help on the gas mileage but i havnt put a tank through yet so i'll let yall know when i do...
  3. May 2, 2009 at 3:53 PM
    #223
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rolleyes:
  4. May 12, 2009 at 6:44 AM
    #224
    gearhead69
    gearhead69 Member
    05 Tacoma Pre
    Anybody tried an underdrive crank pulley for more power and better mpg. Seems like a good idea? Might have a cooling prob when hot weather and towing hard, or maybe stop and go too? I don't thin the alt, p/s or a/c would be affected to much, maybe at idle a little? Anyone have experience?
    Thanks
    gearhead69
  5. May 14, 2009 at 6:53 PM
    #225
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    I removed the secondary charcoal filter and haven't seen any difference on my '09 V6. It did not look like the filter offered any resistance to airflow at all. Maybe they changed it to be less restrictive.
  6. May 14, 2009 at 7:07 PM
    #226
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Who knows. Gadget tested it on his 06, I tested it on my 07, and niether of us has seen a difference. I belive that who ever does this feels a "Placebo" affect.
    Electrathon likes this.
  7. May 14, 2009 at 7:14 PM
    #227
    gearhead69
    gearhead69 Member
    05 Tacoma Pre
    HOPS, I'm sorry but the secondary air filter is not related in any way to your gear ratio. But could help your mpg by uncorking your airflow.
  8. May 18, 2009 at 3:03 AM
    #228
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    When claiming that there are no measurable improvements to mileage or performance please keep in mind that there are two completely different engines and several different drive trains in these trucks. What might be unnoticable on a supercharged V6 4WD automatic driven enthusiasticly can make a noticable difference on a carefully driven 2.7L 2WD 5 speed.
  9. May 20, 2009 at 6:13 PM
    #229
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Just not sure how air flow relates to lower engine RPM at driving speeds, it's not like you changed your transmission fluid to a thicker viscosity or locked the tranny or better, if you have a manual tranny... How can this corrilation be made. I would think they are not related at all and just reinforces my theory below.
    After reading all this and other related threads (farmed out from this one), it looks that there may be a minor improvement in MPG, minor being the key word. Some of the larger MPG improvements (2 MPG or more) could be easily attributed to a lighter foot on the pedal. You may think you're driving the same but you are trying to strech that fuel and as a result get more MPG.
    I hope this makes sense to everyone. With that in mind I'm going to replace my air filter with a dry high flow filter as most of my driving is freeway speeds. If I can squeeze a real 1 MPG more, I'm for trying it.
    Joe
  10. Jun 19, 2009 at 1:36 PM
    #230
    Blaise22
    Blaise22 Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    I just tore it out not thinking, do they check for the secondary filter? As long as its in there sealed around the edges blocking emmisions it will pass right or are you not allowed to tamper with it at all?
  11. Jun 19, 2009 at 1:37 PM
    #231
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Youre fine. But before you tare at your car again, think. ;)
  12. Jun 19, 2009 at 2:07 PM
    #232
    Blaise22
    Blaise
    California
    Thanks, and will do:cheers:
  13. Jun 28, 2009 at 11:49 AM
    #233
    jjohns
    jjohns Member
    Tucson, Az
    07 PreRunner SR5
    luminics headlights and fogs, URD intake, aries bull bar, mag light seat mount
    has anyone with the 4.0L noticed a difference either in MPG or power?
  14. Jun 28, 2009 at 12:02 PM
    #234
    commtrd
    commtrd commtrd
    Corpus Christi TX
    No increase in mileage AT ALL. I removed it and could just about see through it never mind air flow thru the thing. It is considerably more porous than a freaking sieve. Just leave it in place it offers absolutely no restriction to airflow. At least the one on my '09 I am not sure about any earlier models. I removed mine for no good reason...same as running super unleaded.
  15. Jun 28, 2009 at 6:09 PM
    #235
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well roland has a point. my 4 speed automatic, when warmed up, runs at about 650 RPMs i can cruise all the way till I hit 50MPH at 1500 RPMs. so I wouldnt say that its totally not worth it. in my case it drastically helped with rpms and even MPG
  16. Jun 29, 2009 at 11:04 AM
    #236
    markrome1957
    markrome1957 New Member
    New Hampshire
    08 Tacoma access 2wd
    I was prepared to do this mod but found that no secondary filter is installed in my truck. My build date was 1/2008. Could it be this secondary filter is not standard in the NH area...or have the engineers relocated the filter?
  17. Jun 29, 2009 at 8:06 PM
    #237
    beastlytaco
    Ian
    08 Access Cab SR5
    it should stil be there. right above your regualr paper air filter in the air box.
  18. Sep 16, 2009 at 10:55 PM
    #238
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Ditto! No need to remove it. My MPG didn't improve. If you want better performance do the throttle body cleaning.
  19. Sep 23, 2009 at 7:49 AM
    #239
    WunSick
    WunSick Sofware Engineer / Habitual Line-St
    Denver
    Blue 07 PreRunner
    Did this last night, took 5 mins. Removed the K&N filter, took a flat head screw driver and popped the thick charcoal filter off... Checked to make sure there was no plastic bits in the housing, even though there is a metal deal that keeps crap like that out... put the K&N back in, no issues. Too early to tell about MPG, but throttle response is noticeable. Good little mod :)
  20. Sep 23, 2009 at 11:53 AM
    #240
    007Tacoma
    007Tacoma [OP] I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Yeah, I guess people don't read the first post. This was really intended for the 2.7L 4 cylinder engine (which I no longer own).
    I did not remove the secondary filter on my truck. However, my URD TCAI completely removes the filter housing from the truck. I have my original housing complete and in tact just in case I want to go back to stock.
