DIY: Secondary Air Filter Removal
Discussion in 'Performance and Tuning' started by 007Tacoma, Jul 7, 2007.
  1. Dec 22, 2011 at 3:10 PM
    #441
    LadTacoma
    LadTacoma Well-Known Member
    Ray
    NJ
    Prime Mover
    bruddas...no need remove charcoal filter esp on new V6. Just drop in aFe Dry airfilter, keep tires properly inflated & drive like you own it not stole it. You get 21mpg. Pretty good to me from a V6 Tacoma :)
  2. Dec 22, 2011 at 3:19 PM
    #442
    LadTacoma
    Ray
    NJ
    Prime Mover
    tha's it, am "ripping" mine out! :D:D
  3. Dec 22, 2011 at 5:47 PM
    #443
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Make sure you're going forward after this mod, going backwards y'll likely unintentionally slam into something since you're not used to it.
    Take it slow. ;)
  4. Dec 31, 2011 at 9:21 PM
    #444
    dmhart32538
    dmhart32538 Member
    midland
    2011 Tacoma SR5
    XM radio
    To All Tacoma Charcoal air filter removal questioners: I removed mine 2 weeks ago. I keep good records on fuel consumption. I see no realistic change in fuel consumption since removal. I drive a route and change my driving habits very little. It was easy and worth a try, but do not expect anything special. Good luck, DMHart
  5. Jan 1, 2012 at 5:02 AM
    #445
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    What kind of mileage do you expect from a 4.0 v6 and a truck that goes 4100lb Dbl cab 4x4. My job allows me to drive home some of their full size trucks once in a while and the 6.0 litre chevy you can watch the gauge move towards empty when your driving. The mileage is about 9-12 at best.
  6. Jan 18, 2012 at 3:06 PM
    #446
    Taco 05
    Taco 05 Active Member
    Peyton
    Livingston Tennesse
    05 Tacoma reg cab 4x4
    I did this and felt a little more power but nothing incredible. Waiting to fill up to see what kind of mileage i'm getting. hoping that will go up a little bit. Great write up though. Was very easy with this thread.
  7. Jan 22, 2012 at 12:24 PM
    #447
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    It will pass emissions without as long as they dont check for it.
  8. Jan 27, 2012 at 12:52 PM
    #448
    SDrock Taco 05
    SDrock Taco 05 New Member
    Justin
    San Diego
    Tacoma TRD Sport
    I placed an AFE intake and a throttle body spacer into my 05 V6 tacoma and was wondering if that removed the secondary filter?!?
    I'm sure this question was already answered but browsing through the 20 some pages i did not finder it.
    If it is still there that would mean the filter is on the engine side of the throttle body and not toward the filter side.
    Knuckle head me could not distinguish were the filter was in the pictures at the beginning of the thread and i could not see the 2nd filter on the original air filter or air tubing i took out
    Thanks
  9. Jan 27, 2012 at 5:11 PM
    #449
    worthywads
    If you are replacing your stock air filter it is on the top side of the hood over your filter.
  10. Feb 13, 2012 at 2:51 PM
    #450
    cball917
    cball917 Well-Known Member
    Johnathon
    NE GA MTNS
    2010 Tacoma Woods and Water Edition
    black out package. custom decals, fogs
    i went to remove my secondary filter today and noticed that PO has installed a K& N. i do know the k & n allows more air flow, so my question is will it allow too many particles through ??? if so i guess i need to leave secondary filter in right?
  11. Feb 21, 2012 at 6:25 PM
    #451
    UNDEAD1153
    UNDEAD1153 Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    Went to attempt the air filter removal a minute ago but chickened out visioning the one thing that went wrong with the truck would be because I removed it and messed the truck up. What would be things that could go wrong in doing this and what would be the chance of something going wrong?
  12. Feb 21, 2012 at 7:09 PM
    #452
    worthywads
    Nothing can go wrong, your chance is zero.
    All it does is prevent gasoline vapors from exiting through the intake.
    But it will not improve your mpg if that's what you are hoping for.
  13. Feb 22, 2012 at 3:52 AM
    #453
    UNDEAD1153
    Weston
    Not really looking for mpgs, just thought I'd give it a try. Any reason the dealer might look at it during service or something?
  14. Feb 22, 2012 at 4:42 AM
    #454
    UNDEAD1153
    Weston
    Also I'm just trying to get the mesh filter out is all? I could just take a screw driver and a knife to pry the thing out?
  15. Feb 22, 2012 at 5:05 AM
    #455
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yes & yes..........
  16. Feb 22, 2012 at 3:17 PM
    #456
    UNDEAD1153
    Weston
  17. Feb 22, 2012 at 3:33 PM
    #457
    worthywads
    No, No, and define better sound?
  18. Feb 22, 2012 at 3:37 PM
    #458
    UNDEAD1153
    Weston
    Anything really....tb spacer type whistle....better engine noise...anything?
  19. Feb 22, 2012 at 3:43 PM
    #459
    worthywads
    weight reduction, 3oz tops
  20. Feb 22, 2012 at 3:47 PM
    #460
    UNDEAD1153
    Weston
    Sweet.....not even goin to touch it....
