DIY: Secondary Air Filter Removal
Discussion in 'Performance and Tuning' started by 007Tacoma, Jul 7, 2007.
  1. Jan 1, 2013 at 3:40 PM
    #541
    Foxbat
    Foxbat Member
    Pennsylvania
    06 Tacoma
    Step rails
    This post was an awesome find. I just dropped in an AFE and was trying to pull out the secondary and cracked it. My intent was to check it, clean it if possible, or replace it. This post saved me some grief because tomorrow I will take the secondary out. Nice and Thanks!
  2. Jan 22, 2013 at 4:01 AM
    #542
    SonDa5
    SonDa5 New Member
    Tacoma
    If you take out this secondary fixed filter which looks like it rest directly against the main resusable filter seems like the main filter may get loose because the secondary filter isn't applying pressure to it. On a bumpy road it may move around and crap my by pass through the side.
    I'd like to try this mod but it seems like to many risks for little gain.
  3. Feb 11, 2013 at 7:15 AM
    #543
    gary2
    gary2 New Member
    new-brunswick
    yes been customise
    i took the2 air filter out and my engin light came on
  4. Feb 11, 2013 at 9:41 PM
    #544
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    What info do We have on winter gas?
    It plays a part in poor fuel milage?
    And is it not true that 87 octane has more energy than 91 octane with ethonal?
    Right now I've got 200 lbs of sand for winter weight and low tire pressure for traction. So...Its a bad time to make good gas milage.
    I do have a winter-front on the grille to keep the engine at running temps. If i knew that i could get a block heater that would work in my 2010 4.0L I'd buy one. I get mixed reviews on block-heaters.
  5. Feb 11, 2013 at 10:29 PM
    #545
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    87 vs 91 makes no difference in the BTU content.
    Ethanol does reduce BTU content, so yes, "pure" 87 (if you can get it) has more energy and will deliver better fuel economy than ethanol-contaminated 91.
  6. Feb 12, 2013 at 8:30 PM
    #546
    RELLIM
    IOWA CITY IA
    We have 87, it's $3.67/gal. What do you pay per gal?
  7. Feb 12, 2013 at 9:02 PM
    #547
    Rich91710
    Rich
    Los Angeles
    08 Base
  8. Feb 15, 2013 at 8:16 PM
    #548
    tacotruck 2.7
    tacotruck 2.7 Well-Known Member
    Katy TX
    09 cab and a half 2.7
    im considering removing the sec air filter on my 09 2.7 taco can somebody please illustrate or point out where ths "6 rivets" are on the saf so i can dril em out. my eyesight aint like it use to be. thanks muchachos.
  9. Feb 15, 2013 at 8:26 PM
    #549
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    It's more difficult not being able to find the rivets. They stick out around the edge of the filter. You should be able to find them with your eyes closed. Take a look.
  10. Feb 15, 2013 at 8:31 PM
    #550
    Rich91710
    Rich
    Los Angeles
    08 Base
    They aren't really rivets... they're just pins that stick through the sec filter and they are melted down with a hot iron tip.
  11. Feb 25, 2013 at 9:02 AM
    #551
    TacoLoco2001
    TacoLoco2001 New Member
    2001 4X2
    mine is an 01 4cylinder2.4 will this work for mine??
  12. Feb 25, 2013 at 11:27 AM
    #552
    worthywads
    I don't think you have one, but it doesn't work for 2nd generation either.
  13. Feb 25, 2013 at 8:09 PM
    #553
    Rich91710
    Rich
    Los Angeles
    08 Base
    LOL!
    My '03 Tundra 4.7 had one.
    Didn't do anything for it either... dunno why I did my 2.7. All I need is some anal-retentive smog tech and it'll cost me $300.
  14. Mar 2, 2013 at 11:45 AM
    #554
    jimbowie
    jimbowie Member
    Jim
    north texas
    07 4dr prerunner v6 trd
  15. Mar 2, 2013 at 7:21 PM
    #555
    Rich91710
    Rich
    Los Angeles
    08 Base
  16. Mar 5, 2013 at 7:26 PM
    #556
    RELLIM
    IOWA CITY IA
    About the MAF Screen... It corrects the flow of air into the MAf..? My GF has a 04 Subaru Forrester XT 2.5 It has a Denso MAF that has no screen and the engine has a turbo..
    The subie maf part number is 197-6040
    2010 Tacoma maf part number is 197-6030
    Any ideas or info on this?
    I'm wondering if it would work to take the screen off.
    Part numbers are not the same but the shape of the MAf is the same.
  17. Mar 13, 2013 at 7:18 PM
    #557
    piglett
    piglett Member
    wolfeboro,nh
    01 exstended cab TRD
    lots of pages on this subject....wow
    ok so it does work on the 2.7L, cool
    does little or nothing on a 4.0L, well ok
    any info on the 3.4L?
    mine is a TRD do i have the same airbox as the later TRD's?
    thanks for your input
  18. Mar 13, 2013 at 7:19 PM
    #558
    worthywads
    No it really doesn't work for the 2.7L.
  19. Mar 21, 2013 at 5:17 PM
    #559
    beastplumber
    beastplumber New Member
    Gary
    Kennard Indiana
    2013 Tacoma V-6 (SR5)
    K&N Air filter, WET in the rad. Rain-X wiper blades
    DO you know if removing the secondary filter voids the manufactueres warranty???
  20. Mar 21, 2013 at 5:31 PM
    #560
    worthywads
    No it doesn't, but it is rather pointless, and in many states you could fail emissions.
