DIY: Secondary Air Filter Removal
Discussion in 'Performance and Tuning' started by 007Tacoma, Jul 7, 2007.
  1. Mar 22, 2013 at 8:36 AM
    #561
    piglett
    piglett Member
    wolfeboro,nh
    01 exstended cab TRD
    ok my 01 tacoma doesn't have one
    also no sign that there was ever one there
  2. Mar 22, 2013 at 7:43 PM
    #562
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    My '03 Tundra had one.
    Wife's '04 Rav4 doesn't.
  3. Mar 24, 2013 at 4:13 AM
    #563
    joedelli
    joedelli Member
    connecticut
    09TacomaSR54x4
    My truck does have one. I removed it for inspection and found it to be distorted, "charcoal" element had settled and the vacuum from the engine was trying to suck the screen/gauze into the engine. I will get a replacement filter. However, with the charcoal filter gone, a KN installed and tonneau, I get consistently 20 mpg all around and better throttle response. BTW the KN does work (the paper filer is too restrictive. The tonneau makes sense as well (before, its like dragging an anchor, and it worked on my Dakota). I probably can't ask more from this truck as is. Its a daily driver 52 R/T and my fun off roader.
  4. Mar 24, 2013 at 10:15 AM
    #564
    Rich91710
    Rich
    Los Angeles
    08 Base
    You have absolutely no flowbench data to back that up.
    I'm getting 24mpg on the OEM filter.
  5. Mar 24, 2013 at 10:54 AM
    #565
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I continue to get great mpg with a OEM with 40K on it. I'll change it at 60K.
  6. Mar 24, 2013 at 10:59 AM
    #566
    Rich91710
    Rich
    Los Angeles
    08 Base
    Bingo.
    The K&N does flow "better" than stock, but to say that the stock filter is "too restrictive" is submitting to K&N marketing hype.
    And even Amsoil admits that their washable filters (AFE) do not filter as well as OEM.
  7. Apr 10, 2013 at 8:55 PM
    #567
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    WeatherTechs, Console Vault, OEM Bed Mat, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, Exterior Cargo Net, OEM Toyota Cargo Divider, Cobra CDR 840 Dash Cam, Sliding Rear Window Security Bar, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Full Debadge except TRD OEM Red Tailgate Badge, Undercover SE Tonneau
    Ok. Thanks to Rich & Worthywads I'm NOT doing this mod, slightly interested before - slightly, but now after hearing some logical info on the subject - I think not.
    Thanks guys - Rich, Love your Truck - very tasteful, classy, and economical.
    Question though: Can you point me to the info about AFE saying their filters aren't as good as OEM? Just curious cause I just bought an AFE based on all the damn hype on these forums. I've been running OEM air filter now for 30k miles.
  8. Apr 10, 2013 at 9:35 PM
    #568
    Rich91710
    Rich
    Los Angeles
    08 Base
    Interesting... Amsoil (AFE) seems to have modified their marketing and is now claiming significantly better filtration than cellulose.
    But here's some real-world test results of several filters:
    http://www.bobistheoilguy.com/airfilter/airtest3.htm
    Also interesting, related to the "how much is 'good enough' question:
    http://www.bobistheoilguy.com/airfilter/airtest2.htm
    "Best" was the K&N at 0.231psi
    "Worst" was Napa paper at 0.249psi.
    Having a hard time finding the charts that used to be posted.
    I found one that showed the Amsoil to be equal to quality cellulose, but it appears to be referring to the 2-stage foam filter.
    Anyways, a couple of years ago, Amsoil's marketing materials included a very good chart comparing 5 or 6 filters, including K&N, AC Delco, foam, and a couple of other "paper" filters.
    The graphs showed the "paper" (cellulose) being the most restrictive, but the best filtration. The Amsoil (AFE) came in below paper on filtration, but significantly higher than K&N... but with marginally better flow than K&N.
    Could be that those charts were removed because Delco wasn't happy about it? I don't know.
  9. Apr 11, 2013 at 6:14 AM
    #569
    piglett
    piglett Member
    wolfeboro,nh
    there is a difference between how well something flows & how well it filters. removing the filter all together will give the best flow but no filtering. so which one are we after???
  10. Apr 11, 2013 at 9:22 PM
    #570
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    So.. What's better for fuel mileage? More or less flow? This whole filter thing gives me
    a headache. I want good fuel mileage but don't want to be confined to paved roads.
    I really don't like k and n, filters. They are a pain in the ass to clean and oil.
    I like foam filters, they have been used for years on the track, only problem is I can't find one that fits as a drop in filter. There is one made by Blue Monkey I believe.. Not positive..
    Im not sure I'll upgrade to a cold air intake, to many problems with not enough choices of piggy back tuners.
  11. Apr 11, 2013 at 11:10 PM
    #571
    Rich91710
    Rich
    Los Angeles
    08 Base
    Given the minimal difference in flow....
  12. Apr 15, 2013 at 9:30 PM
    #572
    EatMyTacomaDust
    Well after installing my AFE yesterday and comparing it to my OEM Denso Air Filter, I can see the difference. Yes the AFE will give better performance due to less air restriction, not a significant difference though. I mean, If I didn't know i had changed air filters, I wouldn't know - ya know?
    I'm going back to OEM after I use this AFE for a while. The OEM Denso is literally 3 - 4 times thicker in my opinion. I'm looking the for best filtration, I'm not worried about performance, if I was, I wouldn't be driving a 2.7L or even a 4.0L 6 for that matter.
    Conclusion - Stick with OEM Denso Air Filter. Thanks for the links. Good tests, I've been to BTOG's site a few years back. . . Bums me out about the Napa results. I did a ton of research after I bought my Tacoma regarding which Oil Filter to use and I came to the conclusion that the Napa Gold by WIX was the best / and easily available. . .
    Not falling for the AMSoil hype anymore though. I've been using it since my truck was new. Just changed my oil on Sunday after 5700 miles - hate going that long but it was the first chance I've had to get to it - 5700 MILES - AMSOIL was JET BLACK. This is the AMSoil that claims 25k between Oil Changes - Well I'm calling BULLSHIT!
    Done with it, switching to Mobil One, at least I'll save $2 / Quart.
  13. Apr 15, 2013 at 9:51 PM
    #573
    Rich91710
    Rich
    Los Angeles
    08 Base
    A lot of the perceived performance difference, especially with CAI units, it the noise.
    The engine sounds like it's making more power, and added power actually felt is mostly from the throttle being mashed a bit more.
    Drive normally wearing a pair of earplugs and the difference won't be so pronounced, as you saw with the replacement filter in the OEM box.
  14. May 23, 2013 at 6:26 PM
    #574
    Fryguy
    Fryguy New Member
    Saskatchewan, Canada
    '07 TRD DC LB
    Rancho rs9000xl shocks & coil over quick lift, added a leaf on rear springs, k&n a/f, removed secondary charcoal a/f, raider topper, led lighting in box, led map/dome/console in back seat and front foot wells, led under hood lights, led parking lights, led dtr/signal, painted factory wheels black, aux jack from factory stereo, blacked out head light assembly, debadged tailgate, battery terminals in cubby of box, wireless back up camera, stainless cloud rider grill inserts painted black on reverse side, towing reciever added to front frame, anytime fog lights, rocker guard black nerf bars and skid plate, plasti dip badges black, black "taco" badge in hood scoop
    Going to do this right now!!
  15. May 28, 2013 at 9:33 PM
    #575
    TacoTruckDriver
    TacoTruckDriver Member
    Northern Nevada
    Factory Standard Taco
    Custom Bed Mat
    That filter has to eventually go bad. Are there any after market upper-air boxes? I have not been successful in finding any online that look like they fit.
  16. May 28, 2013 at 9:48 PM
    #576
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's not a filter, so it won't go bad.
    It is a sack of activated charcoal pellets and it captures fuel vapors that come back out of the throttle body after the engine is shut down.
    When the engine is restarted, the fresh air pulls the captured hydrocarbons from the charcoal.
    As long as the air filter is changed regularly and not replaced with an oiled element, the secondary mesh will last the life of three Tacomas, just like the charcoal canister in the evaporative control system on the fuel tank.
  17. Jun 17, 2013 at 10:09 AM
    #577
    RedDead
    RedDead Well-Known Member
    Missouri
    2016 DCSB TRDOR
    if its sole purpose is to capture fuel vapors ..does anyone have an explanation on why removing it effects the 4cyc more than the v6?
  18. Jun 17, 2013 at 3:41 PM
    #578
    worthywads
    No, just a rumor with no backing.
  19. Jun 17, 2013 at 8:38 PM
    #579
    Rich91710
    Rich
    Los Angeles
    08 Base
    It doesn't.
    It's psychological, just like a CAI.
  20. Jun 27, 2013 at 6:44 AM
    #580
    Cardiackid
    Cardiackid New Member
    Jim
    Columbus, Ohio
    01 Toyota Tacoma Ext.SR5
    Magna Flow Exhaust, K&N Air Filter
    Installed KN air filter and replaced plugs @ 90K......increased mpg by 2-3 mpg.
    I also got great MPG when traveling to/from Moore, OK to CBUS,OH running 75+ mph with A/C running.....around 24 mpg.
    Go TACO!
