DIY: Secondary Air Filter Removal
Discussion in 'Performance and Tuning' started by 007Tacoma, Jul 7, 2007.
  1. Nov 4, 2020 at 9:24 AM
    #881
    Ozblitz
    Ozblitz Member
    Ozzie
    2015 PreRunner
    K&N air
    Oh, ok. I didn't think to look in the air filter location since there is an air filter in there already. Will this void any warranty or cause the engine to be less protected from dirt.
  2. Nov 4, 2020 at 9:29 AM
    #882
    Kolby
    Kolby Active Member
    Kolby
    2015 v6 Tacoma 4WD Sport
    This is an emmissions filter that blocks harmful pollutions from coming back out of the engine when. The truck is turned off. As long as you don't have the cheapest air filter you can find and check it once in a while you should have no issues. HOWEVER I am not responsible for any damage and I wouldn't do it if your truck is under warranty as dealerships will try to find any way to void your warranty.
  3. Nov 4, 2020 at 9:52 AM
    #883
    Ozblitz
    Ozblitz Member
    Ozzie
    2015 PreRunner
    K&N air
    I'm running K&N so, its a good filter. If it's there to filter air "out" from the engine, then it should not harm the eng. because it doesn't filter "in" So, I guess I will be doing the mod. I bought a separate warranty not from Toyota, so chances are if anything ever happens Toyota will want the work. (Knock on wood) Rather nothing ever happen. Thanks for your help
  4. Nov 4, 2020 at 9:57 AM
    #884
    Kolby
    Kolby Active Member
    Kolby
    Excellent filter choice! I recommend the mod. I get better acceleration as it's basically removing an air restriction. But mpg is unchanged for now... ECM should catch on soon. Glad to help!
  5. Dec 24, 2020 at 7:40 PM
    #885
    Sheepnick1
    Sheepnick1 TacoJerry.com
    Nick
    Lynchburg Virginia
    2019 Tacoma trd off road
    I'm convinced! Mine is coming out this weekend!
  6. Jan 2, 2021 at 8:17 AM
    #886
    along16
    along16 Well-Known Member
    2020 DCOR
    Can’t imagine much difference after nothing noticeable after doing a KN drop in.
    davidstacoma likes this.
  7. Jan 15, 2021 at 3:45 PM
    #887
    Magiriano
    Magiriano Underdog by Doekter TUNED
    Alex
    Calgary, Alberta
    2022 4Runner TRD PRO 2023 Tacoma TRD PRO MT
    Westcott Front lift with Eibach Pro Coils, Icon AAL rear, 17" Rims on 285/70/17 Toyo Open Country AT3 Load Range E, Full PPF Clear Wrap, Diff breater relocation, Greenlane Offroad Stump Bumper, Greenlane Offroad full engine skidplate, Greenlane Offroad Transmission Skidplate, RA Motorsports Gas Tank Skidplate, DEFA Trickle Charger with Cab Heater, CBI DOM 120 Rock Sliders, Greenland Offroad cab height Box Rack, Sherpa Roof Rack with Baja Designs S8 Lightbar, Tailgate lock, Underdog Tune by Doekter TUNED
    Subscribed
  8. Feb 1, 2021 at 6:53 PM
    #888
    ToynbyuTicotex
    ToynbyuTicotex Well-Known Member
    Central Virginia
    1999 Xtra cab V6
    I just removed mine as well. Test spin tomorrow.
    On a separate note: I notices a small pool of red vicious substance on the garage floor this morning, this liquid had pooled up in the skid plate on the passenger side. needless to say , I was a bit (a lot) alarmed, with only 400 miles on the odometer, I was not happy. Just as I was going to call Toyota Care and have my new truck towed to the dealership, I decided to wait a day and ask my friend the wench turner what he thought. Then I saw this thread and decided to get rid of the secondary charcoal filter. That is when I discovered the source of the mystery red goo. You see the day before I bought and installed a K&N filter.... It was the residual oil from the filter that pooled up in the air box and came out the drain and made its way to my garage floor via the skid plate. So thanks to all for this thread. Not only will my V6 breath better! but you saved me the embarrassment of having the truck towed to the dealership only to find out that is was the filter that I installed.
  9. Jun 19, 2021 at 12:19 PM
    #889
    rdcowan
    rdcowan Member
    Robert
    NW Florida
    2017 Silver Tacoma Access Cab, SR5, 4 cyl, Automatic
    I made this mod to my 4-cyl truck just two days ago (6/17/21) and then took a short trip down I-10 and back in NW Florida through a section that I've done many times and have monitored the 'Eco' bar graph showing minute-by-minute mileage. Now...let me tell you....I'm an old retired engineer that keeps a log of all the gas into the truck and what the MPG is for each fillup. I was amazed at the changes in the behavior of the truck as I went UP/DOWN the hills along the highway. First...it didn't downshift as aggressively when I went up a hill with the cruise engaged. Also, the sound was much smoother and quiet...not that 'growl' that I was used to hearing. Lastly, the ups and downs of the bar graph was much shallower as it was getting better mileage on both the uphills and downhills. I got 26+ mpg over a 140 mile trip and usually I was lucky to get 24.5. I'm a fan of this mod!
  10. Jul 17, 2021 at 1:58 AM
    #890
    zorino
    zorino New Member
    1998 toyota tacoma 2.4 2wd
    nobody has said anything about the 2.4 l
    Have a 1998, would the modification worked for me?
  11. Jul 17, 2021 at 3:31 AM
    #891
    rdcowan
    rdcowan Member
    Robert
    NW Florida
    I'd say give it a shot. (Does your 1998 even have the secondary filter?) It would make sense that your 2.4 would get some benefit from some added intake flow. Report back with the results!
  12. Jul 17, 2021 at 1:13 PM
    #892
    zorino
    zorino New Member
    VERY GOOD QUESTION, lets me check and I will get back to you
  13. Jul 18, 2021 at 9:14 PM
    #893
    zorino
    zorino New Member
    After checked and reviewed,
    the 1998 Toyota Tacoma 2WD 4 cylinders 2.4l doesn't have a secondary filter.
    You are right RDCOWAN
    Thank you.
  14. Sep 30, 2021 at 4:00 PM
    #894
    TacoSteve556
    TacoSteve556 Member
    Stephen
    2016 2.7l Taco
    Stock
    Just checked my 16 2.7, it will be removed this weekend!! Buh BYE!!
  15. Oct 1, 2021 at 5:03 PM
    #895
    rdcowan
    rdcowan Member
    Robert
    NW Florida
    Good Luck Steve! Let us know!
  16. Oct 9, 2021 at 4:55 PM
    #896
    TacoSteve556
    TacoSteve556 Member
    Stephen
    2016 2.7l Taco
    Stock
    Real simple, hose clamp off, carful drilling of the plastic welded rivet, popped right out.. Any difference drive wise, not that I can tell.
  17. Oct 10, 2021 at 3:59 PM
    #897
    fattymattie360
    fattymattie360 New Member
    NE Oklahoma
    2012 Silver Tacoma Access Cab 2.7l 5sp 4x4
    I've gotten a lot of great information from this site and I think I can add something to this mod (hopefully).
    I just did the 2nd filter delete and, instead of drilling out the rivets, I took a box knife and cut the filter out along the edges. This allowed me to lift at the rivets and they snapped (pretty clean for the most part) off. I took some dykes and cleaned the ones that needed it. Made it a 5min job (including wrapping the intake so no debris got in the engine).
    Thanks for everyone on this site for posting either great information or some good humor.
  18. Nov 23, 2021 at 8:04 PM
    #898
    ToyotaGuy59
    ToyotaGuy59 Member
    Scott
    Houston
    ‘15 Silver Prerunner TX Edition
    Re 07TRD sport
    Can’t go wrong switching the mobile one synthetic there’s a high mileage version for vehicles over 75,000 miles as well. I saw a slight mpg improve on my 2015 Tacoma, as well as my 95 F150.
  19. Dec 3, 2021 at 12:08 PM
    #899
    too.poor.for.a.mechanic
    too.poor.for.a.mechanic Active Member
    2006 2.7L Access Cab
    Relatively Stock
  20. Dec 3, 2021 at 6:59 PM
    #900
    ToyotaGuy59
    ToyotaGuy59 Member
    Scott
    Houston
    Great education!
