DIY: Secondary Air Filter Removal
Discussion in 'Performance and Tuning' started by 007Tacoma, Jul 7, 2007.
  1. Dec 25, 2007 at 10:40 PM
    #101
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    they should have them, i don't know why they wouldn't if almost all new cars are made with them...it's just a few inches further in from the primary air filter
  2. Dec 25, 2007 at 10:45 PM
    #102
    TacomaYAK
    TacomaYAK The Reel Sportsman
    League City, Tx
    08 Access Cab 4.0
    Lifted.
    I will look better tomorrow, but I know my air filter does not look like the first pictures posted...
  3. Dec 25, 2007 at 10:49 PM
    #103
    TuRDTACO
    joliet, il
    remove your intake tubing and your primary air filter, it will just come out when you pull off the clamps, it's a long rectangle shape. once you take that filter out, look at the side of the intake you didn't remove or touch and the charcoal filter should be right there. it won't just pop out tho, use a knife and cut the tops of the plastic rivets off and take it out
  4. Dec 26, 2007 at 7:49 AM
    #104
    007Tacoma
    007Tacoma [OP] I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    The first set of pictures are from a 2007 2.7L. Look further through the posts and you will find that Maverick491 has some pictures and instructions on how to remove the filter out of the 4.0L V6 (which is the same from 2007 to 2008).
    Cheers!!!
  5. Dec 27, 2007 at 9:03 PM
    #105
    danusa
    danusa Well-Known Member
    I Am Not In Cali, So Screw Them.
  6. Dec 30, 2007 at 5:20 AM
    #106
    danusa
    Is this still relevant if you install a Super Charger?
  7. Dec 30, 2007 at 6:43 AM
    #107
    dan_o_89_rs
    dan_o_89_rs Member
    White 2x4
    STOCK
    so your saying that on an o8 v6 the filtration process starts with the standard paper filter, then is followed up with the charcoal filter before entering the IM?
  8. Dec 30, 2007 at 7:58 AM
    #108
    danusa
    I am in the asking position here.
  9. Dec 30, 2007 at 9:14 AM
    #109
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    yes...exactly. if you undo the clips to the air filter housing and look directly to the right of the housing, u'll see the charcoal filter right there. if u dont live in a low emmissions state and dont care about replacing the filter, u can have it out in less than 5 mins and put back together.
  10. Dec 30, 2007 at 3:37 PM
    #110
    dan_o_89_rs
    dan_o_89_rs Member
    White 2x4
    STOCK
    just like you said. pretty dumb IMHO. thanks for the help. seing how this isnt my truck i cant attest to mpg improvements.
  11. Dec 30, 2007 at 9:56 PM
    #111
    TuRDTACO
    joliet, il
    what hodgey said :D
    Canyon lands likes this.
  12. Jan 8, 2008 at 3:47 AM
    #112
    tacomanub08
    tacomanub08 Well-Known Member
    San Diego, Cali
    08 Black Access Cab I4
    Removed 2ndary Air Filter, Front Tint
    Hmm i just got my 2008 4 cyl. tacoma... it doesn't even have 400 miles on it yet.
    Should I try this mod out or wait awhile to break in the car?
    Also, anything I should know about this affecting the warranty?
    And what should I do so that I am able to re-apply the filter if neccessary?
  13. Jan 8, 2008 at 6:09 AM
    #113
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I wouldn't really think that this filter has anything to do with your break-in, but if you really want you could wait another hundred miles to be sure.
    As for being able to re-install the filter if necessary. If you follow 007Tacoma initial write up to the letter the filter will be intact and can be re-inserted if the need for a warranty repair were to arrise. Also Sawdust added his own method somewhere down the line in this thread of just shaving off the "plastic buttons" with a very sharp small detail chisel, which would leave the mounting posts intact as well as the filter intact which would make re-install even easier and slightly more secure.
    In short anything but jhodge83's "cut and rip" method (no offense intended) will enable you to re-install the filter at a later date should you need to.
    As for warranty... It would be hard for them to prove that the removal of t his filter affected anything other than perhaps your emissions, but none the less as long as you keep the filter intact and place it back into the airbox before going in for warranty work you should have no problem.
    Edit: Just saw you were in Cali, so you will likely want to keep the filter to put back in for when you have to go for smog inspection, since you guys have all those wierd emisions laws out there.
  14. Jan 8, 2008 at 2:39 PM
    #114
    tacomanub08
    San Diego, Cali
    Awesome, thanks Maverick.. now I just have to build up to courage to do it. (Never even opened up the hood of a car before, ha)
    PS Should I reset the ECU after I'm done? And how do I go about doing that?
  15. Jan 8, 2008 at 4:34 PM
    #115
    maverick491
    South Jersey
    You're welcome.
    Don't worry about re-setting the ECU, it is a learning computer to begin with, so it will adjust to the higher air flow by itself anyway.
  16. Jan 13, 2008 at 7:25 PM
    #116
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I removed my secondary air filter yesterday. IMHO it made a nice improvement. I have no idea how it will effect my mileage (24.8ish average)but the truck is definately responding to throttle better. I found myself having to keep a lighter foot on the gas pedal for my normal driving speeds and when hitting hills with the cruise control on the truck maintained speed with less effort.
    I ordered a scangauge II (about 2 hours after removing the filter) and I'm looking forward to playing with.... I mean using it to confirm the differences with the filter in place and removed.
  17. Jan 15, 2008 at 1:03 PM
    #117
    erock
    erock Well-Known Member
    Boise
    06 TRD OR Tint Window, Magna Flow 2.5 Catback, TRD CAI, 3" Revtek and TSB, 33" Toyo MTs
    Cig Lighter Will tackle the Rear Locker Always On soon
    Does this have any affect of emissions?
  18. Jan 16, 2008 at 4:40 PM
    #118
    Roland
    Rhode Island
    It shouldn't affect the exhaust emissions at all. It's only reason to exist is to absorb hydrocarbons that might try to find their way out of the truck through the air intake while it's not running.... Like that's going to save the planet :rolleyes:
  19. Jan 21, 2008 at 1:13 PM
    #119
    Roland
    Rhode Island
    I'm convinced!
    The two tanks I used before removing the secondary filter averaged out to 23.681 mpg. The two tanks I've used after taking the filter out averaged to 24.615 mpg.
  20. Jan 22, 2008 at 12:13 AM
    #120
    TuRDTACO
    joliet, il
    i cut that thing out of there just for the weight reduction :p
