DIY - SmartStart Installation with DBALL2 Remote Start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gpb, Dec 31, 2016.
  1. Dec 31, 2016 at 9:32 AM
    gpb
    gpb [OP] Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Content removed.
    Mods think that an image of a dog peeing on a photo of a war criminal is inappropriate.
    I think I won't support this site with my intellectual property.
  2. Dec 31, 2016 at 10:39 AM
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    gpb[OP] likes this.
  3. Dec 31, 2016 at 1:56 PM
    BadRobot62
    BadRobot62 Well-Known Member
    David
    2017 Tacoma Sport 4x4
    Level kit,
    So the DSM300 is not a plug n play module for the Remote install kit that's sold by KBVoodoo. is there some additional wiring needed, I have purchased the DSM300 from Amazon and none of the connectors have a white plug like in your picture, my kit came with a two wire harness with a fusible link in the middle and bare wires at the end.
    Thanks
    David
    Hank Heel likes this.
  4. Dec 31, 2016 at 2:58 PM
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    Great work and write up. I'm interested in the Apple Watch functionality
  5. Dec 31, 2016 at 3:13 PM
    BadRobot62
    David
    Level kit,
    Must of had a senior moment, when I rolled my chair back I stepped on the missing wiring harness,
    Thanks for your offer and help.
  6. Dec 31, 2016 at 4:26 PM
    BadRobot62
    David
    Level kit,
    The generic installer account you can use, login is “dei1” and password is “dei1”. works, thanks for the info.
  7. Dec 31, 2016 at 4:33 PM
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    Have seen it mentioned to be sure you log out after using it also. And I now hate this thread. I'm currently telling myself "you don't need this" "you don't need this" but I did the same thing with the remote start and ended up with 2. :rofl:
  8. Jan 2, 2017 at 2:42 PM
    PJnc284
    Garner, NC
    I need to find a way to put a thread on ignore. :rofl:
    ratcityrain likes this.
  9. Jan 2, 2017 at 2:44 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    I'm trying convince myself I need this..
  10. Jan 2, 2017 at 2:47 PM
    PJnc284
    Garner, NC
    I'm trying convince myself I don't need this..
    Ch78 likes this.
  11. Jan 3, 2017 at 10:36 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    So everything seems to be pretty much plug n play. Just need to find out if KBVoodoo programmed his kits to enable smart start or not.
  12. Jan 3, 2017 at 10:46 AM
    Hank Heel
    WA
    I can relate, I came from a former Soviet Union and we had a 79 lada, heater is a luxury we couldn't afford. We're spoiled to the max here, but im not complaining
    SC4333, RIDERED67 and gpb[QUOTED][OP] like this.
  13. Jan 3, 2017 at 12:07 PM
    nickj718
    nickj718 Well-Known Member
    Nick
    2016 Tacoma TRD Sport
    For anyone doing this here is a couple notes
    The smart start doesn't have to be at the top of the dash. I installed mine in the same spot as the remote start unit (between the ecu and bcm). The older units were not as good but the vsm 300 and 350 are no longer directional.
    As for the user account here is the log in for those who dont want to create a account
    log-in: dei1
    password: dei1
    gpb[OP] and ratcityrain like this.
  14. Jan 4, 2017 at 5:21 AM
    PJnc284
    Garner, NC
    Even with the improvements, I would think your location is optimal. This is cell signal we're talking about so higher is better and you want minimal obstructions. May only be an issue in marginal signal areas but better safe than sorry.
    gpb[OP] likes this.
  15. Jan 4, 2017 at 4:40 PM
    Mtbkrguy
    Mtbkrguy Well-Known Member
    2016 Tacoma TRD Sport 4x4 Double-cab
    Apple watch is so slow... It took way too long on that demo video in my opinion. Yes I've had the Apple Watch since it was first released and it's too slow on pretty much any aftermarket app.
  16. Jan 6, 2017 at 8:48 AM
    ratcityrain
    Seattle, WA
    I just emailed KBVoodoo to confirm that they are shipping out the dball2 flashed with this capability. I have already installed my remote start and and now I want to add this Smart Start kit.
    Good to know.
    Lastly, does this smart start kit come with the connector that plugs into the dball2? I assume it is a white one since that is the only connector I saw on the dball2 that didn't get anything plugged into for remote start to work.
  17. Jan 6, 2017 at 9:02 AM
    ratcityrain
    Seattle, WA
    Awesome. I have plenty of wire to use to extend wires and I have the same sleeving to use to keep it clean or at worse I can use black loom, but that sleeve stuff is nicer & easy to work with
  18. Jan 6, 2017 at 9:31 AM
    nickj718
    Nick
    All remote starts are flashed to adapt a smart start at a later date
    Gravybird and ratcityrain like this.
  19. Jan 6, 2017 at 9:36 AM
    ratcityrain
    Seattle, WA
    That is great news. Time to order the smart start :)
  20. Jan 6, 2017 at 9:43 AM
    ratcityrain
    Seattle, WA
