DIY: squeaky leaf fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beachbumberry, Jun 15, 2010.
  1. Jul 12, 2012 at 7:08 PM
    #301
    ppfd
    ppfd Well-Known Member
    WV
    09 TRD ext. cab 6 spd
    Bought it back in May from a Toyota dealer in Columbus Ohio. I live in WV and at the moment I'm in northern Ohio, (Akron) at my parents home.
    I planned on running by the dealer my parents bought their Toyotas at. I need to pick up an Oil filter.
    I'll ask them and see what they say. I hate to have to drive 2 hours back to Columbus and then spend a few hours there. If the parts are $40.00, I'll suck it up and do it myself.
    For the record, I've got 44, and some change on the Odometer.
  2. Jul 13, 2012 at 12:30 PM
    #302
    ppfd
    WV
    Ordered the kit from the dealer, should have it in the morning.
    Price was $31.00.
  3. Jul 14, 2012 at 4:50 AM
    #303
    dsc522758
    dsc522758 Active Member
    Daniel
    Arlington, Texas
    2008 PreRunner TRD SR5 Sport Pkg. LB
    Bilstein Shocks, Billet Grille, Bull Bar, A.R.E LSII Series Tonneau Cover, OEM Daytime Running Lights Mod
    I ordered and received the 4 spacer replacement kit the first week of March but just got the chance to do the work yesterday. The new pads are much beefier than the old, hard plastic ones. You really need to spread the leafs apart to get the new ones to fit. The rear ones are especially a tight squeeze! I lubed each spacer pad with Lucas white lithium grease I bought at Home Depot before putting them in there. No more squeak!
  4. Jul 14, 2012 at 7:38 AM
    #304
    GMRtaco
    GMRtaco Well-Known Member
    IE
    07 Pre Runner DCSB
    URD TCAI, TRD Seat covers, WeatherTech Liners, BHLM, DTRLM, 6000K HID Heads, 3000K HID Fogs, Black Valence, Custom license plate mount, LED interior lighting, Pioneer 4200DVD, 2 10" infinite subs behind rear seats, spidertrax spacers, 265/65/17 Dynapro ATM with powdercoated stock wheels
    Best 31 bucks you will ever spend on your truck! :thumbup:
  5. Jul 14, 2012 at 7:22 PM
    #305
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    question is how long will this fix work?
  6. Jul 14, 2012 at 7:33 PM
    #306
    nj636
    Kev
    Jersey
    what's the Toyota part #?
  7. Jul 14, 2012 at 8:42 PM
    #307
    ppfd
    WV
    Hopefully til I sell the truck!:D
    Part #04001-28104 Spacer Kit, Service.
    If you have 4 leafs you will need 2 of the kits above.
    This is according to the TSB instruction sheets the dealer printed of for me.
  8. Jul 15, 2012 at 2:07 PM
    #308
    ppfd
    WV
    Just finished!
    Took about an hour, the rears are somewhat of a pain in the ass.
    My tool list:
    Long, short (nail puller) crow bars, and a "wonder bar"
    Needle nose (long)
    Flat head screw driver
    2 chisels used as wedges
    Hammer on stand by
    Brake cleaner
    I did each side separate, starting with the rears. I pretty much followed the TSB print out. The wonder bar made this so much easier I think. If your not familiar, its a flat crow bar with a bend in the middle, lot more leverage with it.
    I can't say it enough, spend the money and get the kit. These things are rubber and twice as thick as the plastic disks your popping out and replacing.
    Rick's 2012 likes this.
  9. Jul 18, 2012 at 9:01 PM
    #309
    Rabby
    Rabby Well-Known Member
    2010 Tacoma 4x4
    OME Hvy Kit, ARB Bumper
    I have a 2010 with the TSB add a leaf upgrade and in the past few months theleaf spring squeak showed up like it did in my 2005. I just did my 20k serviceand talked to the service writer and he said, and I quote, “they stopped makingthe TSB shim/pucks and won’t be making them at all anymore”. My 05 squeakedlike a 77 Chevy ranch truck and now so does my 2010.
    I’m not taking this as gospel as I have had to show up and say look up yourlittle TSB machine because they thought the 2010 didn’t get the add a leaf fix.But if it is true, instead of using a tire tube, you can also use a tougherbike tube liner like this;
    http://www.amazon.com/Mr-Tuffy-Bicycle-Tire-Liner/dp/B0048LO6BQ
    It’s a liner that goes between your bike tube and tire. I haven’t tried itbefore but it seems like it would hold up better then a regular bicycle tube.
    Anyone hear the same or is there a light at the end of the squeaky leafspring tunnel.
  10. Jul 20, 2012 at 2:28 PM
    #310
    08trdoffrode
    08trdoffrode New Member
    Jesse
    South Carolina
    08 access cab TRD offroad 4x4 SR5
    hunter brushguard, flowmaster orininal 40 muffler
    i did this mod and it worked great. used locktite super glue, two of the pieces did slide out in two days, however im blaming that on the heavy rain and puddles at the time of install. will soon upgrade to JB weld
  11. Jul 24, 2012 at 4:10 AM
    #311
    ppfd
    WV
    I think your dealer is bullshitting you.
    That part number, I listed, others have listed, did you use it?
    The TSB print out even says a 4 leaf set up gets 2 packs of these.
  12. Jul 24, 2012 at 6:09 PM
    #312
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    So if I recently had the TSB done should I have some sort of rubber shim kit installed already? I ask because I have a squeak from the rear now since the TSB that wasn't there beforehand. I just haven't had the time to take it in to the dealership since I work from about 6:00am to about 8:00pm these days and spend most of my days up in the mountains w/o even any phone reception to call and schedule anything.
  13. Jul 25, 2012 at 9:07 AM
    #313
    dsc522758
    Daniel
    Arlington, Texas
    I assume you did not use the Toyota kit since, if you did, there is no way for them to slide out.
  14. Jul 31, 2012 at 8:12 AM
    #314
    makeshiftTaco
    makeshiftTaco Well-Known Member
    Andrew
    New York
    09 TRD Sport
    Undercover Tonneau, Black Emblems, Weathertech Digifits, TRD Shift Knob, TRD Exhaust, Avid Light Bar, TRD Skid, Thin-lip Satoshi, Devil Horns, AFE Stage 2 SI, URD SS
    I bought the Toyota kit and installed them in about 15 minutes. I couldn't be happier! I can get in and out of the truck without any squeaks or creaks or noises!
  15. Aug 9, 2012 at 9:30 AM
    #315
    calebdnehus
    calebdnehus Well-Known Member
    Caleb
    Arkansas
    '98 Prerunner V6--2004 Tacoma facelift
    K&N cold air intake FPIK, FlowMaster 40 series muffler, Euro Diamond clear headlights, 2003 tacoma tailights, bixenon HID headlights, 4 inch lift, pioneer headunit w/kicker door speakers(amped w/Rockford four channel), 2004 facelift, led dash light mod, painted needles, black auto shifter, leather steering wheel, ultra gauge. Plenty to come... Still
    I have a 98 prerunner that does this. I have a three leaf pack with an aal, would you guys just put the tubes in between the 1st and 2nd then the 2nd and 3rd?
  16. Aug 10, 2012 at 9:26 PM
    #316
    justinitsuj
    justinitsuj Well-Known Member
    Justin
    Mills illest
    Debadged//blacked out//6" fabtech//stubby//spintech//thule//wet okoles//weathertech floor mats//
    what if we purchased the 6 inch fabtech kit. Can we still use these rubber spacers from toyota?
  17. Aug 12, 2012 at 9:50 AM
    #317
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    i did & i still spray leafs with w-d when a squeak develops or where ever i find a squeak elsewhere :p
  18. Aug 20, 2012 at 5:52 PM
    #318
    greasemonk
    greasemonk Active Member
    Houston
    08 Black PreRunner V6
    HIDs, debadged, 2012 taco tail lights, mud flaps removed, black grill emblem, JVC Radio
    Could anyone give me a rundown on this? What exactly do these newer pads do that fix the squeak problem? And what does "TSB" mean?
    My truck has been squeaking horribly the past few months and I'm fed up with it! :mad:
  19. Aug 20, 2012 at 6:36 PM
    #319
    nj636
    Kev
    Jersey
    "T.acomas S.queeky B.ushings"
  20. Aug 20, 2012 at 6:41 PM
    #320
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    glad this got bumped. was about to look for it. mine squeak like a MOFO!!
