DIY: squeaky leaf fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beachbumberry, Jun 15, 2010.
  1. Oct 6, 2012 at 9:24 AM
    #361
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I used thick rubber gas tank strap first and it worked for about 5-6 weeks then it was back to squeaking.
    my advice to everyone, get the bushings and be done with it.
  2. Oct 17, 2012 at 4:42 PM
    #362
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Just Installed my new leaf bushings that I picked up from the dealer last weekend.. Ahh... The sweet sound of silence :D
    Anybody that has the squeaky leafs.. pick these up. 30 bucks and ten minutes.. done.
  3. Dec 7, 2012 at 12:17 PM
    #363
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Shoot works like a charm. Glad I saved that last bicycle tube I popped. Good for two things. Making rubber bands and leaf silencers. Great write up!!!
  4. Dec 7, 2012 at 3:27 PM
    #364
    Sixxtaco
    Sixxtaco Well-Known Member
    West Des Moines
    05 SR5 TRD Rad Red
    Part number?
  5. Dec 7, 2012 at 3:42 PM
    #365
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  6. Dec 9, 2012 at 3:27 PM
    #366
    nj636
    Kev
    Jersey
    and when those wear through or start to squeak go ahead and get the bushings
  7. Dec 13, 2012 at 7:10 PM
    #367
    gnarcal
    gnarcal Active Member
    Max
    Washington State
    '09 Tacoma 4x4
    Bilstein 5100's SPC Performance upper control arms Diff drop 1.5° shims Carrier bearing drop 1" AL blocks in rear
    the tubes walk themselves out of the leaf pack. I pried apart the leafs and sprayed lithium grease on the isolation pads. NOW my squeek is gone. Keep I'm mind each side had 2 isolation pads; a total.of 4 pads must be treated with heavy weight grease.
  8. Dec 18, 2012 at 9:38 AM
    #368
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Mine has creaked since I had about 5,000 miles on it. I worked at the dealership when I bought it, so I figured it wasn't a big deal. Now it is six years later, and I am way out of warranty and it still annoys me! I am going to try the tube trick. It certainly seems cheaper than aftermarket springs.
  9. Jan 11, 2013 at 1:52 PM
    #369
    carlsv650
    carlsv650 Well-Known Member
    Colfax, NC
    05 PreRunner TRD
    Extra "D" Rings, ARE MX Truck cap carpet lined with entry door. mods to bicycle mounts
    I never really paid attention until I read this thread. maybe I'll fix it now.
  10. May 17, 2013 at 5:34 PM
    #370
    MagneticTaco
    MagneticTaco Well-Known Member
    Kiel
    Louisiana
    2013 DCSB Magnetic
    3" toytech lift, front spacers, AAL in the rear, 285/75r16 goodyear duratrac, blacked out emblems and taillights, pained grill
  11. May 17, 2013 at 10:49 PM
    #371
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    Since this got bumped, I'll do a quick update.
    I used some treadmill belt in my leafs about 7 months ago. One needs to be readjusted, but all others are holding firm and NO SQUEAKS.
    I definitely suggest people try this if they are squeaking.
  12. May 23, 2013 at 8:26 AM
    #372
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Stupid easy.
    Just a large flat head or a crow bar... anything to separate the leafs.. another flat head to pop out the old ones... and help slide the new ones in..
    Done.
  13. Jun 7, 2013 at 5:52 AM
    #373
    futureclaypool
    futureclaypool Member
    Tyler
    Minot, ND
    '08 Tacoma Double Cab Sport
    Upgraded stereo Toytec height adjustable front coilovers (Bilstein 5100 struts w/ Eibach coils) Bilstein 5100 rear shocks All Pro Offroad standard duty leaf springs (3" lift) Sway bar relocate kit Carrier bearing drop URD short throw shift kit URD cold air intake
    this is just pure curiosity but what mileage did everybody's tacoma's leafs start to squeak?
  14. Jul 1, 2013 at 7:41 AM
    #374
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
    Stupid question, what does TSB stand for?
  15. Jul 1, 2013 at 7:42 AM
    #375
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Technical Service Bulletin
  16. Jul 3, 2013 at 7:23 PM
    #376
    Sixxtaco
    West Des Moines
    05 SR5 TRD Rad Red
  17. Jul 3, 2013 at 7:27 PM
    #377
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup: right on! Good to hear. Its definitely a great, simple fix.
  18. Jul 3, 2013 at 7:41 PM
    #378
    Sixxtaco
    West Des Moines
    05 SR5 TRD Rad Red
    Yeah, my driver side leafs were a bitch to get far enough apart for the new pucks. Those old ones were a real pos though.
  19. Jul 8, 2013 at 12:32 PM
    #379
    Yoshio
    Yoshio Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    This thread is great, mine are squeaking when I get in/out or step on the tailgate... off to order the space kit, thanks much!
  20. Jul 13, 2013 at 5:28 PM
    #380
    RiverRock
    RiverRock Member
    Jeff
    RDU
    05 TRD Sport DCSB & 15 TRD Sport DCSB
    Thanks for the advice. Installed the kit today after putting up with the squawk for two years, trying WD40 and others. This was a 20 minute job. Front spacer is simple, back one needs a little finesse. You don't need to take off wheels - just jack from the hitch to relieve pressure. Your lug handle will work well for separating the springs. Kit was $31 from dealer. Don't bother with anything else.
