DIY: squeaky leaf fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beachbumberry, Jun 15, 2010.
  1. Jun 23, 2010 at 12:14 PM
    dougmays
    dougmays Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    this is awesomei was just getting on here to ask a question about a squeak i just developed. and this might be the fix...
    but let me ask just incase its something more severe. i haven't had any issues with squeaking ever (truck is 3 years old)....and i went mudding a couples weeks ago and after that i had this squeak.
    Do you guys think it was from that? how do you think the squeak came about from that? i hope i didnt break anything?
    it squeaks even when i get and out...do you think its the leafs or something else>?
  2. Jun 23, 2010 at 12:26 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    should be added to cheap free mods section as well ;)
  3. Jun 23, 2010 at 1:28 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Don't know, but I can tell you I've never taken my Tacoma mudding, and I have it. Mine showed up between 45,000 and 50,000 miles.
    That said, while I don't intentionally get my truck into the mud, it does happen on occasion, but nothing serious by any means.
  4. Jun 24, 2010 at 6:33 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    My leafs squeek after every trip I make to Ocotillo Wells or just driving offroad in super dusty conditions. My reliable fix is to use a wheel cleaning brush and some wheel/tire cleaner and briskly scrub the leafs after washing the truck. After word I use a can of Teflon spray that resists new dirt sticking to it and becoming sludge. Works until my next offroading session. Than ofcourse it comes back. The rubber in between the leafs seems like a more permanent fix though. Very clever!
  5. Jun 25, 2010 at 3:48 AM
    Finsterino
    Finsterino Active Member
    Florida
    07 TRD
    Thanks for this DIY! I installed rubber inner tubes last night - quick and easy and cheap. Easier than wasting time with the dealer, too.
  6. Jun 25, 2010 at 4:31 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    this'll give you a 5mm lift too! SICK
  7. Jun 25, 2010 at 4:33 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Nice one OP!
  8. Jun 28, 2010 at 10:36 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    I had this problem with my 1947 Plymouth, and I solved it about the same way, but instead of using rubber I used plastic strips cut from old oil bottles. This seemed to work very well, and the bottles are, of course, free, when you buy the oil.
    I remember switching from Penzoil to Havoline, because I thought the black plastic was less obvious than the yellow Penzoil bottles.
  9. Jun 29, 2010 at 10:47 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I am going to give it a shot this wknd. My driver side leaf pack is driving me nuts. Every time I get out of the truck it squeaks, and I am not a big guy either.
  10. Jun 29, 2010 at 9:20 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    a "wally world" innertube will not last long as a buffer in between the leafs of a truck that is really offroaded. Should last longer for the street queen trucks which never go offroad, especially if they do not haul or use the truck for its intended purposes. I would like to hear if you gained more miles before squeaks with the Tube vs Lube long term? :D
  11. Jun 30, 2010 at 4:16 PM
    beachbumberry
    beachbumberry [OP] Well-Known Member
    andrew
    fl now, tx native
    05 sr5 4x4 access cab
    leveling kit, american racing rims, push bar, nerf bars
    i did less offroad and loaded trips with the lube (about 1 week) before the squeak came back than i did with the tube. ive had the tubes in for a few weeks and played on the beach then drove 8 hours with them in and still no squeak.
  12. Jun 30, 2010 at 5:17 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    I think i'm gonna go with the plastic from the oil bottles instead...I would think it would last much longer then the rubber from the inner tube
    Thanks for all the great info..
  13. Jun 30, 2010 at 7:06 PM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    18 DCLB OR Prior: 99LX470/05DCOR97LX450/914R
    Basic
    This shall be the first thing I do in the morning. Thanx!!
  14. Jul 1, 2010 at 10:07 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    This didn't work for me. It decreased the amount of noise, but there are still more places where the leafs rub.
    Edit: figured out that I had so much grime in there that I had to power-wash the leafs as well.
  15. Jul 1, 2010 at 10:10 AM
    #35
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    :frusty: i'm doing this sometime in the very near future! mine squeak like a bitch!!! over every bump, around every corner...squeak....squeak....squeak aaaaaaaaaaahhhhhhhhhhhhhaaaaaaaaaaaaaaahhhhhhhhhhhaaaaaaaaaaaaaaaaaa :goingcrazy:
  16. Jul 1, 2010 at 6:26 PM
    #36
    blazze2005
    South Jersey
    I just noticed my 05 Tacoma already has the nylon spacers between the leafs from the factory
    Their is already a small gap between the leafs from the factory spacers so I guess I won't be doing this mod
  17. Jul 2, 2010 at 8:38 AM
    #37
    Rob79
    Rob79 New Member
    Well I did the fix to the fronts first, let the truck back down and the squeak was still there so I did some more investigation and my squeak was the back on the leafs, there is also a factory pad in the back also. Once I did the backs, my squeaks are solved, thanks for this GREAT thread as I was going NUTS, just bought the truck (2006) and was worried I would have to listen to this for the rest of my ownership days. Just have to install a set of the Timbren SES since I do not have hte TSB on my leafs done. Thanks again :)
  18. Jul 3, 2010 at 9:27 AM
    #38
    JAM73
    JAM73 New Member
    Richmond, VA
    07 Tacoma DC Long
    Creak in the rear left suspension was driving me nuts...Toyota dealer told me $227 (200 labor and 27 parts) to replace spring pads....so glad i decided to do some research. found this forum and thread. Just finished cleaning the leafs w/ some WD40 and then added a piece of tire tube and no more creakin!!!! F'n A!
    Note: on the way over to work to grab a crowbar from the garage this morning, a rock hit my windshield. there are now two 8" cracks running side by side from the top on the passenger side. Eff! There went my savings!
  19. Jul 3, 2010 at 9:32 AM
    #39
    HBMurphy
    Paul
    So California Coast
    None
    That doesn't sound like "savings." That sounds like "spendings." Savings is something you don't touch. If you ever want to have savings, I would steer clear of this place! You have been warned! :eek:
  20. Jul 3, 2010 at 10:35 AM
    #40
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    HAHA so true, this is a money pit!
