DIY: squeaky leaf fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beachbumberry, Jun 15, 2010.
  1. Jul 31, 2013 at 2:18 AM
    #381
    m32
    m32 Well-Known Member
    Edwin
    2013 DCSB TRD
    Sub'd
  2. Aug 19, 2013 at 8:32 PM
    #382
    Cuda17
    Cuda17 taco lover
    Jeffrey
    Bellville, Texas
    06 PreRunner SR5
    ToyTec/Eibach Coilovers with custom aluminum built-in spacers, rear aal, 1.5" spacers
    Installed mine today annnnnnnd it still squeaks like crazy!!! WHAT IS IT?!?!?! It's making me looney!!!
  3. Aug 26, 2013 at 10:02 AM
    #383
    Onion27
    Onion27 Well-Known Member
    San Antonio, TX
    05 Tacoma Dbl Cab PreRunner
    Would any sort of silicon spray work or should I just stick to some sort of grease? Looking for a qucik fix until I can devote the time to do the better fix.
  4. Aug 26, 2013 at 10:35 AM
    #384
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    that didn't work for me, there is a lot of pressure and I believe it squeezed the lube out.
    the actual fix for this will not take a long time for you to do, 30min should be enough.
  5. Aug 26, 2013 at 11:28 AM
    #385
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    If that. Just get the parts and get it done and over with.
  6. Sep 7, 2013 at 1:22 PM
    #386
    hondamxracer
    hondamxracer Well-Known Member
    Installed some hydro-turf between my leaf springs today and it remove the squeak!
    Thanks!
  7. Oct 19, 2013 at 2:37 AM
    #387
    cleveland48
    cleveland48 Well-Known Member
    Andrew
    Belmont, Mississippi
    2012 TRD Off Road
    5100's set at 1.75, 1.5 in. AAL, 265/75/16 Cooper ST tires.
    I know it's been awhile since anyone posted on this thread. But where are the most critical points to put this rubber piece in? Front or rear of the leaf pack? I have a wheelers AAL in. Do I need to put some between every leaf?
  8. Nov 8, 2013 at 2:53 PM
    #388
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    I just installed the bushings and the squeak is completely gone. I added a leaf last year and today I put a piece of hard plastic between that leaf and the original. I used a piece of rubbermade tote that I had cut into a 1-1/2 square.
  9. Nov 15, 2013 at 7:34 AM
    #389
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    I'm going to do this on my next day off. However I think my squeak is coming from the shackle bushing. Any ideas how to fix that squeak. It's getting very annoying
  10. Jan 12, 2014 at 3:56 PM
    #390
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    Wherever I have changed the engine oil on any of mine vehicle with leaf springs I have poured (I used to use a pump oiler) the drained oil over the leaf springs. None have ever squeaked after being oiled. My 2007 Tacoma included.
    PHM
  11. Feb 6, 2014 at 1:49 PM
    #391
    Pacos13Taco
    Pacos13Taco Member
    Texas
    13 PreRunner Dlb Cab TSS Debadged
    K&N air intake i think a lift it, can't tell :( husky floor liners ARIES 3 inch black bull bar with silver skid plate debadged and blacked out grill
    I have that annoying leaf spring fix. I called the dealer and they asked to bring my truck in so they could look at it and possibly fix the noise. I ended up taking my truck and what do you know, once i got there I tried to show the tech the noise the truck was making. The damn Taco was a quiet as a church mouse. I could not get it to replicate the noise so decided to take it in and drive it around to see if the noise would come back. In the end the truck was super quiet (didnt get wet or spray anything in it) so i drove home pissed knowing the squeak would come back. Later that night the noise returned so needless to say i was pissed.
    Now i have to wait for the noise to be awful again so i can stop by and get it fixed the second time around
  12. Feb 6, 2014 at 4:34 PM
    #392
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    or just buy the bushings from Toyota, and swap em in yourself. no more having to coordinate the sound with the techs. :thumbsup:
  13. Feb 7, 2014 at 1:49 PM
    #393
    Rabby
    Rabby Well-Known Member
    2010 Tacoma 4x4
    OME Hvy Kit, ARB Bumper
    I have had the add a leaf TSB and I can still get it to squeak when I have weight in it. When I put my quad in the back (600 lbs) and then it does it pretty reliably. The bed is rated for 1000 lbs so maybe try add some weight you have around the house and bounce on your bumper and see if it does it.
    Hope it helps, the squeak drove me nuts too.
  14. Mar 29, 2014 at 6:23 AM
    #394
    deadbird8
    deadbird8 Well-Known Member
    Dallas, TX
    14 4x4
    My 2014 has about 1000 miles on it, rained and now its squeaking like my 2005 with 205K :mad:
    Noise is from the leaf on the passenger side and seems to go away when it dries out. Any ideas what's up with this? It should have all the TSBs on it?
  15. Mar 29, 2014 at 9:40 AM
    #395
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    its normal to squeak like that. any other tacoma driving around will most likely have it to
  16. Mar 29, 2014 at 7:21 PM
    #396
    darrylsawyer1989
    darrylsawyer1989 Member
    Darryl
    Panama City, Florida
    2010 SR5 4x4
    baja rack, tint, lift, 20" rims nito tires, more to come
    i did the fix today. it took all of 10 min. i used an old radiator hose and cut it into strips about 1" x 12" (four strips total) and slid them in the front and back of both leaf springs and it worked like a charm. thanks for the write up.
  17. May 1, 2014 at 5:48 PM
    #397
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    My 2014 tacoma is going to the dealer on Saturday for new leaf pack, under warranty.. and see how long it takes for the noise to come back :/ ... I dont even feel like driving the tacoma with that noise!! :mad:!
    edit: I just notice a part number on pg 15.. should i tell them to install the new leaf kit , and the service bushings? or what should i do?
    thanks
  18. May 2, 2014 at 4:34 PM
    #398
    gnarcal
    gnarcal Active Member
    Max
    Washington State
    '09 Tacoma 4x4
    Bilstein 5100's SPC Performance upper control arms Diff drop 1.5° shims Carrier bearing drop 1" AL blocks in rear
    Jack up rear at the trailer hitch or bumper.
    Wedge a crowbar or cats paw in between each leaf to access the isolation pads.
    Apply a dab of heavy grease on the isolation pads. There are two pads on each side. The ones further to the rear are easier than the others.
    Dont ever put your finger in between the leafs.
  19. May 3, 2014 at 7:59 AM
    #399
    Poodle Head Mikey
    Always use a water-proof grease. High temp silicone is good. Many greases are soap based and aren't a good choice for this - so check to make sure they aren't going to wash out in the first rain.
    Separate the leafs (as stated), put some grease in, and then use a piece of small string or heavy thread to drag the grease well in with a back and forth 'sawing' motion with the string.
    PHM
  20. May 3, 2014 at 12:05 PM
    #400
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    If u un bolt the shock and keep the axle supported, u can put a bottle jack between the leaves and frame and get really good separation of the leaves.
