DIY - Tailgate Lock - (cheap quick writeup, lots of pics, 56k go walk your dog)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lookylookitzadam, Jul 23, 2010.
  1. Jul 23, 2010 at 10:33 PM
    lookylookitzadam
    lookylookitzadam [OP] Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    Why this mod:
    So this write up is my method to combat tailgate theft. I already installed the hose clamp mod, but I didnt want to deal with the pop n lock because I didnt want another key and I did not want to pay for the electric model.
    What this mod does:
    This mod shoots barrel bolts through the frame of the tailgate and into the frame where the taillights reside. It basically creates locking pins on each side near the top of the tailgate. This is actuated with the car alarm.
    Anyway what you need is:
    What you need:
    2 typical car door lock actuators
    2 door lock bolts
    wire
    Drill
    t30 torx bit
    socket wrench
    STEPS:
    1. Start by opening up the tailgate and taking off the composite cover.
    2. You need to remove all the T30 bolts and then the cover should just lift off.
    3. Shot with the cover off
    4. Next you gotta remove the taillights for when we drill the holes unless you want to drill into your lights. Its just a few no. 10 bolts I believe, should be obvious.
    5. This is the barrel bolt that you need to install on each side, get a length that will work. The first ones I got were too short.
    6. The next steps kinda require some good old fashion intuition and measuring. Due to the variances in the locks used and positions you are on your own for drilling their location. What you need to do is drill as close to the top of the tailgate as possible to give yourself the strongest and most secure locking position.
    I eyeballed it all from inside the taillight space when the tailgate was shut. Then drilled through it. Here is a few shots. I ended up drilling through the lowest blue dot. When I got through the tail light portion and made a mark on the tailgate, I dropped the gate and continued drilling.
    Next you have to align the barrel bolt with the holes you drilled and then drill its mounting locations into the tailgate.
    Holes drilled
    7. Bolt up the barrel bolt
    Shot of the barrel bolt extended
    8. Next it is time to get those actuators installed. These are the ones I used.
    When +12v and ground are applied to the wires in one configuration the actuator expands, when you flip the polarity, the actuator contracts. I wired up a few relays and connected them to my alarm door triggers. I used this diagram: (yours may vary based on alarm outputs) stolen from the12volt.com
    9. Align the actuators and the metal pins in line with the barrel bolt. They need to not bind.
    10. Test fit everything mounted on the top side, it makes things easier.
    11. I just bent the rods securely around the bolt tab, and its been working for me. Once it all works as required, mount on the underside of the tailgate so you can reinstall the composite cover
    12. Connect the wires and you should be good to go. There are a few places to run the wires out of your tailgate.
    I will provide more pictures if people want, or some videos next week if requested.
    Thanks and good luck.
    Post questions here since others may have the same ones.
    Jake Kern likes this.
  2. Jul 24, 2010 at 6:31 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    Very Nice Job !
  3. Jul 24, 2010 at 6:36 AM
    floridaoccifer
    floridaoccifer Civil Servant
  4. Jul 24, 2010 at 6:59 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Awesome!
    Brand, Model and cost of the actuators?
  5. Jul 24, 2010 at 7:04 AM
    ycart1201
    ycart1201 Well-Known Member
    Nathan
    Oregon
    2016 DC TRD Sport 4x4 - My build is underway
    Current Project: 2016 DC TRD Sport 4x4
    nice write up!
    Nathan
    ycart1201
  6. Jul 24, 2010 at 2:34 PM
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    They are just the standard door lock actuators. DEI makes them as well as a ton of other companies. Any alarm shop will sell them. They are the ones used for installing keyless entry and older cars.
    They cost about $10-$20 a piece, depending on where you get them.
    Got mine at a local shop. He wanted $30 each and I laughed and said Amazon had them for $8.99. He checked online and told me I could have them for $10 a piece. Any install shop will have plenty of these.
  7. Jul 24, 2010 at 2:41 PM
    austex
    austex Member
    Tom
    Texas
    Base
  8. Jul 24, 2010 at 2:46 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Similar to the electronic pop n lock but about $80 cheaper.
  9. Jul 24, 2010 at 2:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Looks far more secure than the pop n lock. Nice work and writeup.
  10. Jul 24, 2010 at 2:59 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    :eek:
    I was like pffff! when I saw the barrel locks, but the portion of the post after that really opened my eyes!
    Props for a job well done!!:bowdown:
  11. Jul 24, 2010 at 3:00 PM
    JAG
    JAG Well-Known Member
    WOW! Great job!
  12. Jul 24, 2010 at 3:28 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    awesome writeup and mod!
  13. Jul 24, 2010 at 3:44 PM
    chaztoyo
    chaztoyo Well-Known Member
    Chaz
    West TN
    10 Tacoma DCSB TRD Sport White
    Very creative idea, and very well executed too.
    Thanks for sharing the writeup and the pics.
  14. Jul 24, 2010 at 3:51 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Nice mod and well done. +1:thumbsup:
  15. Sep 5, 2010 at 1:55 AM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    It would be great to see how you ran the wires.
  16. Sep 5, 2010 at 2:48 AM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    x2.. hey do ya think one could tap into the door lock and have them run off of them????
    nice job
  17. Sep 5, 2010 at 6:39 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I like it! If my Dynolock ever dies I may convert to this and I have all the wiring all ready to go. This will provide a much more solid and secure locking method than the Dynolock, that simply interferes with the tailgate latch mechanism.
    One mod to this I would look into is to not use barrel bolts and instead get a piece of 1/4" aluminum or steel bar stock, center drill it, insert the actuator rod, then epoxy or weld them together. Attach this to the tailgate with an appropriately sized u-clamp to allow it to slide.
    Very good idea and design!
  18. Sep 5, 2010 at 7:04 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Great job!!
  19. Sep 5, 2010 at 8:25 AM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Good job I like this better than thw dynolock as well
  20. Sep 5, 2010 at 11:55 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Hum......we need a San Diego mod day :)
