DIY: Tinting Tail Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stroM-, Nov 18, 2009.
  1. Nov 18, 2009 at 8:46 AM
    stroM-
    stroM- [OP] @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    I know there are a few threads out there with a tail light write up but mine is a bit different than usual.
    Lets Begin:
    Here are the supply's you will need in order to tint your tails properly.
    First remove your tail lights & third brake light from the truck.
    Next you want to take some soap and water and lightly wash the lights.
    After you wash the lights you want to get a clean shop rag and put some lacquer thinner on it. Don't over wet the rag as you can always apply more thinner if nessecary. Once the thinner is on the rag rub down the outer side of each light. The thinner will give it a scuffed up / matted look. Once you have gone over the lights with enough thinner they should look like these:
    Now its time to mix your paint. Put about 1/3 black in your spray gun and 2/3 clear. Mix well before spraying. What this allows for is a nice lighter coat of black letting you really manipulate how dark you would like your tail lights to come out. This also eliminated the step of clear coating and having to wait for your original base coat to dry.
    The lights will show much lighter than they will cure so keep in mind to spray a bit lighter because you can always add more.
    This is how they should turn out after you spray them. (Keep in mind my idea of tinting the tails was to get rid of the pinkish tint, not totally go blacked out with them)
    Leave about 30 - 45 minutes of curing/drying time. You want to make sure that they have fully cured before you place them on the truck again.
    Here are some before and after pictures of the lights...
    Before:
    After: (Crappy glare but you get the point)
    Sorry about the pictures, all i had was an iPhone and some of them didn't come out as clear as i would have liked. Later this afternoon i will take high resolution pictures of the lights to show the full effect.
    The up side to using the lacqer thinner method is that you can always return stock whenever you want. All you would have to do is take some more thinner to the lights and scrub them pretty hard to get the tint off. The other upside is one coat with a maximum of 1 hour drying time. (Usually they are cured within the first 25 minutes but its safe to let them cure for 30 - 45 minutes minimum.
    Hope you all have enjoyed my diy write up. It is my first write up so go easy on me! Feel free to ask any questions I may not have coverd.
    -Jason
  2. Nov 18, 2009 at 9:24 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    pretty bad ass man. i don't have all of those supplies, but i have done it with vht niteshades. the niteshades sucks. i just sent out my tails to have professionally tinted.... similar to this.
    good job, looks great!
  3. Nov 18, 2009 at 12:52 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    damn, thats pretty professional. I think you should offer this as a service as this is quite a steep investment in equipment and paint for most members. Awesome job tho! :thumbsup:
  4. Nov 18, 2009 at 1:01 PM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    or you can go get vht. aout 12 bucks at autozone
  5. Nov 18, 2009 at 1:05 PM
    griffin407c
    Upstate NY
    definitely doesn't produce the same results. i've used that stuff before. mixing black and clear and using the proper spray gun gives a 100x better results in my opinion.
  6. Nov 18, 2009 at 11:57 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    Not in California you can't, only off the net. I have my own paint gun and might think about doing it this way.
  7. Nov 19, 2009 at 12:05 AM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    nice writeup!!!
  8. Nov 19, 2009 at 12:40 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    cool writeup... if only I had all the supplies :/
  9. Nov 19, 2009 at 5:33 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    It's not even comparable.
  10. Nov 19, 2009 at 5:49 AM
    SURFTACO
    SURFTACO Well-Known Member
    New Jersey
    09 Tacoma
    3'' Pro Lift, 275 70 17 Tires Rear Suspension TSB Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover
    Nice write up man. Im thinking of doing this but I live in NJ. I'm sure it's illegal
  11. Nov 19, 2009 at 7:48 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    I picked some of that VHT up at PepBoys here in California, granted it is harder to find.
    Nice job OP, looks good!
  12. Nov 19, 2009 at 1:17 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Not if you do one coat ;)
  13. Nov 19, 2009 at 2:26 PM
    Taco Ron
    Taco Ron Male Member
    Very nice write up. Thanks for your effort.
