DIY Tranny Oil Change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by low12, Aug 26, 2009.
  1. Aug 26, 2009 at 9:59 AM
    low12
    low12 [OP] Active Member
    RUFFIAN
    Virginia
    Prerunner SR5 V6
    I want to replace the Tranny Oil on my 2004 Tacoma Automatic V6 Double Cab , is there a tutorial or how to on this forum, thanks. preciate it.
  2. Aug 26, 2009 at 1:46 PM
    spasur
    spasur Well-Known Member
    New Orleans
    02 PreRunner 4cyl
    As far as I know you can drain and fill the auto tranny, but without specialized equipment you can't get all the fluid out. There are some 15 qts of fluid that are in the tranny, radiator and lines connecting the two, but you can only drain out ~3-4 qts.
    I don't know about a how to, there may be one out there...you should be able to take out the fill and drain plugs and let it drain out, then fill until it won't take any more.
  3. Aug 26, 2009 at 2:11 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Just buy a Haynes manual for your truck, they should have your generation of manuals of your truck in your local auto parts store in-stock. And if they don't carry it in-stock on a regular basis, then don't go there. :D
    And if you have any other questions the manual can't answer, then post your question on here.
