DIY TRD Intake / ISR intake silencer removal / IFA intake flow accelerater
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Only Danks, Jan 3, 2014.
  1. Jan 3, 2014 at 7:07 PM
    Only Danks
    Only Danks [OP] TRUKWERX : Desert Racing Products
    Bryant
    San Diego, CA
    05 Black TRD O/R 4x4
    3" MID-TRAVEL LIFT: Fox 6x2.5 Front RR C/O's, Fabtech unibal UCA, Fox 10x2 Rear RR Shocks, All-Pro Leaf Pack, Fox 2x2.5 Air Bumps all 4, Strapped all 4, TC Gussets:, Lower Arm Cam Tabs, Front C/O Bucket Tower, Spindles, OTHER: Custom Front Bumper skid, Custom Rear Tube Bumper, McNeil Racing 3" Fiberglass Fenders, McNeil Racing 4" Fiberglass TT Bedsides, 2 Matching Vertical Spares, GrillCraft black mesh, 07 LED Tails(black), Headlights (black), Viper 5204 Alarm, Remote Start, Cobra 19 CB Radio, 6 ft Red LED Firestick Whip, High-lift jack, Black Emblems, STEREO: Custom Nexus7 inDash, Rockford 3sixty.3 to SPDIF, Rockford T1 6.5 Comp Front, Rockford T1 6x9 rear, Rockford PBR300x4 Amp, Rockford P310 (x2) rear seats, Alpine 1100w amp, USB DAC via SPDIF, USB Audio ROM, FUTURE MODS: TC +2" LT Kit, 8" LT Coilover, 16 Rear Piggys, L/T CV Axle Shafts, Heim Steering, DMZ SUA kit, Bedsaver cage, Shackle Crossmember, Motor Mount Gussets, Box Frame
    Iv decided to do the ISR / IFA mod, drop in a TRD filter in the stock air box, and remove the fender elbow.
    As for the ISR / IFA mod, Id prefer to just replace the whole "air intake tube" with a new one with no silencers (rather than removing the silencer and plugging the whole), in case anything goes wrong.
    Iv found this part # PTR03-35090-AB - TRD Air Intake Tube for CAI
    http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-9264
    Does anyone know if this works with the stock air box?
  2. Jan 5, 2014 at 9:22 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Just leave it alone.
    Toyota designed an air intake system that is just perfect for your engine.
    Anything else is a waste of your money.
  3. Jan 5, 2014 at 9:26 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    Removal of silencer won't let you pass smog. Well at least in California. They filed it under "visual"
  4. Jan 6, 2014 at 10:50 AM
    Only Danks
    Bryant
    San Diego, CA
    Totally agree, they built it well, for the best over all. But it is likely they make some minor air restrictions to make it slightly quieter(as most people want). But i wouldn't mind a slightly less restrictive intake with maybe a better throttle response and little more aggressive sound. But yea the TRD CAI definitely is not worth the $$.
  5. Jan 6, 2014 at 10:53 AM
    Only Danks
    Bryant
    San Diego, CA
    So even though the numbers on the machine pass, if they visually inspect and suspect anything has been modified you can't pass? Seems silly! the TRD CAI removes the silencer...
  6. Jan 6, 2014 at 2:36 PM
    DylansBase
    Dylan
    Murfreesboro TN
    Well my friend has a 2004 reg cab and removed the silencer and plugged the whole back. But yes the #'s were good but it didnt pass because the intake had been "altered". They might have just been havng a shitty day because i know mutiple others that have done this mod, so its really just hit or miss. It was a simple fix, all he did was pull the silencer out of the cab and put it back.... passed smog and then removed it right after in the parking lot.
