DIY Valve swap for Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nevenelestate, Mar 13, 2017.
  1. May 16, 2017 at 7:19 PM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    I too am going through this right now....today on the way home from work truck became sluggish and cel and trac off lights are on. Researching i came across a thread that one member went the bypass route through hewitt technologies. I am hoping it is covered under warranty. I am at 58k miles but depends on when the 5 years started. We will see, nevertheless a big THANK YOU for your time and experience. Excellent write up...How much did the replacement cost you?
    scottfarm likes this.
  2. May 16, 2017 at 7:20 PM
    dustin613
    dustin613 New Member
    Dustin
    2012 Tacoma TRD OR DCSB
    You'll have a hard time getting it covered under warranty. The guys at the dealership here just told me flat out that it was only covered under the 3-year 36,000 mile warranty. Mine went out at 4.5 years and 30,000 miles. I paid $430 plus $20 shipping for my valves, and I replaced them in under an hour thanks to this thread.
    Marc70 likes this.
  3. May 16, 2017 at 7:27 PM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    Lots to come
    Thats what i was wondering. I will have to wait until i hear from the dealership. Its not the end of the world if its not, i will just go this route. Thanks for your response. Everything all good with your truck now?
  4. May 16, 2017 at 7:27 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Mods Can we make this a sticky?
  5. May 16, 2017 at 7:28 PM
    dustin613
    Dustin
    Yep, back to normal (same symptoms as you). I just try to let the air injection process finish before putting the truck in drive. I'm not sure if that was part of the issue, but I figured it couldn't hurt!
    Cheers,
  6. May 16, 2017 at 7:33 PM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    Lots to come
    Can there be any further damage while driving waiting on parts and getting it done? Or best to not drive it at all? My commute to work is only about 15 mins each way through town?
  7. May 16, 2017 at 8:33 PM
    dustin613
    Dustin
    I'm no expert, but from what I understand there are reed valves in addition to the solenoid valves in this system to prevent (mostly) exhaust gases from going through the system backwards. I drove mine for a couple days with a similar commute, and my pump didn't show any signs of being touched by exhaust gases. Couldn't say if it could damage anything in a different way though.
  8. May 16, 2017 at 8:34 PM
    Admiral Awesome
    Admiral Awesome IG:Bucklaooooo
    anthony
    Houston Texas
    2012 DC TRD LT
    Camburg 3in LT kit fox shocks/bypasses 315-75-16 Scs f5 wheels gunmetal 16x8 Prinsu rack 40in heretic light bar Cali raised ditch light Baja squadron pros McNeil fiberglass fenders Adv fiberglass bedsides Volant intake
    mine just went out today at 81k miles :( leaving for work and my engine light came on.
  9. May 17, 2017 at 4:43 AM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    Lots to come
    Okay thank you. I am just wondering if the codes will show if it is the pump that is bad or the valves. I didn't see that the OP replaced the pump as well.
  10. May 17, 2017 at 9:27 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    @MTgirl
    Good info on the first page of this thread. Sticky?
  11. May 17, 2017 at 9:35 AM
    Large
    Large Red
    Ask for a sticky, we have multiple threads on this same issue with 30+ pages. It's been covered.
  12. May 17, 2017 at 10:01 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I believe this is the only thread where a lower cost nonTacoma assembly was used to correct the problem other than Hewitt's bypass
  13. Jun 8, 2017 at 3:39 PM
    nevenelestate
    nevenelestate [OP] Well-Known Member
    Andrew
    Southern MD
    12 Tacoma V6 4X4 SR5
    Stock
    I used the OE Toyota parts to fix it...not sure what you're talking about the nonTacoma parts.
  14. Jun 8, 2017 at 3:42 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Correction- nonTacoma parts.
  15. Jun 8, 2017 at 3:44 PM
    #35
    nevenelestate
    Andrew
    Southern MD
    Stock
    Still don't get it, the parts were all Tacoma parts. Same PNs in as came out.
  16. Jun 8, 2017 at 3:45 PM
    #36
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    My mistake, I thought they were Tundra.
  17. Jun 8, 2017 at 4:09 PM
    #37
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  18. Jun 10, 2017 at 12:49 PM
    #38
    gatordc03
    gatordc03 Member
    Dennis
    Marietta, GA
    2012 Tacoma DCSB Limited
    Did the swap today myself. Took me about an hour and fifteen minutes. Would have been quicker but I didn't fully remove one of the nuts on the exhaust - duh... Thanks so much for the help with the parts.
    I did everything with the 10mm and 12mm short sockets and used a 3" and 6" extension to help out - for anyone looking to make sure what to get. I didn't have any bolts shear off or anything like that.
    Again - great help and would highly recommend.
    Spent $493.34 - I had it sent next day air and also ordered 2 extra gaskets that were on the Toyota quote. Quote from Toyota was for $2000.
    Hope others try this - it isn't very difficult.
    Marc70 likes this.
  19. Jun 10, 2017 at 4:35 PM
    #39
    nevenelestate
    Andrew
    Southern MD
    Stock
    Glad it was able to help, there's always that one nut that doesn't want to play along ;)
  20. Jun 11, 2017 at 11:02 AM
    #40
    bugsbomb
    bugsbomb New Member
    12 Tacoma TRD Double Cab
    2012 Tacoma V6 TRD 4x4 with 64k miles. CEL and Trac Off lights with codes P2440/P2442 and ECU in limp mode. I skipped the dealership and diagnostic after reading this thread. I put about 200 miles on the car in limp mode, no harm, just keep under 2300 rpm to avoid dumping gas. I Ordered parts (valve assembly $430 / 2 gaskets @ $1 each) and followed these fantastic directions to fully fix my problem in about 90 min and saved myself about $1500 bucks. Dealer quoted 2k to fix. If you have same symptoms, save yoursel some cash... thank you OP, great write up!!!!!
